My Fling 2M ended up at 21.7oz (616grams) AUW. I'm using an Electron 6 receiver sans case. I also had to add weight in the nose to balance it.
Ivan |
LI, New York, USA
Joined Mar 2003
Berg has a good reputation but I have never used one. I would point you to the Hitec receivers. I have had good luck with them.
Hitec Electron 6 would be my first recommendation. Small, light and very reliable. Neg Shift http://www2.towerhobbies.com/cgi-bin...&I=LXCXM8&P=ML Pos Shift http://www2.towerhobbies.com/cgi-bin...&I=LXCXM9&P=ML Hitec Micro 05S if you need to go low priced or are going for the lowest possible weight. It will adjust shift to your radio automatically http://www2.towerhobbies.com/cgi-bin...&I=LXGZT0&P=ML |
Everett, WA, USA
Joined Jun 2003
Sounds like it works as advertised. I actually have (2) of these in other gliders right now; a QFII and a Skeeter. Another cool thing is if you want to switch off your tx first, you can; the servos wont jitter all over the place and over-extend your control surfaces. |
Everett, WA, USA
Joined Jun 2003
Thanks I will check these out. |
Ivan |
| Thread Tools | |
| Discussion How much ballast for a fling 2m | skewbe | Thermal | 1 | May 24, 2009 05:26 PM |
| Discussion GreatPlanes Fling 2M wing on slowstick questions | ki4aoa | Aerial Photography | 10 | Jun 03, 2006 03:15 PM |
| Discussion fling 2m for second plane or? | bgjames111 | Sailplane Talk | 5 | May 19, 2006 07:09 AM |
| Discussion Great Planes Fling 2M, not sorry I bought it now. | Jimmy James | Thermal | 24 | Apr 14, 2006 02:25 PM |
