Old Apr 11, 2006, 09:00 AM
Jim T. Graham is online now
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
NEW E-flite J-3 Cub 25 ARF PLUS 25-Size Fiberglass ARF Floats
http://www.horizonhobby.com/Products...ProdID=EFL4000
http://www.horizonhobby.com/Products...ProdID=EFLA500
Aimed at the scale electric enthusiast, the new J-3 Cub 25 ARF (EFL4000) from E-flite is at the top of its class for scale appearance and performance. It’s also the only 25-size Cub with scale aile*rons. Quality balsa and light ply construction make for a sturdy, lightweight airframe that handles incredibly well in most any flying situation. The firewall is set up for use with an outrunner motor, such as E-flite’s Power 25, making a perfect power match for the airframe. Optional 25-Size Fiberglass ARF Floats (EFLA500) add a new dimension to the scale flying experience, and the one-piece wing allows for easy trans*portation to and from virtually any flying field, lake or pond.
J-3 Cub Features
- Sturdy ARF airframe for fast transition to the flying field
- Factory-mounted wheels with authentic Cub wheel caps
- Built-in float mounts
- Outrunner-ready firewall—perfect match for E-flite’s Power 25 Outrunner, 870Kv
- Factory-painted fiberglass cowl with molded engine detail
- Flies great with Li-Po (THP42003S2PPL- http://www.horizonhobby.com/Products...=THP42003S2PPL)
or Ni-MH (EFLB4010) packs
The E-flite quick-mount floats are designed specifically for 25-size
planes that are float-ready out of the box, so you can go from pavement to pond in just minutes. They're expertly constructed from top-quality fiberglass and painted with a fuel-proof silver finish. They come equipped with a quick connecting rudder assembly to hook it up directly to the rudder control horn. All installation hardware is included.
- 25-Size Fiberglass ARF Floats Features
- Quick connecting water rudder assembly
- Pre-bent and assembled wire struts
- Great add-on sale for the E-flite J3 Cub
Jim T. Graham is online now Find More Posts by Jim T. Graham
Administrator
Wanted NIB E-Flite J-3 Cub 25 ARF BD Flyer Aircraft - Electric - Airplanes (FS/W) 0 May 14, 2007 01:54 PM
Wanted E-flite J-3 Cub 25 ARF smurf Aircraft - Electric - Airplanes (FS/W) 3 Mar 02, 2007 07:38 PM
Sold NIB E-Flite J-3 Cub 25 ARF ClipperBill Aircraft - Electric - Airplanes (FS/W) 4 Dec 31, 2006 03:15 PM
Sold E-Flite J-3 Cub 25 Arf "SOLD" Pending Funds Yardbee Aircraft - Electric - Airplanes (FS/W) 3 Oct 06, 2006 11:35 AM
Wanted Wanted E-Flite J-3 Cub 25 ARF smileyz Aircraft - Electric - Airplanes (FS/W) 0 Sep 18, 2006 04:12 PM
