Old Apr 10, 2006, 07:55 PM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Question
Want To Shorten My Servo Wires, Whats The Best Way?!?
Hi all,
Got a few servo wires, as well as the 'servo' wire for my ESC that I wana shorten, just looking for the best way to do it...
Firstly, its OK to shorten these wires isnt it? Brushed and BL ESC...
Now, Im thinking, just cut a piece out of the middle area of the wire, to shorten it. Then just solder the 3 wires together, idividually heatshrink them, then put a piece of larger heatskrink round the 3 wires to keep them together.
Does that sound like a good plan, or are there any other better ways?
I dont ahve any special crimping tools e.t.c., just the normal wire cutters, strippers, solderin iron e.t.c.
Thanks in advance,
Duane
Minimole is offline Find More Posts by Minimole
Old Apr 10, 2006, 08:53 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
That's all I know of Duane. Just make sure you get the polarity right...
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Apr 10, 2006, 09:52 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Don't Cut Servo Wires.
You may want them longer when you reuse them in another plane. Find a way to wrap them up and tape them to keep them neat.The extra wire doesn't weigh much.
E-Challenged is offline Find More Posts by E-Challenged
Old Apr 10, 2006, 11:08 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
If you are doing this to save weight, don't, you won't unless you remove a lot of wire.
I would do as you mentioned until the three wires are soldered/shrunk. Then add some hot glue over the area on both sides keeping it thin. It won't take much heat glue to satisfy your eyes.
rampman is online now Find More Posts by rampman
Old Apr 10, 2006, 11:37 PM
freddy warbird is offline
Find More Posts by freddy warbird
Keep 'em Flying
freddy warbird's Avatar
California
Joined Feb 2005
If your going to do it, do it right!
http://www.maxxprod.com/mpi/mpi-4.html
freddy warbird is offline Find More Posts by freddy warbird
Old Apr 11, 2006, 05:18 AM
willhicks is offline
Find More Posts by willhicks
Dealer
Hendersonville, NC
Joined May 2004
You can open up the the servo and desolder and resolder the shortened lead to the circuit board.
Be sure to tin the wires and reconnect the wire the same way it came off.
Will
willhicks is offline Find More Posts by willhicks
Old Apr 13, 2006, 10:30 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
Easiest way is to loop them shorter and use some Zip-Ties.
I ONLY cut when there is not enough room and I have never had this problem in an aircraft.
Popsflyer is offline Find More Posts by Popsflyer
Old Apr 13, 2006, 10:43 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Loop and tie.
There's other planes in the future that will need the full length..
Sparky Paul is offline Find More Posts by Sparky Paul
Help! Increasing Performance Of My Heli, Whats The Best Way...?! Minimole Mini Helis 7 Apr 26, 2006 03:45 AM
Whats the best way to use a Servo to trigger Mini 3 RandyK1 Aerial Photography 2 Nov 21, 2003 05:43 AM
Whats the best way to connect pushrod to servo arm? BryanHarstad Micro Helis 1 Feb 18, 2003 11:10 AM
aggg, whats the best way to connect 2 computers?? TheSpruceMoose Life, The Universe, and Politics 23 Aug 01, 2001 12:06 AM
want to buy a new battery charger, whats best? techroscope Beginner Training Area (Aircraft-Electric) 5 Jun 26, 2001 08:37 PM
