Old Feb 09, 2013, 04:23 PM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
As I mentioned a couple of posts ago, I am underwelmed with the quality of the wing. Not only was the covering abysmally bad, several ribs were not glued to the TE.
But these were minor hickups as I knew I was going to recover. One thing I didnot verify (as this was an ARF after all) was the fit of the two wing halves. I expected to maybe have to do a bit of sanding to get a good fit, so I left this for last.
So imagine my surprise when I trial fitted the winghalves. One root is 5mm longer then the other! Measuring further towards the tip, the differences are less, and by the dihedral break they're equal.
How will it fly?
Up&Away is offline Find More Posts by Up&Away
Old Feb 09, 2013, 06:22 PM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Yikes, in country I haven't seen so bad quality control on 2M Flings.
Check the warping too.
Ricardo RW is offline Find More Posts by Ricardo RW
Old Feb 09, 2013, 10:20 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
There was a very slight warp, which I treated with some heat from my covering iron. I'll have to keep an eye on it though
Old Feb 10, 2013, 03:38 AM
Ricardo RW's Avatar
Joined Jun 2002
I suggest you to use -2° to -4° washout at the tips. I use a very simple device to check warping an doing washouts, I'll send you a picture later if you want.
Regards.
Old Feb 10, 2013, 05:16 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Regards.
Always willing to learn... I use bamboo BBQ skewers taped to the wing's bottom...
Old Feb 10, 2013, 08:37 AM
Crowfly is offline
Find More Posts by Crowfly
Crowfly's Avatar
United States, MO, Belton
My wings came out the same where they went together. It is at least 5 years old,but it rarely gets flown. If i ever got ambitious and put a motor,or power pod on it it would get flown a lot more often.
Fred
Crowfly is offline Find More Posts by Crowfly
Old Feb 21, 2013, 01:44 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
How does 570g AUW sound?
Old Feb 21, 2013, 01:48 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Sounds like about 20 ounces which is a very nice number.
aeajr is offline Find More Posts by aeajr
Old Feb 21, 2013, 03:16 PM
Ricardo RW's Avatar
Joined Jun 2002
That's pretty nice. In my country we use to fly 2m contests with Flings and the minimum weight is 650g.
It should fly very well.
Old Feb 21, 2013, 04:13 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
I hope to do at least some trim/glide tests tomorrow. Depends on the wind.
Old Feb 24, 2013, 01:30 AM
Alex VK2KR is online now
Find More Posts by Alex VK2KR
Albion Park Rail Aus
Joined Nov 2009
Wing Joiner
Help
Anybody have the joiner for the 2 piece wing that can scan
and send it?
At a local comp, the winch driver got exuberant and the wings
now have a "bit" more dihedral, I have aluminium and ply to
fabricate a new one but need the angle of the original joiner
Alex
Alex VK2KR is online now Find More Posts by Alex VK2KR
Old Feb 24, 2013, 01:47 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Originally Posted by Alex VK2KR View Post
Help
and send it?
Alex
I'll measure tonight...
Old Feb 24, 2013, 04:50 AM
Joined Nov 2009
Originally Posted by up&away View Post
i'll measure tonight...
תודה
אַ דאַנק
Old Feb 24, 2013, 12:29 PM
R2R is offline
R2R
Find More Posts by R2R
R2R
R2R's Avatar
United States, FL, St Johns
Joined Nov 2009
Darn -- I just cleaned out my garage last weekend and threw out the old joiner for that wing.
R2R is offline Find More Posts by R2R
Old Feb 24, 2013, 02:29 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
8.5mm thick
7.5mm wide
measured at the underside, from tip to center 13.4mm
also measured at the underside, with one side flat on the table, the underside of the other side is 23mm high
Discussion How much ballast for a fling 2m skewbe Thermal 1 May 24, 2009 05:26 PM
Discussion GreatPlanes Fling 2M wing on slowstick questions ki4aoa Aerial Photography 10 Jun 03, 2006 03:15 PM
Discussion fling 2m for second plane or? bgjames111 Sailplane Talk 5 May 19, 2006 07:09 AM
Discussion Great Planes Fling 2M, not sorry I bought it now. Jimmy James Thermal 24 Apr 14, 2006 02:25 PM
