OK guys, Just got my gambler..
![]() Does anyone see any issues with running a single lipo cell to run the servos? Jeff www.CommonSenseRC.com |
John ![]() You know, after looking at these pictures I seem to remember seeing them elsewhere; probably in this same thread! Definatly open to the idea! Will probably do something similar .. Just need to pick up some aluminum or other simple piece to use Of course, we're suppose to get snow here starting tonight thru the weekend Unfortunatly no flying in the near future But, plenty of build time!!!
Pensacola, FL, USA
Joined Dec 2000
Yep you saw the picture here when someone else wanted to histart. I think you can also find thin aluminum at LHS in K&S metal assortment bin. Some hwd stores also have K&S. Sorry to hear you are getting ready to be snowed under, but building and indoor flying can be fun too. I build here in the summer when it's so hot you get baked alive at the field. Some of the new indoor stuff looks pretty exciting. Please continue to give us pictures of your projects. Regards, John255 |
Pensacola, FL, USA
Joined Dec 2000
We used to be restricted to limited light gear, but these days there are many ways to go and it's just personal preference. If your Rx will run full range on 3.5~4V then you could put a fairly large single cell in Gambler. Allen likes to use a large single cell and fly all week end in safety. Many guys choose small 4-NiMh packs and charge every 1.5 hours or so of flying. I've become used to using CR2 cells and replace the pack every 22+ flying hours for $5. They are just the right 1.0 oz. weight to balance the Gambler. Aren't you in the electronics business? Certainly you must know all this. Regards, John255 |
Will Do John..
I'm still working on the base here to allow us to fly in one of the large hangers. It's not used for aircraft any longer, and only contains a large running track and empty bball floors. Huge celing and everything! Unfortunatly i don't have anything that small any more (totalled my Curtis Jenny against a errant curb). Time for some 'smaller' stuff or time to pull out a sheet of bluecor!
Joined Mar 2007
Jeff - I used to use a very small single cell (3.7 volts) with a Low-voltage FMA M5LV receiver. It worked fine in my Bobolink, a very heavy plane compared to the Gambler. I may be using that same setup in my Gambler once I finally get her built.
I had no touble driving the 2 very small servos and receiver with that battery for an hour or two, at least. Which was just about all my plane could take...!! See the following sad link for more details: http://www.rcgroups.com/forums/showp...&postcount=126
| Thread Tools | |
| Article Wright Brothers R/Cs Gambler AG X-Tail DLG Laser Cut Kit Review | Goinav8n | Hand Launch | 21 | Nov 26, 2006 05:06 PM |
| Article Gambler+ from Wright Brothers RC | Mitch G | Sailplane Talk | 2 | Aug 17, 2004 08:52 AM |
| Wright Brothers R/C Electric Mite | BEC | Electric Flight Events | 3 | Aug 26, 2003 08:48 AM |
