Old Jan 30, 2013, 07:54 AM
buzzfly is online now
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
Originally Posted by Fickle flier View Post
I have read many times in this thread about which film covering is best. That said, I can not find it now. Can you guys give me some guidance on the pros and cons of the various films. I bought my Gambler in August and am finishing up a project now then I will build it. I wanted to get the same film for both planes.
I can get Microlight at the LHS which I would prefer if it is equivalent to others available, but since I am ordering it ahead I could wait and get something else. I am planning to do full weight monokoat over glass and CF on the pod.
I used Ultracote lite. Great film, and incredibly tough! It's also amazingly light. The translucent red is a very visible color, but the trans yellow is so pale that it's almost clear.
Hope this helps!
-- the markster
buzzfly is online now Find More Posts by buzzfly
Old Jan 30, 2013, 05:58 PM
flynfrfun is offline
Find More Posts by flynfrfun
flynfrfun's Avatar
Seattle, WA
Joined Apr 2006
I used Ultracote Lite red/yellow on mine. If you want to see, here is a pic. Yes, the yellow is pretty light in color. Very easy to apply and seems strong.
flynfrfun is offline Find More Posts by flynfrfun
Old Feb 06, 2013, 02:44 PM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
Ultracote Lite Transparent is my personal preference for wing. I use Monokote for the fuselage (for abrasion durability) and either the same Ultracote Lite Transparent or SoLite/Nelsonfilm on the tail feather sheeting.
Allan Wright is offline Find More Posts by Allan Wright
Old Feb 26, 2013, 06:19 AM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
ok almost to the point of electronics. need help selecting.
This is what i have and will use. Hitec HS-45HB servos. Spektrum Receiver.
what do i use for Battery? BEC? what else is needed?
twister782 is offline Find More Posts by twister782
Old Feb 26, 2013, 06:25 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Just so it is known I Suck at covering. HaHa
i spent 3 1/2 hours just covering the pod with monocoat. still not happy with it.
waiting on my solite to get here to do wing. i hope that goes better
Old Feb 26, 2013, 07:16 AM
Curtis Suter is offline
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Assuming you're electronics are okay with using 6volts I use these Cr123a batteries:
http://www.ebay.com/itm/2-NEW-OEM-Su...1103%26ps%3D54
These are NOT rechargeable! I put in a set in the early Spring and am able to fly all season. No worries if I wish to go fly at the last minute as I know they are charged and ready to go.
Curtis
Montana
Curtis Suter is offline Find More Posts by Curtis Suter
Old Feb 26, 2013, 07:18 AM
buzzfly's Avatar
Joined Apr 2003
There are a lot of opinions on this one, and if you read through the thread, you'll see them.
As for me, I opted for a 400mah 4-cell Nimh pack from Cheapbattertpacks.com (square configuration).
This is a much simpler option compared to a 2s lipo and regulator, or soldering together two camera batteries.
Three packs come to about $30 with shipping, and combined offer you more flying time than you're likely to use in a day.
YMMV
--the markster
Old Feb 26, 2013, 08:11 AM
Lee, NH, USA
Joined Jun 2001
Originally Posted by buzzfly View Post
T I opted for a 400mah 4-cell Nimh pack from Cheapbattertpacks.com (square configuration).
This is the recommended batteries. Whatever you use the Gambler is designed for a battery pack that weighs between 20-30 grams, or about an ounce. If you go lighter you'll just be adding lead to the nose, so might as well use good old reliable NiMh cells.
I actually use a single LiIon rechargeable cell surplus from Qualcom Cell phones. They've lasted me forever and I will be sorely disappointed when they die of old age.
http://pease1.sr.unh.edu/aew/rc/HowTo/Qualcomm/
Old Mar 02, 2013, 06:45 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
covering question.... is it wise to make a covering hinge. or should i use the suggested tape
Old Mar 02, 2013, 07:01 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
I have had short life with covering hinges. It hasn't failed suddenly and completely, but they should be inspected frequently. Tape hinges aren't forever either, but they seem to last longer. Both must be replaced from time to time.
Al M is offline Find More Posts by Al M
Old Mar 02, 2013, 07:41 AM
buzzfly's Avatar
Joined Apr 2003
I used Blenderm tape for my hinges. This summer will mark three years of use on the original hinges.
-- the markster
Old Mar 02, 2013, 08:08 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
thanks!! great advice
Old Mar 02, 2013, 01:20 PM
TScott1118 is online now
Find More Posts by TScott1118
TScott1118's Avatar
United States, NM, Albuquerque
Joined Nov 2011
Another vote for Blenderm.
TScott1118 is online now Find More Posts by TScott1118
Old Mar 03, 2013, 06:14 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
my solite should be here on tuesday. I am ready to cover. spring is around the corner and I am pumped to add the Gambler to my fleet! I am sure I will be asking more questions when I start to add the electronics.
Old Mar 04, 2013, 08:02 AM
Lee, NH, USA
Joined Jun 2001
I've always used tape hinges. Blenderm is my preferred tape as well.
Article Wright Brothers R/Cs Gambler AG X-Tail DLG Laser Cut Kit Review Goinav8n Hand Launch 22 Mar 17, 2015 10:36 PM
Article Gambler+ from Wright Brothers RC Mitch G Sailplane Talk 2 Aug 17, 2004 08:52 AM
Wright Brothers R/C Electric Mite BEC Electric Flight Events 3 Aug 26, 2003 08:48 AM
