Old Apr 14, 2006, 09:03 PM
lordbyronxxiv is offline
Find More Posts by lordbyronxxiv
Joined Sep 2005
Question
Difference between 2 stroke and 4 stroke engine
I am new to the hobby, I was just curious, what is the difference between a 2 stroke and a 4 stroke engine, is one better than the other?
Thanks.
lordbyronxxiv is offline Find More Posts by lordbyronxxiv
Old Apr 14, 2006, 09:28 PM
jbatch is offline
Find More Posts by jbatch
Lawn darts, anyone?
Long Island, NY U.S.A.
Joined Oct 2003
Never heard of 2 stroke or 4 stroke electric motors, so can't answer question.
If your question relates to internal combustion engines, you'll get better info
by posting on the "Aircraft - Fuel - Airplanes" forums. That's where the glow
fuel/gas guys hang out.
jbatch is offline Find More Posts by jbatch
Old Apr 14, 2006, 09:47 PM
charge1(ds) is offline
Find More Posts by charge1(ds)
Joined Apr 2006
Well if you didn't repost this into a different section. Check this 2 links each one is a different type of motor. 2 stroke produces higher rpm. 4 strokes turn out more torque less rpm.
Also your car is a 4 stroke equiped vehicle. http://science.howstuffworks.com/two-stroke2.htm
http://science.howstuffworks.com/engine1.htm 4-stroke
also in an rc the 2 stroke engine does not have the read valve fuel/air flow is controlled through a hollow driveshaft with intake port and open end into the chamber. hope this helps!!!
charge1(ds) is offline Find More Posts by charge1(ds)
Old Apr 14, 2006, 10:34 PM
ryanl2006 is offline
Find More Posts by ryanl2006
ryanl2006's Avatar
Ames, Iowa
Joined Oct 2002
As I understand it, on a 4 stroke you have fuel come in, then it explodes, then the exhaust leaves, then new gas comes in. The new gas coming in and exhaust leaving is in 2 different steps.
In a 2 stroke, the fuel comes in at the same time as the exhaust leaving. This produces generally more power to weight and more rpm because you are doing 2 steps at once. It is also less efficient because some of the new unburnt gas goes out with the exhaust. They also have much worse emmissions because again, a lot of unburnt gas is leaving with the exhaust.
ryanl2006 is offline Find More Posts by ryanl2006
Old Apr 15, 2006, 01:22 AM
Joined Apr 2006
Thats the jist of it.
Old Apr 15, 2006, 03:25 AM
wolw is offline
Find More Posts by wolw
<- Balsa flies better ->
wolw's Avatar
Gustafs, Sweden
Joined Feb 2006
Thanks.
The 4-stroke has more torque, almost like an electric
Seriously, being away from the hobby 20 years, going combustion feels like taking a step backwards.
wolw is offline Find More Posts by wolw
Old Apr 15, 2006, 06:38 AM
BeavrdamElectric is offline
Find More Posts by BeavrdamElectric
Beaverdam Creek, VA
Joined Aug 2005
4 strokes generally use valves in the cylinder head, actuated by a camshaft. RCV engines are 4-stroke with a rotating sleeve with a port in it.
2-stroke engines can be piston port (old time ignition engines), reed valve (most Cox engines), rotary valve (rear carburetor, high performance mostly) or use a passage in the crankshaft (most, the ones with front carburetors) that's timed to line up with the carburetor when the piston is going up.
Piston port and reed valve will run about the same either way(with glow plugs anyway).
Good Luck!
BeavrdamElectric is offline Find More Posts by BeavrdamElectric
Old Apr 15, 2006, 09:25 AM
electricFlyNut is offline
Find More Posts by electricFlyNut
Manchester, NH
Joined Mar 2006
I believe 4 stroke engines have more windings than two stroke motors. Also they can handle more speed without throwing a magnet. Not sure about max current differences.
electricFlyNut is offline Find More Posts by electricFlyNut
Old Apr 15, 2006, 11:26 AM
grouchy1 is offline
Find More Posts by grouchy1
grouchy1's Avatar
Edison, NJ
Joined Mar 2005
Is this the right forum to get an egg salad recipe?
grouchy1 is offline Find More Posts by grouchy1
Old Apr 15, 2006, 01:04 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
A four stroke has the windings on the inside and a two stroke has the windings on the outside.
Charles
Old Apr 15, 2006, 01:34 PM
chris8105 is offline
Find More Posts by chris8105
Cincinnati Cin N.Knty, Ohio, United States
Joined Sep 2004
http://www.rcgroups.com/forums/showthread.php?t=478786
chris8105 is offline Find More Posts by chris8105
Old Apr 15, 2006, 01:46 PM
Joined Apr 2006
For some of you unless your joking strokes is gas motors only.
Old Apr 15, 2006, 03:46 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
four stroke or two stroke egg salad?
Toshi
TMorita is offline Find More Posts by TMorita
Old Apr 17, 2006, 10:30 AM
Sonsight is offline
Find More Posts by Sonsight
Sonsight's Avatar
United States, AR, Cabot
Joined Aug 2004
Can I supersize that egg salad?
Jake
Sonsight is offline Find More Posts by Sonsight
Old Apr 19, 2006, 11:40 AM
Manchester, NH
Joined Mar 2006
Jake
Nope, you'd need a turbocharger or a supercharger for that!
Discussion difference between 2 stroke and 4 stroke wickkerr82 Fuel Plane Talk 7 Jul 08, 2006 01:24 PM
Alert Difference between a 2 & 4 Stroke? #2 ? coaxial-gyro Engines 3 Aug 30, 2005 04:46 AM
Difference between a 2 & 4 Stroke? gulfstreampiper Engines 14 Aug 24, 2005 08:06 AM
Question So, 2 or 4 stroke for this bird? fiveoboy01 Engines 3 Mar 30, 2004 01:28 AM
