LI, New York, USA
Joined Mar 2003
No problem.
I put a layer of clear packing tape across the end rib and cut the opening out where the spar slides thorugh. I overlap it onto the top and bottom wing surfaces in the area where the rubber bands cross and where the "joiner tape" will stick. This helps the covering take the stress of taping and pulling the packing tape when I join the wings. I use 2" clear packing tape, typically a medium weight tape, to join the wings at the field. I insert the joiner piece then put the two wing halves together. Then I tape them together. I start it at the back of the wing, run it to the front, wrap around the leading edge then back to the rear of the wing. I have spoilers so I leave a gap where the wires come through. This makes the wing amazingly strong, and since the taped area is under the rubberbands or inside the fuselage, any minor wrinkles have no impact on the performance of the wing. Typically I pull the tape off at the end of the day. Sometimes this can detach some of the monokote, so I have to occasionally reseal it to the wing using the heat iron, when I get home. No big deal. Solid as a rock! I have broken this wing several times due to failed winch launches but have never had to replace the wing joiner as the tape has held. Maybe if I had not taped it, the wing would not have broken as the joiner could have given, but I find this the best compromise between the strength of a glued wing and a wing just held with the joiner. If I were a totally new flyer launching off a typical 2M hi-start maybe It would be best to not tape it so that the wing can give more on a bad landing. But I have always launched off a 3M+ very powerful hi-start, or a winch, so I want that wing strong. I don't want the halves shifting or separating on the launch or in flight, which is the reason some people glue the halves together. This works just as well, in my opinion and I can separate the halves at the end of the day for easy transport and storage. This is a Spirit Select, so the plane was all built and came in a box. I still keep the plane in that box for storage and transport. So convenient. Hope that helps.
My slope site has nice tall grass for landing, so it wasn't a problem other than just trying to get the plane to land - the slope lift was very strong. Mitch |
Another tailboom goes boom
I took some time this morning to tune up the fling 2m. Added nylon bolts for the wing hold down, did the jack/switch thing with a small hole for the charger or off-plug, ironed out all the wrinkles in the covering, and proceeded to beat the heck out of it.
It was flying beautifully, better than it has. Hovering above the trees, moving out when I told it, but I clipped a fence on the way back and it landed on its tail. No obvious harm, everything still looked straight. So up the upstart again, no problems, again I overstretch the return and manage a one wingtip landing, and I hear a crunchy sort of noise as the fuse flops onto the grass... Standard issue, empennage floppy, Last pushrod exit hole is in line with the failure. Oh well, I was wanting to weigh it down a bit anyway
Punta Gorda, FL
Joined Apr 2002
The tailboom carbon is great except for the holes in the carbon tube. That's a stupid design with holes that weaken it greatly. The smart design is to run the control plastic tubes outside the carbon tube tail boom. Also, the tail mounts with stupid metal threaded rods thru carbon holes. The smart design is to glue the tail to the carbon boom. Good design could save weight and increase strength.
This has been talked about in a previous thread. http://www.rcgroups.com/forums/showt...t=504359&pp=15 Like Ollie said. Run the pushrod tubes on the outside of the boom and glue the tail on, instead of screwing it on. Wrap the boom with carbon tow to reinforce the pushrod exit holes. |
Joined Jul 2005
I'm glad I never bought a Fling DLG from the reports I have heard but you owe it to yourself to invest $65 for a Fling and try it out before you write off GP. |
| Thread Tools | |
| Discussion How much ballast for a fling 2m | skewbe | Thermal | 1 | May 24, 2009 05:26 PM |
| Discussion GreatPlanes Fling 2M wing on slowstick questions | ki4aoa | Aerial Photography | 10 | Jun 03, 2006 03:15 PM |
| Discussion fling 2m for second plane or? | bgjames111 | Sailplane Talk | 5 | May 19, 2006 07:09 AM |
| Discussion Great Planes Fling 2M, not sorry I bought it now. | Jimmy James | Thermal | 24 | Apr 14, 2006 02:25 PM |
