Old Jul 07, 2002, 09:19 AM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Help! - Problem with Tiger Moth - CG?
I have a problem with my Tiger Moth when I fly it. It keeps on Porpoising & balooning, I keep having to feed down trim or keep pushing the nose down. Where should the CG be on this plane?
I'm thinking that maybe this plane is Tail Heavy but it seems to balance out pretty Fair. Where do you have your CG on your Moth?
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Jul 07, 2002, 09:32 AM
ronnath is offline
Find More Posts by ronnath
ronnath's Avatar
Iowa
Joined Oct 2001
on page 2 of this section is a thread called "tigermoth cg help". it gives some pretty good info on your question.
ronnath is offline Find More Posts by ronnath
Old Jul 07, 2002, 10:04 AM
mrebman is offline
Joined Nov 2000
Ronnath:
I just taped a flattened out little fishing weight to the nose of my Moth & went out to the field. She is flying much better now & I got quite a crowd (Bible study group) who were amazed how it would litterally stop in the headwind that was blowing out of the southwest. I do think I need a tiny bit more weight though & may try a little larger sinker.
I think that my problem stemmed from the fact that I went to a split Lith configuration, so I have one long battery & less of the battery weight is in the nose. The Moth is a great little airplane, I'm overdosing on Loops since my Beloved Litestick won't do them.
Anybody - Please finish this sentence "If you love the Tiger Moth, you'll love the ______" (I need a new project)
-Thanks-
Old Jul 07, 2002, 11:34 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Standard CG is 35-45 mm from the front edge of the lower wing. Get a pencil and draw it right on the wing so you can check it at the field if you need to. I've got mine set back at the 45 mm mark and it loops quite easily on the stock A drive. I've got li-ons in a side-by-side configuration and they have to be centered over the LE of the lower wing to balance. That's pretty far back, I would think you could still achieve CG without adding weight even though your batteries are end-to-end.
Tres Wright is offline Find More Posts by Tres Wright
Old Jul 07, 2002, 11:44 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Mike, I agree with Tres, my side by side Li's balance when centered over the LE too. Seems like to get the same yours should have one in the battery compartment and one over the wing?
Have you cut out the front of the battery compartment to try sliding them forward farther?
"If you love the Tiger Moth, you'll love the Mountain Models Cessna 180"
BC
Basketcase is offline Find More Posts by Basketcase
Old Jul 07, 2002, 01:10 PM
mrebman is offline
Joined Nov 2000
Basketcase:
Thanks, No I have not tried to carve out any foam forward of the Battery compartment. Actually, I went to a permanent Split-Lith configuration so that I specifically would not have to do any carving. The fishing weight idea seems to work & I only need about 3-4 Grams to get the job done. Come to think of it, I may try sliding the battery a little forward or I will have to find somewhere to stash the lead & 3 Grams ain't much to make up.
-Mike-
Need Help With Tiger Moth Flight Mr Zig Parkflyers 19 Sep 25, 2002 02:09 AM
Help with Tiger moth CG j.Rendon Parkflyers 2 Aug 22, 2002 10:30 PM
GWS Tiger Moth CG correction with bigger motor Gene Bond Parkflyers 10 Aug 05, 2002 03:32 AM
Need Tiger Moth CG Help 300 mah bat. Sheptack Foamies (Kits) 5 Jul 11, 2002 06:54 AM
CG experiments with Tiger Moth. mrebman Parkflyers 1 Sep 09, 2001 05:09 PM
