Old Feb 06, 2007, 07:04 AM
equest is offline
Find More Posts by equest
Questio scientia
equest's Avatar
Texas
Joined Apr 2003
The Flings are covered in Monocote.
equest is offline Find More Posts by equest
Old Feb 14, 2007, 05:12 AM
byen00 is offline
Find More Posts by byen00
Joined Oct 2001
Originally Posted by Sparky Paul
One came into the LHS yesterday.. I thought, from the price, it was a kit..
as an ARF, the price is unbeatable!
Took it home, added a motor on a pylon... eFlite 400 outrunner, APC 9x4.7 prop, Electrifly C25 ESC, Kokam 3c910, 2 Cirrus CS2400BB servos. AUW 29 oz.
Not decided as to whether or not to epoxy the wing joiner in place.
Originally Posted by jcfetterly
Got my 2M Fling Monday, cut the nose off and installed a 2212-34 AXI with a 11x8 folder, Jeti 12, 2 Hitec 65HB servos and 2 cell 1800 battery. AUW 25 oz. First flight yesterday was great considering it was a bit gusty for a lightweight. AXI suggests a 12x8, I'll try that next for a better climb. I was impressed enough with the construction and handling that I'll buy another for Hi-start or gentle winch use. Great deal for $89.
SP: pod-mounted motor in a tractor configuration
JCFetterley: in line motor at the nose, foldable prop
What are the tradeoffs in the above 2 power configurations?
Wouldn't the JCF system w/foldable prop have less drag than SP (a feathered prop)?
I like the SP's system for an AP system (stick a camera in the nose). SP, can you comment on location & thrust-angle of your system?
I was originally thinking of the Multiplex Easy Glider for an AP platform, & putting an electric motor in a pod. Tractor or Pusher?
Would the Slinger 2M be a better glider than the Easy Glider in the sense that the wing is more rigid? (the Epalor foam wing on the Easy Glider flexes & bends)
byen00 is offline Find More Posts by byen00
Old Feb 14, 2007, 11:51 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
The pod mount is more agreeable to me for any potential changing the plane back to a TD unpowered version. Just split the wings remove the pod.
A nose mounted motor is kinda in there for good.
The pod thrust line is tilted up just a bit.. it tended to push towards the ground on hand-launching.
For AP, the camera must be small, and probably external, there's no room in the fuselage for much of anything.
On those planes I use the Aiptek 1.3M SD on a slide mount that fits under the wing at the fuselage..
Folding props are good. Somewhat impractical on a pod, if one blade can get hung up on the pod when folded. The motor then can't be restarted.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 03, 2007, 07:46 PM
Crowfly is online now
Find More Posts by Crowfly
Crowfly's Avatar
United States, MO, Belton
Battery question
I have joined the Fling club. I like the simplicity of it all
My first question (I am trying to make this a thermal trainer), what batteries are best for a fling with no motor? I know the batt needs to go in the nose, and there isn't much room. I know there has to be a simple answer to this AA batteries? Help please..... Fred
Crowfly is online now Find More Posts by Crowfly
Old Mar 03, 2007, 08:06 PM
Crowfly's Avatar
OOps
Sorry I just read this topic was covered on the previous page
.Fred
Old Mar 03, 2007, 11:58 PM
fredeich is offline
Find More Posts by fredeich
fredeich's Avatar
Fresno, Calif
Joined Aug 2005
I saw one of these on the slope today and could not believe the performance. It was built stock, but was really amazing considering the price. I just ordered mine tonight.
I just read this whole thread and will use some of the great mods posted. I really like keeping it two wings(no glue).
Fred
fredeich is offline Find More Posts by fredeich
Old Mar 04, 2007, 10:40 AM
nr5a is offline
Find More Posts by nr5a
Box Elder, SD
Joined May 2002
We have a couple of these in our area and they are all 2 piece wings. None of us glued the wings together. We put them together at the field and tape across the center joint. We hi-start them and slope them and have never had any problems with the wings.
CrashinJ
nr5a is offline Find More Posts by nr5a
Old Mar 04, 2007, 10:45 AM
nr5a is offline
Box Elder, SD
Joined May 2002
Has anyone added a power pod to one? how?
CrashinJ
Old Mar 04, 2007, 11:49 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
CrashinJ
Post #91
Old Mar 04, 2007, 10:54 PM
fredeich is offline
fredeich's Avatar
Fresno, Calif
Joined Aug 2005
Does anyone know the size of the rubber bands that hold the wing on? I have found numbr 62 and number 64.
Fred
Old Mar 05, 2007, 09:48 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I use #64, but double them - from the rear dowel to the front and then back to the rear. I also used yellow rubber bands - looks neat with them.
Ivan
ivanc is offline Find More Posts by ivanc
Old Mar 05, 2007, 03:19 PM
fredeich is offline
fredeich's Avatar
Fresno, Calif
Joined Aug 2005
Thanks Ivan. They are on order.
Fred
Old Mar 08, 2007, 02:06 PM
fredeich is offline
fredeich's Avatar
Fresno, Calif
Joined Aug 2005
I am going to keep mine in a 2 wing configeration. What do you do with the plywood support that is supposed to be glued at the trailing edge where the wings meet? Is it even needed?
Fred
Old Mar 08, 2007, 02:51 PM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
I put pieces of velcro on the wing halves and the trailing edge doubler. When assembling the wing, I join the wing halves, put the doubler and then tape the doubler and the wing halves together with packing tape. Never had a problem, including on the high start.
The doubler is there to prevent the rubber bands from crushing the TE of the wing.
Ed (aeajr), thank you for the ideas!
Ivan
Old Mar 08, 2007, 03:36 PM
fredeich is offline
fredeich's Avatar
Fresno, Calif
Joined Aug 2005
Thanks, much appreciated.
Fred
Discussion How much ballast for a fling 2m skewbe Thermal 1 May 24, 2009 05:26 PM
Discussion GreatPlanes Fling 2M wing on slowstick questions ki4aoa Aerial Photography 10 Jun 03, 2006 03:15 PM
Discussion fling 2m for second plane or? bgjames111 Sailplane Talk 5 May 19, 2006 07:09 AM
Discussion Great Planes Fling 2M, not sorry I bought it now. Jimmy James Thermal 24 Apr 14, 2006 02:25 PM
