Old Jan 02, 2013, 07:44 AM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
Originally Posted by buzzfly View Post
If you want, you can read every post in this thread -- something that I did before I built mine, and from there you will learn that the design is well honed.
Thanks for the kind words. Anyone (other than myself) who has read all 4000+ posts in this thread has my respect.
Allan Wright is offline Find More Posts by Allan Wright
Old Jan 05, 2013, 02:54 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
I have read almost all the posts.. did skim over some areas. glad you are still alive.
going to open the package today and start looking over the directions.
twister782 is offline Find More Posts by twister782
Old Jan 12, 2013, 05:38 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
woohoo! started my build. working on pod.
1st question. should i use Gorilla foaming glue in the area right behind F3? to fill that void. it would real make that area rock solid. the area here in picture
Old Jan 12, 2013, 07:14 AM
Al M is online now
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
If you start doing things like that it will become too heavy in a hurry.
Al M is online now Find More Posts by Al M
Old Jan 12, 2013, 08:44 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
ok i will stay light. i have a tendency to over build
Old Jan 12, 2013, 09:34 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
can anyone help with pictures of how they sheeted the top of the pod? do i use the 4- 2 1/4" x 4" pieces of balsa? like to have a close up view of what it is supposed to look like when completed
Old Jan 12, 2013, 10:21 AM
buzzfly is online now
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
Twister,
here are some links to posts in this thread that might help you.
1st -- regarding filling the void behind F3, here is an option:
http://www.rcgroups.com/forums/showp...7&postcount=78
If you look at the second picture, you'll see he used a little bit of Gorilla glue sprinkled with water. Allan commented that he thought this would be light and solid.
After I ripped out the tailboom on a launch, I repaired it the same way and have had no problems since.
2nd -- regarding pics of the sheeting of the pod, here are a variety of posts that might help you out. If these aren't specific enough, post here, and I'll take pics of my pod. Keep in mind though, that mine is 2 1/2 years old, rode hard and put up wet!
-- Mark
http://www.rcgroups.com/forums/showp...5&postcount=57
http://www.rcgroups.com/forums/showp...&postcount=112
http://www.rcgroups.com/forums/showp...&postcount=118
http://www.rcgroups.com/forums/showp...&postcount=303
buzzfly is online now Find More Posts by buzzfly
Old Jan 12, 2013, 10:53 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Thank You, Mark. yes that answered my question.
boB
Old Jan 12, 2013, 01:00 PM
TScott1118 is offline
Find More Posts by TScott1118
TScott1118's Avatar
United States, NM, Albuquerque
Joined Nov 2011
I crammed some balsa wedges between the pod and shaft where the shaft enters the pod. Then squirted a little thin ca on it. This helped to beef it up without adding much weight.
TScott1118 is offline Find More Posts by TScott1118
Old Jan 12, 2013, 06:30 PM
Al M is online now
Wallingford, Ct
Joined Sep 2001
My problem is that after I beef up one thing, I can't stop there.
Old Jan 14, 2013, 04:01 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
is 30 min. epoxy the same as finishing epoxy?
Old Jan 14, 2013, 05:21 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
if you had to do it all over again would you.....
cover pod with monocoat or paint?
Old Jan 14, 2013, 07:12 AM
Al M is online now
Wallingford, Ct
Joined Sep 2001
They are not the same.
I covered with the real light glass cloth and Nelson film for a light color. I don't remember how I did the cloth, but I think I might of sprayed it lightly with spray adhesive such as 3M77 and put it in place. Then brushed with Polyclilic. Probably two coats.
Old Jan 14, 2013, 08:31 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
No.
30 minute epoxy is a bonding epoxy, typically fairly thick.
Finishing epoxy is used for surface coating and/or with a fabric. It is usually quite thin. Not as strong a bond but it works better for surface finishing.
Finishing epoxy
http://www3.towerhobbies.com/cgi-bin...?&I=LXK304&P=7
aeajr is offline Find More Posts by aeajr
Old Jan 14, 2013, 09:18 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
http://www.wrightbrothersrc.com/tips.htm
Check out the Reinforcing pod video.
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Article Wright Brothers R/Cs Gambler AG X-Tail DLG Laser Cut Kit Review Goinav8n Hand Launch 22 Mar 17, 2015 10:36 PM
Article Gambler+ from Wright Brothers RC Mitch G Sailplane Talk 2 Aug 17, 2004 08:52 AM
Wright Brothers R/C Electric Mite BEC Electric Flight Events 3 Aug 26, 2003 08:48 AM
