Old Jul 07, 2002, 02:36 PM
UK
Joined Jan 2001
Looking for a (modulated) IR beam break kit for school project...
I'm looking for an IR beam break kit ... I need one for a school project. I need an IR tx/rx with a logic output ... I can accomodate either a beam break = logic 1 or break = logic 0.
I know there are relay kits available, which could be made give a logic output, but relay current draw would be unnecessaryily high. Plus, I was looking at finding a modulated IR beam for ambient light rejection. I don't think the Maplin kits have this.
Range must be door width minimum ... ideally 1.5-2m.
I've found a circuit on the web here:
http://www.ee.washington.edu/consele...l/proposal.htm
http://www.ee.washington.edu/consele...inal/final.htm
but I would like to avoid a 741 if possible (negative power supply needed and I was gonna use a receiver pack). Plus for some reason it doesn't work on the simulator (crocodile technology).
ANY help appreciated,
Ben
Ben C is offline Find More Posts by Ben C
Old Jul 09, 2002, 07:37 PM
Shirley, New York, United States
Joined Apr 2002
radio shack
Does england have an equivilent for radio shack? here in the states, Radio Shack has a sharp IR detector, which is a small silver box with three pins. The ir detector will filter out all but 40khz modulated signals. That plus a lens would be a fine detector stage. You could build an emitter stage with a 555, and an infra-red led.
Lots of info on IR detection can be found on Robot news groups and robotics info sites. Many homebuilt robots use IR for obsticle (sp) detection.
-Adam
afabio is offline Find More Posts by afabio
Old Jul 11, 2002, 02:26 PM
UK
Joined Jan 2001
Which Sharp IR module would you recommend?
There are quite a few and I do not know the difference between them.
I need output like this:
- modulated IR beam = 1
- non modulated, always on IR = 0
- broken beam = 0
The reverse would be fine, too, so long as all the above were reversed.
Thanks a lot,
Ben
Old Jul 12, 2002, 07:06 AM
London UK
Joined Sep 2001
Modulated IR beam
Have you considered modifying an infra red remote control system. These use a modulated beam. Maplin do a pair of kits number K6708 and K6709 which may be suitable.
Neil
Neil McGrath is offline Find More Posts by Neil McGrath
Old Jul 12, 2002, 04:18 PM
UK
Joined Jan 2001
Although I still do not fully know the difference between the sharp modules, I think that they are what I want.
But does anyone know where they can be found in the UK? Or an equivalent product made by another company?
Ben
Old Jul 12, 2002, 04:43 PM
Joined Apr 2002
Ready to go setup
Here's a pre-made board with a sharp sensor on it. This particular sharp sensor is not a break beam, but a object sensor. it's $30.00
All the data is on the page. I'll try to get you some more info on the original sharp sensor I mentioned.
Another option is an industrial break beam sensor. These can be had from banner, or sick optic. Prices are high as these are industrial devices. $100.00 usd is common. However, I've had luck asking for samples when I was young and doing my own school projects.
-Adam
Old Jul 13, 2002, 11:49 AM
UK
Joined Jan 2001
I found the IS471F (in the UK!) on www.rswww.com . It turns out to be exactly what I need, a modem with four pins: modulated diode sink, logic out, vcc and ground. The same IC modulates and demodulates the signal - no messy discrete timing circuit, and perfect syncronisation!
Price (ex. diode) £2.90!
[Datasheet]
OK, final question. I'll probably need an IR reflector (either that or have a diode on VERY long wires). Obviously a mirror is no good as it sends light away from the source. What I need is one that uses total internal reflection - just like a bike reflector, in fact.
Would a simple bike reflector work? I assume the red one would be better for infrared (?). Or would I need a special (read: expensive) reflector to get at all decent performance?
Thanks guys,
Ben
Yippee! build a fomie from scratch for a school project; Help Needed to Jarg Foamies (Kits) 3 Nov 09, 2004 03:04 PM
Hand launch balsa plane for school project Terry W Fuel Plane Talk 6 Oct 28, 2002 01:17 AM
Looking for a low-wing kit for endo setup Mitch G Sport Planes 36 Oct 09, 2001 10:21 AM
Looking for 8'-9' DH Mosquito Kit. Randall Miller Electric Plane Talk 2 Jun 11, 2001 12:11 AM
