Old Jul 07, 2002, 10:34 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Tiger Moth on Floats DXA Power weirdness
I had my first float mishap on Sat. I had a fresh charged QC 830 pack and was positioned (CG) in the usual spot. Conditions were great with little or no wind. I went to full power and she would not take off. I tried three times to get on step and the third time she hooked a right turn and flip over nose in. I rescued it and dried it out and checked everything when I got home and nothing was damaged. So, I was wondering what went wrong? (I had 2 full packs of float flying before and was able to get airborne then) I fully charged the QC 830's until the green light then put my Whattmeter on them to check the voltage. 8.2 volts. I went ahead and reconnected the leads to the B+ and B- leads on the board to bypass the protection curcuit in flight. I then took amp readings at full throttle with the gws 9X7 and the 10X4.7 props. I got 1.7 and 1.8 respectively at full throttle. I don't have the Whattmeter for micro stuff, so it could be off a little.
I run the stock motor without a heatsink and have never noticed a problem with power before. What are the signs of a DXA motor going bad? The amps seem to be ok? Is that voltage ok on the pack?
I have 45+ flights averaging about 20 mins a flight session logged on this motor.....
cactus is offline Find More Posts by cactus
Old Jul 10, 2002, 02:02 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
I'm no expert as I've only killed one DX-A motor, but it sounds like your motor may be suspect. When mine went, it was started to act like I was flying at 1/2 throttle the whole time. My Gym-E will normally stay airborne with about 1/2 throttle, but it took full to keep it aloft. I changed the motor, and voila! She was back to normal. By the way, my IPS probably had approximately the same running time on it as yours does when it died
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jul 10, 2002, 09:44 AM
cactus is offline
cactus's Avatar
Joined Sep 2001
Yeah, that's what I thought. I am going to order a replacement motor and just for fun I am going to start using a heat sink
GWS Tiger Moth on floats Pat Daily Parkflyers 28 Dec 22, 2008 08:58 AM
Tiger Moth on floats? mikeflys GWS (Grand Wing Servo) 30 Mar 26, 2004 04:40 AM
Tiger Moth on floats... DennisG Parkflyers 11 Jun 16, 2003 11:55 PM
Travels with Tiger Moth (on floats) Martin Hunter Parkflyers 26 Sep 19, 2002 09:55 AM
Tiger Moth on floats - Early Morning Photo!!! CheeseWing Parkflyers 14 Aug 14, 2002 09:29 PM
