Old Nov 21, 2009, 07:16 AM
2400RDR is offline
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
A guy over in the classifieds has some carbon tow for sale that looks like it might be pretty easy to work with:
http://www.rcgroups.com/forums/showthread.php?t=1143560
Anyone know if it would be suitable to use on a Gambler? It's pretty cheap and I wouldn't mind using it rather than trying to cut apart the strip that came with the kit. I haven't tried cutting it yet, but it sounds like it's been a little problematic for a few folks.
Rick
2400RDR is offline Find More Posts by 2400RDR
Old Nov 21, 2009, 10:37 AM
jedoug is offline
Find More Posts by jedoug
jedoug's Avatar
United States, CO, Littleton
Joined Jun 2009
Rick
Rick,
It was actually very easy to cut. All I did was stick my X-acto into my building board and then pulled the ribbon through the blade slowly along the segments. If I remember the segments were in 1/8" increments so you need to cut with 2 segments together. With a good light on the ribbon the segments were very easy to see.
I was a little worried about working with this as well but it actually was very easy this way.
I hope this helps,
Jeff
jedoug is offline Find More Posts by jedoug
Old Nov 21, 2009, 11:08 AM
2400RDR is offline
Joined Feb 2009
Originally Posted by jedoug View Post
Rick,
I hope this helps,
Jeff
If I had the segmented stuff I'd definitely use it. What came with my Gambler is a sort of hairy 1 inch wide strip with no segments or anything to use as a cutting guide (photo attached). I believe Allen said that the segmented ribbon became unavailable.
What attracts me to the tow in the classifieds is that it's already in a nice 1/4" wide strip- no cutting necessary. Anything to make it easier for a newb (myself)
Rick
Old Nov 21, 2009, 11:11 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
https://www.acp-composites.com/searc...keep_https=yes
This is what I used for my scratch built Gambler.
I can take a photo of the package and the Carbon if you'd like.
Curtis
Montana
Curtis Suter is online now Find More Posts by Curtis Suter
Old Nov 21, 2009, 02:05 PM
John255 is offline
Find More Posts by John255
Pensacola, FL, USA
Joined Dec 2000
Rick,
There are several ways to do the 1/4" cuts in the CF.
Below is another way if you are concerned about cutting straight.
The only piece I had is only about a foot long, but this will work for any length.
Now if you do this on the dining room table and cut a nice grove in the finish You might as well go straight to the couch.
Good luck,
John255
P.S.
Tape the straight down in three places to keep it in place for the long cut. This also keeps you from cutting off your finger tips in case you want to play the banjo some day.
John255 is offline Find More Posts by John255
Old Nov 21, 2009, 02:22 PM
2400RDR is offline
Joined Feb 2009
Originally Posted by John255 View Post
Rick,
Good luck,
John255
P.S.
Thanks John-
I had actually considered doing just what you suggested, so if you say it'll work, I'll give it a try.
That precut quarter inch stuff was just pretty irresistible
Rick
Old Nov 21, 2009, 02:24 PM
mr ray is offline
Find More Posts by mr ray
mr ray's Avatar
Canada, BC, Kamloops
Joined Dec 2008
Hi John255, I wish someone had shown that when it came time for me to cut my cf. The only thing I would add is if it is like mine was,(it kind of resembled a squirrels tail) then use a little spray adhesive on the cf first. It really help to control all the loose fibres...Ray
mr ray is offline Find More Posts by mr ray
Old Nov 21, 2009, 02:50 PM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
Hello Rick, and Ray,
Well we've already discussed the need for many, many more pictures.
And, I have to be careful because I don't want to get between Allan and his customers.
However, what I had hope for was that the shooting would start right away, and thats why I posted the mini-how-to on photos, because as you do them they get easier, but I got no response.
I built my Gambler several years ago and the material at that time was very easy to rip apart into 1/4" strips. Sounds like from you Ray and and from Rick's pictures that the material has changed.
BTW, I never understood clearly until I saw the shots. Pictures tell the story in all languages. Words only give us hints that can go many ways!!!!
The spray adhesive sounds OK if kept light. You want the fibers to remain open so the thin CA can saturate and bond to the wood.
Good luck guys and hang in there....it's worth it!!
John255
Old Nov 22, 2009, 06:29 AM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Some thoughts on covering Gamblers.
The advertised weight difference between SoLite and Profilm Light does appear to be significant, 20g/Msq versus 38g/Msq. So I can see why the SoLite is often recommended. The reality is different I found, these are the measured weights of actual film;
SoLite translucent 29g/Msq
Solite solid black 34g/Msq
Profilm Light translucent (Oracover) 39g/Msq
Profilm translucent (Oracover) 58g/Msq
I found Profilm light a lot easier to apply than the Solite, it takes heat better and shrinks more. I have found that Solafilm (the heavier version of SoLite) sags a fair bit in hot weather, whilst Profilm sags very little.
The weight penalty of using Profilm light on a Gambler wing over SoLite would be 5g or so, rather than 10g based on advertised figures.
srnet is online now Find More Posts by srnet
Old Nov 22, 2009, 03:00 PM
2400RDR is offline
Joined Feb 2009
A little trick for setting the wing
When it comes time to make the hole for the wing hold down bolt, the plans call for using a toothpick or sharpened stick to make an impression for the drill.
Since the supplied nylon bolt is far too long anyway, you can cut off about a half inch, grind a point on it, screw it into the hold down tee nut and get a very nicely centered impression for drilling the hole through the TE.
Works like a charm.
Rick
Old Nov 22, 2009, 03:05 PM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
That's a good one Rick!!!
And the picture is good too.
Cheers,
John255
Old Nov 22, 2009, 03:26 PM
mr ray is offline
mr ray's Avatar
Joined Dec 2008
Hey Rick, That's using the old noggin!..Ray
Old Nov 22, 2009, 09:22 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
The pointy bolt method also comes in real handy when you are putting a new wing on a DLG that you have been flying for a while. I've also used it to mark a second wing when I wanted to use two different wings on the same fuselage.
I've found that I get better results by using a metal (Steel or Aluminum) bolt with a point ground on it to mark the wing. The threads on the nylon bolt have enough drag in the t-nut that it's sometimes hard to back it back out after marking the wing when all you have to grab hold of is the little pointy end. You can easily back a metal bolt back out with your fingers.
The drag on the nylon bolt makes it a better choice for the wing bolt because it stays tight and doesn't require constant retightening as a metal bolt sometimes does.
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Nov 23, 2009, 12:08 PM
Teezer is offline
Find More Posts by Teezer
Teezer's Avatar
Pagosa Springs, CO
Joined Jul 2007
Speaking of the nylon bolt, mine broke on a hard landing on Saturday. No other damage, so I figured that I could zip over to the local Ace hardware and pick up another one real quick. Nope. Ace had nylon bolts, but not that small.
So, I flew on Sunday with a metal bolt (a donation from one of the helicopter guys), but I wanted to replace the nylon one for safety. I found a pack of 100 on Amazon for a couple of bucks (and free shipping because I was buying something else that was much more expensive), so now I'll have a supply of nylon bolts that will outlast the Gambler.
That brings me to a suggestion for Allen. Since the nylon bolts are so cheap, yet so inconvenient to buy, why not include a couple of extras in the kit? They are a part that's expected to fail, after all.
Terry
Teezer is offline Find More Posts by Teezer
Old Nov 23, 2009, 12:45 PM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
Terry,
Your experience is the first I've heard anyone shearing the nylon.
There was a thread on the subject and I think the conclusion was the LE CF pin(s) absorbed most of the force and it was questionable that the nylon screw could ever be sheared.
Most of the hardware stores don't stock smaller than 6-32, and the supplied screw is 4-40. Another way to solve the prob would be to move to 6-32.
In one of my spectacular crashes everything went except the screw.
Regards,
John255
Article Wright Brothers R/Cs Gambler AG X-Tail DLG Laser Cut Kit Review Goinav8n Hand Launch 22 Mar 17, 2015 10:36 PM
Article Gambler+ from Wright Brothers RC Mitch G Sailplane Talk 2 Aug 17, 2004 08:52 AM
Wright Brothers R/C Electric Mite BEC Electric Flight Events 3 Aug 26, 2003 08:48 AM
