Old Jul 05, 2002, 08:20 AM
Clydewinder is offline
Find More Posts by Clydewinder
Tiger Moth World Tour
Clydewinder's Avatar
New Berlin, WI USA
Joined Jan 2001
Sureflite 1/2a Cessna Conversion
First flight went very smoothly yesterday of the Sureflite 1/2a Cessna meant for cox motors.
www.sureflite.com
I used:
MFA rocket 400 w 3/1 gearbox 9x7 apc e-prop
Radio Shack 1600 nimh
Aveox ESC 14a from my Zagi
4 servos ( elevator, rudder, and 2 for the ailerons/flaperons )
Standard airtronics receiver
AUW unknown at this point, estimated 24 oz.
The mods I did to the airframe were few: wing fibreglassed and mounted to the fuse 2-dowel style with rubber bands. I didn't use the stock firewall, i just drilled a hole through the foam for the motor to stick through then used balsa 1/4 x 1/2 stock to make an upside down U shape around the hole, then RTV siliconed the motor/gearbox assy to the balsa. Very easy installation and it fits under the cowl too! The fuselage was just sanded, and the tail pieces were monokoted ( they are balsa, not foam ) I also used oversized foam wheels for the crappy overgrown field i fly at.
How does it fly? Very nicely! Climbs out like nobody's business. The rudder authority is amazing. The ailerons are a bit weak, i'm going to lengthen them out a bit. I have not had a chance to fly with the flaps on yet, but it should be fun.
Yes I know 4 servos is pushing my luck on a Zagi ESC but I'm going for minimal cost here. The kit was 35 bucks, 6 bucks for the motor, 20 for the MPI gearbox, then add the cost of servos and battery and this is a nice little unit.
I'll try to add some pictures when I can, I don't have a digital camera so I have to wait for the film.
This setup flies as well as the glow version does on a 1/2a motor and with a much longer duration. The rocket400/ gearbox combo flies this plane at 1/2 throttle or less without the cheap batteries even getting warm. I also plan to try the Zagi X pack in there (1700AU) which I expect will have a little more punch but as it is it flies very scale.
Clydewinder is offline Find More Posts by Clydewinder
Old Jul 07, 2002, 03:17 PM
New Berlin, WI USA
Joined Jan 2001
2nd test flight today
flew cessna again today, this time with ailerons wing-length and rudder mixed with ailerons, much better. Easy to fly, very smooth and hands-off recovery. Next I will try 7x600AE cells as they are lighter and probably have as much punch as the RS1600NIMH.
Carl Goldberg 1/2A Cessna Skylane Gonnacrash Aircraft - Fuel - Airplanes (FS/W) 2 Jun 01, 2005 07:26 PM
Idea Carl Goldberg 1/2A Cessna Skylane Gonnacrash Vintage & Old-Timer Designs 0 May 30, 2005 07:49 PM
Sure Flite 1/2A Cessna NIB RB Aircraft - Electric - Airplanes (FS/W) 0 Sep 01, 2004 06:18 PM
FS: House of Balsa 1/2A Chipmunk Conversion. genovia Aircraft - Electric - Airplanes (FS/W) 12 Mar 01, 2003 09:05 PM
Converting a Sureflite 1/2a Cub to electric ARCHER7153 Foamies (Kits) 2 May 21, 2001 12:05 AM
