Old Jun 11, 2001, 01:47 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Cool
Yellow Aircraft F-18 Twin EDF
I was up in Reno yesterday for the SP400 pylon races there. I know your saying, what does this have to do with EFD. Well, I had the pleasure to meet Gordon Myers from the Reno area. He brought along a little something to tease our eyes. I'll let him explain as it's his project. He's doing a great job with much custom work inside to fit the fans and save weight. Great job Gordon!
I have A Yellow F18 single that is almost done with conversion to EDF. Right now the Yellow F18 single with 2 midi fans, Aveox 1412 2y's, 32 cells RTF wieght is 11.75 lbs. Conversion took some work, all new ducts and recut wood but the RTF weight seems very good. I am using Spring air #301 slimline retracts with out the scale struts which is pretty much what you would get from Yellow Aircraft.
GregG is offline Find More Posts by GregG
Old Jun 11, 2001, 02:01 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
Check the picture, Greg. Isn't showing up at the time that I write this.
I was planning to do the exact same project, but I was going to go with a lot more cells. I'm interested in hearing how this works out.
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Jun 11, 2001, 02:09 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
The picture is there, it's my ISP that is the trouble. They were just bought out by a larger company and the switchover makes things intermittant. Sorry to anyone that can't see it. I'll contact them (the ISP) but you know how that can be. All I can say for now is keep trying back, it will eventually work. If you'd like to see some more pictures, send me an email.
[This message has been edited by GregG (edited 06-11-2001).]
Old Jun 11, 2001, 02:34 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
That sure is a great looking project and I wish Gordon all success.
However, with a Kv of only 1450, the setup will draw around 20 - 23A per motor (assuming Gordon has 16 cells per motor), so he could be rather light on input watts.
IMHO I'd expect at least 20 cells per motor to be needed here, for 30+ amps.
Just my thoughts
Gordon
Gordon is offline Find More Posts by Gordon
Old Jun 11, 2001, 02:36 PM
flying_pig is offline
Find More Posts by flying_pig
crazy builder
flying_pig's Avatar
United States, CA, Santee
Joined May 2001
WOW now that is realy drool-worthy!!
lets hear more, I'm sure i'm not the only one here that would like to hear how it fly's
flying_pig is offline Find More Posts by flying_pig
Old Jun 11, 2001, 02:40 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Woha!! What can I say? Charge ahead!
Haldor is offline Find More Posts by Haldor
Old Jun 11, 2001, 02:43 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
The bold type in my 1st post was from an email he had sent me prior to our meeting face to face. He said yesterday he'll probably use 40 cells total, now that's what I call performance! I checked it out well and there isn't a whole lot of room for a battery pack in there. He may have to split the pack up into multiple packs. Perhaps we can get him to check in here and fill us in with some more info. Are you reading this Gordon, welcome to Ezone fame?
Old Jun 11, 2001, 03:01 PM
Plane Crazy is offline
Find More Posts by Plane Crazy
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
I originally was starting with 40 cells for this project with a RTF wieght of 12.70 lbs. The Yellow Aircraft F 18 flys very well in glow configuration at 13 pounds. Robert at EJF suggested starting with 16 cells per motor to play some games with wing loading. I think that 36 would be a better minimum for the weight versus Midi fan thrust. But 40 would definitely provide very good thrust.
Just to give you and idea on weights. The plane kit parts out of the YA box weighed 5 lbs. I am down to 3.87 lbs in my lightening excercise. Very promising.
I have been documenting this with pictures and tracings of the new wood parts and will create a PDF file for others that are interested.
Who says you can't carry large planes in an Audi TT?
Gordon Myers
Plane Crazy is offline Find More Posts by Plane Crazy
Old Jun 11, 2001, 04:27 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Gordon-
You know when I see this one fly I'm gonna be in trouble - 'cause I can't hide that big of a box from my wife for that long once I break down and get one!
Ed
Eddie P is offline Find More Posts by Eddie P
Old Jun 11, 2001, 05:38 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Should work great. I have the same power plant in my PFS F-86. On 16 cells I'm at 28,500 RPM per WeMoTec this is nearly 4 lbs of thrust. If the The plane stays less than 12 lbs. With 8 lbs of thrust it should be a great flier. Good Luck!
bruff is offline Find More Posts by bruff
Old Jun 11, 2001, 07:22 PM
PharmD2B is offline
Find More Posts by PharmD2B
NC
Joined Feb 2001
Hey Gordon,
I am getting 30 amps and 503 watts out of my 1412/2Y and 16 cell 2400's. I am flying a 6 pound Jetster and it flies great with plenty of power. 18 cells will put you close to the limit of these motors. I know that people are using 20 cells but I would not try it for a long term set-up. I have fried a few aveox motors in my time
Your project should do great considering that my Jetster is a very draggy airframe with fixed gear. I will be using this set-up in my Airworld ME262 that finally arrived. Awesome kit indeed!!!!!!
Good Luck!!!!!!
PharmD2B is offline Find More Posts by PharmD2B
Old Jun 12, 2001, 01:11 AM
Gordon is offline
Gordon's Avatar
Joined Aug 2000
Bruff and Pharm
I sure wouldn't want to argue with your measured currents and rpm
But ... 1450rpm/V X 1.2V/cell x 16 = 27840rpm
and that's off load.
Load up for 30A, and rpm will fall significantly.
I'm puzzled
Best regards
Gordon
Braunton, N Devon, England.
[This message has been edited by Gordon (edited 06-12-2001).]
Old Jun 12, 2001, 09:05 AM
Flying Welder Pilot
Reno, Nevada
Joined Jan 2001
FA-18 threads sure can get attention.
Things are moving fast. Retracts are installed, and all servos (5 Futaba 3002's, 2 3101's) and linkages are installed except for the rudders/ nose gear steering servo.
Almost ready to start glassing and painting.
I am still looking for a pair of ESC's good for up to 20 cells. Jeti's would have been neat to try but they only go up to 16 cells. Any suggestions??
Also looking for a pair of Aveox 1412 2Y's. These also seem to be in short supply.
Thanks for all the input, keep it coming
Gordon
Old Jun 12, 2001, 09:25 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Gordon, man you work fast! In regards to finding a pair of motors and controllers, have you tried <a href=http://www.angelfire.com/ut/gliders/ target=blank>CSR</a>? They seem to have the best prices I've seen. He always has goods for sale on Ebay and they seem to go for less than list price. Keep up the good work Gordon!<img src=http://www.flightlines.com/forum/icons/icon14.gif>
Old Jun 12, 2001, 10:17 AM
Flying Welder Pilot
Reno, Nevada
Joined Jan 2001
GregG- I'm not working that fast!! Alot of the things that I have completed were sitting on the work bench curing or I did not have the time to place them in the plane before I loaded the plane into the car to show you. I hate to say how many times I had to redesign something or recut a part thru this conversion process.
Gordon
F-18 Twin EDF conversion - microfans NO THRUST Help! dirtypool Electric Ducted Fan Jet Talk 50 Jan 16, 2006 10:02 PM
f-18 twin EDF-50 foamy 50ccRacer Electric Ducted Fan Jet Talk 28 Dec 20, 2005 08:53 AM
Re: Any Yellow Aircraft F-18 Twin owner here? X-spec Fuel Jet Talk 10 Mar 16, 2005 08:19 AM
FS Yellow Aircraft F-18 rc jet flyer Aircraft - Fuel - Airplanes (FS/W) 0 Oct 23, 2004 02:50 PM
Yellow AC F-4 twin KRose Electric Ducted Fan Jet Talk 10 Jun 26, 2001 08:47 PM
