Old Jul 05, 2002, 01:30 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
GWS Pinion Gear Pullers at Balsa Products
Finally both sizes of Gear pullers ar in! Micro and standard and at a great price. www.balsapr.com. check them out!
Pete
peterv is offline Find More Posts by peterv
Old Jul 05, 2002, 05:15 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Just ordered mine, both sets. $21 for two pullers and that takes care of all my motors. Such a deal!
Pete
Old Jul 05, 2002, 06:33 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Just what I've been waiting for to get some of my motor projects kick-started. Balsa Products, here I come.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Jul 05, 2002, 06:44 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Ordered mine this morning!!
boomer
boomerace is offline Find More Posts by boomerace
Old Jul 05, 2002, 08:52 PM
Joined Feb 2000
Now that my gear puller order is in, I'm wondering if anyone makes a gear presser -- that is, a small tool for pressing gears on. I have several methods in mind without a special tool. Does anyone have a favorite proven method?
Old Jul 05, 2002, 10:00 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
I use a block of metal on the back shaft and a small hammer to tap the gear on. However I have thought of using a C-Clamp. But the hammer works fine. Took two off this holiday( put the wrong gear on twice!) with a fork. Slide the shaft between the center tines, lay it across the open jaws of a vice and tap the shaft out with a small center punch. Crude but works.
Pete
Old Jul 06, 2002, 10:31 AM
Joined Feb 2000
The c-clamp is one of the things that I was considering. Was also thinking of walking through a tool store just to see if there were any other standard tools that might double as a gear presser.
Old Jul 06, 2002, 06:12 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
I put the motor in a vice, longwise of course, with a metal ruler against the back of the motor (the vice is wood) and line the pinion gear up with the shaft, and close the vice slowly. The pinion slides right on every time. The wood protects the brass pinion from damage, and the ruler adds support to keep the back end of the motor from pushing apart.
marcus
MKH is offline Find More Posts by MKH
Old Jul 06, 2002, 08:10 PM
electricrcflyer is offline
Find More Posts by electricrcflyer
Corvallis, OR
Joined Mar 2000
Finally...a reasonably priced PG puller. Don't understand why
these cost over $30 in the first place.
Ron
electricrcflyer is offline Find More Posts by electricrcflyer
Old Jul 06, 2002, 09:20 PM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
GWS Fair Prices
Right! Leave it to Mr Lin and GWS to come up with something we all need at a fair price. Good going GWS! I'm sure you will sell many.
Pete
Old Jul 06, 2002, 11:55 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Why Do I Need a Puller
All of the GWS replacement motors come with proper pinions installed for the particular gearbox ratio ( dont they?). If so why would I need to remove and replace pinions for GWS geardrives?
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 07, 2002, 12:05 AM
boomerace's Avatar
Joined Sep 2001
Re: Why Do I Need a Puller
First of all I have 4 diff. gearboxes in use. The replacement motors I have found so far are all with the A pinion. If you buy the motor without pinion it has no wires or capacitors. So it makes sense to be able to keep a couple of A spare motors on hand that I can remove and switch pinions as necessary. Further I intend to try the EDF motor in several diff. gear boxes. Also if a motor from one of my 300C or 100C series would burn out I can do the same as I use several diff. gear ratios there also.
boomer
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Yes GWS replacement motors do but most of my motors a Graupner and Mig using MP Jet GBs, the pinion gear comes with the gearbox and must ber pressed on at time of assembly. Then when you want to change GB ratios or replace a worn motor you have to pull the gear. Sure helps to have the right tool!!
Pete
Old Jul 07, 2002, 08:20 AM
Joined Feb 2000
My GWS gear puller projects include pulling gears off of IPS motors to put on EDF motors for use in IPS gearboxes, and pulling gears off of 280 motors to put on Johnson 250 motors to use in 280 gearboxes. Think of it as combining two hobbies into one -- e-flight and hot rodding.
Old Jul 10, 2002, 11:23 AM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Got My GWS Pinion Gear Pullers!
Got the pinion gear pullers from Balsa Products www.balasapr.com today(fast!) and they look great! Come in a nice receiver plastic box with fitted foam insert. Very well made. Looks like a great tool. Now to see if there are any motors in my truck to pull, can't wait to try them!!
Pete
GWS Pinion Gear Puller Help Needed bmizes Parkflyers 7 May 08, 2003 06:54 PM
New Lithium Battery at Balsa Products ggunners Foamies (Kits) 3 Jul 31, 2002 11:53 PM
10 tooth/48 pitch pinion gear, where at ? William A Sport Planes 7 Sep 28, 2001 12:52 PM
Whick flight pack..tha GWS, or the one at balsa products. ramw5p Parkflyers 5 Aug 06, 2001 08:16 PM
Removing the GWS Pinion gear Der Zip Power Systems 5 Jun 05, 2001 04:48 AM
