Old Jul 04, 2002, 07:30 PM
genovia is offline
Find More Posts by genovia
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
Hobby Lobby's Super Cub wing problem
Hello all, and specially greetings to those who have build and flown the Super Cub.
I am in the process of building a HL Super Cub and read threads concerning it's death in flight, due to it's wings problem, due to it's weak structures (?) and strength.
After reading the Paul Balint's website, that got me doing and following it's modification's (Thanks Paul) but there was no comment and the modification's made, but the website has been a guide to me.
http://paulsplanes.fws1.com/supercub.htm
I have not touch the wings, waiting for every all other things to finish and get back to it. I have a couple ideas of my own, but hold it off, for the fear of putting weight to it, that would enable the Super Cub of it's authoritarian flight.
I am near finishing the Cub. two more hours, I am done
Here is my progress
Fuse rudder/elev. finish
genovia is offline Find More Posts by genovia
Old Jul 04, 2002, 07:32 PM
genovia is offline
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
Now this is my main concern, and where I left off, until I can get some good advice on what to do.
The wings.
1) What to improve?
2) What to use?
3) where to put it?
4) What to look out for?
Old Jul 05, 2002, 09:31 AM
KevinM is offline
Find More Posts by KevinM
Pro Bro # 179
KevinM's Avatar
United States, TX, Little Elm
Joined Jan 2002
If they are weak, you might try some carbon fiber sparing.
just an idea
KevinM
KevinM is offline Find More Posts by KevinM
Old Jul 05, 2002, 11:18 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Its the center ply joiner where the trouble was.
the wing fails at the end of the joiner
Rest of wing is fine.
I repaired mine and made a hard ply center joiner that extends out to the second rib from the fuselage on each side.
I also made the struts functional by adding wire ends that screw to ply plates in the wing and fuselage.
No more problems.
easy to do when wing is not yet covered.
DaveW
DaveW is offline Find More Posts by DaveW
Old Jul 05, 2002, 11:25 PM
genovia is offline
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
***I repaired mine and made a hard ply center joiner that extends out to the second rib from the fuselage on each side. ***
Dave,
By adding scrap balsa, do you think that by gluing it to the dihedral braces and the center joiner, not extending the ply, but adding a ply on top or bottom of the other would do the trick?
On the side where screws are located change the balsa piece same measurement but stronger.
What do you think?
Old Jul 06, 2002, 06:13 AM
Airnut 2 is offline
Find More Posts by Airnut 2
Innisfil, Ontario, Canada.
Joined Dec 2000
Hi Genovia
Wing struts(functional) and a little more wing joiner bracing will fix
the wing folding problem. There is another week spot inherent with most high wing models, the vertical supports on the fuselage at the leading edge of the wing. To add some strength to them, add another vertical to the inside of each from the top to the bottom of the fuselage.Use Spruce instead of Balsa.
Airnut 2 is offline Find More Posts by Airnut 2
Old Jul 06, 2002, 10:53 AM
genovia is offline
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
I'll see to it, thanks AIRNUT 2
Old Jul 08, 2002, 09:44 AM
MK is online now
MK
Find More Posts by MK
MK
NJ
Joined Feb 2001
Is that lightening hole necessary in the rudder? I know on the plan, it said 'optional'. Also, what did you do to make that? Just some wide wood drill bits?
MK is online now Find More Posts by MK
Old Jul 08, 2002, 10:01 AM
genovia is offline
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
***Is that lightening hole necessary in the rudder? I know on the plan, it said 'optional'. Also, what did you do to make that? Just some wide wood drill bits?***
Optional to the sense that balance (CG) has to be perfect, and the weight, I've managed to beefed up the fuselage, specially the bottom. and the firewall. I was looking ahead of how it will balance.
I used a pipe, and sharpened the round tip of it, twisted it through the balsa wood, and you have yourself a hole. Though it requires sharpening after every so often, but does the job nicely.
Article Hobby Lobby's Super Dimona Powered Glider ARF Review kevin Electric Sailplanes 176 Oct 25, 2014 08:20 AM
Sold Hobby Lobby's Low Wing Skimmer 400 kit stevesu Aircraft - Electric - Airplanes (FS/W) 2 Jan 09, 2007 08:35 PM
Discussion Hobby-Lobby's Northrop N9M EPP Flying Wing FlattyFlier Flying Wings 9 Nov 18, 2006 10:10 AM
HOBBY LOBBY's SUPER MISS 2 SCOTT LINDSAY Parkflyers 63 Sep 11, 2002 08:50 PM
HL Super Cub wing folded in flight! Paul Electric Plane Talk 27 Jul 06, 2002 03:38 PM
