Old Nov 23, 2009, 12:49 PM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
I'm surprised your local hardware store doesn't have 4-40 nylon bolts. Aubuchon, ACE and True Value here all do. Also SIG carries them, so your local hobby store is sure to have them as well.
I usually try to remember to toss extra bolts in any kits I ship to the Metric world (i.e. Europe, South America) because there the bolts are a huge pain to get.
To be clear, the bolt is only expected to fail if you crash. I've never broken one during normal use of a Gambler, only when I've crashed.
Originally Posted by Teezer View Post
Speaking of the nylon bolt, mine broke on a hard landing on Saturday. No other damage, so I figured that I could zip over to the local Ace hardware and pick up another one real quick. Nope. Ace had nylon bolts, but not that small.
So, I flew on Sunday with a metal bolt (a donation from one of the helicopter guys), but I wanted to replace the nylon one for safety. I found a pack of 100 on Amazon for a couple of bucks (and free shipping because I was buying something else that was much more expensive), so now I'll have a supply of nylon bolts that will outlast the Gambler.
That brings me to a suggestion for Allen. Since the nylon bolts are so cheap, yet so inconvenient to buy, why not include a couple of extras in the kit? They are a part that's expected to fail, after all.
Terry
Allan Wright is offline Find More Posts by Allan Wright
Old Nov 23, 2009, 12:55 PM
Lee, NH, USA
Joined Jun 2001
Originally Posted by John255 View Post
In one of my spectacular crashes everything went except the screw.
Wow that is spectacular. If you don't make the CF pin so long that it binds in the former, the 4-40 bolt head does fail in a crash and often save the wing. I've had it happen a few times. I actually thought about switching to a 6-32 bolt early in the design of the Gambler, but the 6-32 never failed before the wing did, so I settled on the 4-40 because it can sometimes save a wing.
On a side note, I will be switching to another carbon product once the current batch of Gamblers sells out. I'll be switching back to the non-iron-on 'tacky thread' CF that I used for most of 2008. It's a tiny bit thicker than the preferred product, and you have to use spray glue to tack it in place before saturating it with CA, but it separates easily into 1/4" strips and is easier to work with than the current forumla of the iron-on product. I'm not sure why the manufacturer of the iron-on product keeps changing their manufacturing process, but at $13.00/ft. I need to go with something I KNOW will be manufactured consistently. I HATE making things difficult for my customers. This latest change happened without warning to me, until I received a $1000.00 order of carbon. As always, I'll make it right. Anyone having trouble with the current carbon just needs to contact me and I'll send them additional carbon as needed to get your kit built. I also included an extra 3/8" width in the current kits so people could cut away any of the 'hairy' edges that might occur when you're un-packaging your CF.
Old Nov 23, 2009, 01:07 PM
mr ray is offline
Find More Posts by mr ray
mr ray's Avatar
Canada, BC, Kamloops
Joined Dec 2008
John255, I have been looking but not too hard yet for a nylon bolt that has a better head than that stupid slot. My bolt twists and bends so much when trying to screw it in that I'm hoping there is something with a robertson head on it that I can use instead. If successful will let you all know. That pic of your crash was brutal. What happened? ...Ray
mr ray is offline Find More Posts by mr ray
Old Nov 23, 2009, 01:16 PM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
"I usually try to remember to toss extra bolts in any kits I ship to the Metric world (i.e. Europe, South America) because there the bolts are a huge pain to get."
Allan, I was going to mentions that .....
I contemplated getting a 3mm T nut, since I have plenty of 3mm nylon bolts already.
However I found someone in the UK apparently stocking the imperial ones;
http://www.modelfixings.co.uk/nylon_...tm#thumbscrews
srnet is online now Find More Posts by srnet
Old Nov 23, 2009, 01:38 PM
Lee, NH, USA
Joined Jun 2001
I had assumed that my customers in England could still get imperial hardware. It's good to know this is true.
Allan
Old Nov 23, 2009, 02:24 PM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Allan-
Would you mind posting brief instructions for using the iron-on variety? It's probably old hat to most builders, but I'm a newb and want to be sure I have it right!
To be sure that we're on the same page, I have the carbon that's a little over an inch wide and looks to have a layer of cellophane or some othe clear material attached to one side.
Thanks-
Rick
2400RDR is offline Find More Posts by 2400RDR
Old Nov 23, 2009, 02:30 PM
Lee, NH, USA
Joined Jun 2001
Originally Posted by 2400RDR View Post
Allan-
Thanks-
Rick
you have the new-formula iron-on product. I gave my suggestions on how to best work with this product on page 177 of this thread in a few posts. Let me know if you can't find the posts.
Old Nov 23, 2009, 04:22 PM
2400RDR is offline
Joined Feb 2009
That would be post 2653. I had actually seen that one, but hadn't made the connection between "thermal adhesive" and "iron-on" what with me being new to this and all.
It looks like you are suggesting not using the iron-on capability but rather the spray adhesive. Just for my information, which side of the carbon ribbon has the thermal adhesive?
Thanks-
Rick
Old Nov 23, 2009, 05:07 PM
aholein1 is offline
Find More Posts by aholein1
Joined Oct 2007
Today was a good day.. Post man delivered a perfect little box. Pics coming soon.
Thank you
A
aholein1 is offline Find More Posts by aholein1
Old Nov 23, 2009, 09:01 PM
Teezer is offline
Find More Posts by Teezer
Teezer's Avatar
Pagosa Springs, CO
Joined Jul 2007
One of the disadvantages of living out in the boonies. My "local" hobby shop is 100 miles away, and the hardware stores don't stock a lot of stuff, so Amazon is one of my major suppliers. But I'd rather have the inconvenience of the Colorado Rockies than the high-density rat race of a major city, so it's something I'm used to.
Thanks for the reply.
Terry
Teezer is offline Find More Posts by Teezer
Old Nov 24, 2009, 09:31 AM
Lee, NH, USA
Joined Jun 2001
Both sides do. It's the white spider-web looking substance on the surface. The problem is the manufacturer has been using less and less of it recently, so it's not all that easy to use as an 'iron-on' adhesive as it used to be. You'll have much better luck with a dusting of spray adhesive. Once tacked in place, saturating with CA will both permanently affix it to the spar and create a rigid composite for structure. There was nothing special about ironing it on other than convenience.
Old Nov 24, 2009, 06:16 PM
2400RDR is offline
Joined Feb 2009
Got it- thanks!
Rick
Old Nov 25, 2009, 12:13 PM
mr ray is offline
mr ray's Avatar
Joined Dec 2008
Hi Everyone,
I am on the finishing touches now. Just got my ultracote lite covering yesterday afternoon finally. My question is does this covering have a peel off layer or not? I can't seem to find any but it feels fairly thick for a lite covering...Ray
Old Nov 25, 2009, 12:35 PM
mr ray is offline
mr ray's Avatar
Joined Dec 2008
never mind I answered it myself. The fingers tell me more than my eyes nowadays...Ray
Old Nov 25, 2009, 01:01 PM
Lee, NH, USA
Joined Jun 2001
I usually use 2 pieces of masking tape to remove the backing. One piece on the covering, one on the backing, placed at a corner. Pull apart then remove the tape from the covering. It's easier than fiddling with the corner and a fingernail.
Article Wright Brothers R/Cs Gambler AG X-Tail DLG Laser Cut Kit Review Goinav8n Hand Launch 22 Mar 17, 2015 10:36 PM
Article Gambler+ from Wright Brothers RC Mitch G Sailplane Talk 2 Aug 17, 2004 08:52 AM
Wright Brothers R/C Electric Mite BEC Electric Flight Events 3 Aug 26, 2003 08:48 AM
