Joined Apr 2006
Spektrum DX-6's receiver, failsafe, and robot receiver option
OK, relative newbie here, so this may be a dumb question or already covered.
The DX-6's standard airbourne receiver (AR6000) has a failsafe mode that puts only the throttle into a programmable setting and keeps all other channels at their last commanded positions. This is good, but has some potential drawbacks. Spektrum also markets another receiver that is identical in every way, except it allows you to program the failsafe settings for ALL channels. It is the same price and can be purchased in a bundle with a TX at the same price. Model number is BR6000 and it is marketed to RC combat robot users. The added failsafe programmability is needed to shut down robot weapon systems. Range should be the same because it is just a firmware change on the AR6000 hardware as I understand it. http://www.spektrumrc.com/Products/D...odID=SPM6000BR It seems to me that having a programmable setting for failsafe on ALL channels is a big advantage for aviation because it would eliminate the problem, for example, that the aileron channel was off center at the moment the signal was lost and therefore that the airplane would quickly enter a spiral dive. It would also give you a chance to program a circling pattern or maybe even do something like drop flaps to reduce crash impact speed. So wouldn't this robot receiver be the hands-down better choice for rc aviation? Are people using them? Why wouldn't the AR6000 be made this way? |
southbay ca
Joined Nov 2005
That is correct. It is idential in performance to the AR6000. Only the failsafe is different. Paul Spektrum Team |
St. Pete, FL
Joined Feb 2006
Apparently, Horizon will exchange DX6 owners' AR6000 receivers for the BR6000 if you send your AR6000 to them. See article on DX6, "New Spektrum BR6000 Bot Receiver" at http://www.spektrumrc.com/Articles/HobbyWire.aspx.
--Van |
In short, there is nothing keeping you from using the BR version in a plane. Were I to use the DX6 for anything I would only use this Rx. |
| Thread Tools | |
| Sold Spektrum DX 6 transmitter w/receiver | bruff | Aircraft - General - Radio Equipment (FS/W) | 2 | Jan 11, 2007 01:43 PM |
| Sold Spektrum DX 6 Transmitter and Receiver w/ True RC 2000mA Lipo for RX | Bnova | Aircraft - General - Radio Equipment (FS/W) | 1 | Dec 26, 2006 07:31 PM |
| Sold Spetkrum DX 6 channel receiver | bruff | Aircraft - General - Radio Equipment (FS/W) | 2 | Aug 21, 2006 09:54 PM |
| Discussion Spektrum DX-6 Chief Engineer Jon Adams at the AMA Convention 2006 | Thomas B | Radios | 78 | Jan 25, 2006 08:28 AM |
| Discussion Rx now available for the Spektrum DX-6 | no stick | Radios | 1 | Jan 17, 2006 10:38 PM |
