Old Apr 02, 2006, 04:33 PM
_Pattern_Man is offline
Find More Posts by _Pattern_Man
Fly it like you own it.
_Pattern_Man's Avatar
Canada
Joined Feb 2006
Question
Covering a foam plane? Glass it, iron-on, homebrew, silk??
I'm resurrecting my A-10 warthog ( http://www.rcgroups.com/forums/showthread.php?t=499873 ) with brushless and retracts. Even with CF rods and ribbon for reinforcement, I still want a stronger feel to it and better looks.
I wanted to cover the plane in CoverLite because it is strong and light. but the Coverite glue you apply to the balsa before applying the covering, eats foam like it's going out of style. So much for that idea.
So I was going to just use my tried and true method of 1 part Acrylic primer, 1 part white glue, 1 part water and 1 part Microbeads to fill the imperfections and leave me a nice smooth finish to paint. But this isn't going to add any strength.
I'm real hung up on some sort of covering. I've heard a few people mention covering a foam plane in tissue paper with 50/50 white glue/water as a sort of "Poor man's fiberglass".
Does anyone have a method of doing this? Does it add considerable strength for the amount of weight it adds?
Any other ideas?
I've used monokote on large balsa planes but I would imagine the high temperatures and shrinkage would wreck the plane. Is there other "foam safe" iron-on coverings that don't shrink as much and are lower heat?
Thanks alot.
_Pattern_Man is offline Find More Posts by _Pattern_Man
Old Apr 02, 2006, 05:53 PM
mike3976 is online now
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
http://www.rcgroups.com/forums/showthread.php?t=491417
This thread is in parkflyers. Solarfilm is hard to beat for covering foam
mike3976 is online now Find More Posts by mike3976
Old Apr 02, 2006, 05:58 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
try "silkspan" with your Acrylic primer formula. Silkspan is the tissue used for the old tissue and dopw finished Control line models. It comes in 3 weights, and possibly the light, more likely the medium would be what you want. I'm sure heavy would be too much.
Silkspan adds a lot of strength when doped onto balsa. It should do well for your purpose.
I have used silk cloth for a similar project, but it came out heavy. Might want to use it in high stress areas (or double layer the silkspan)
Silk plus yellow glue makes a lighter dihedral joint reinforcement than 2 oz fiberglass and epoxy. Silk is appx 10 times as strong as steel oz for oz. Fiberglass is not quite as strong as silk.
Epoxy doesn't really add as much strength as some people think... its ability to make up for less than perfect joints is where it shines. Just about any glue is stronger than the foam, balsa, spruce or plywood used in the models.
For a .40 size white styro wing I have used grocery bag paper and a mix of yellow glue and water then "primed with water based poly paint... stiff as if I'd used 2 oz fiberglass and epoxy but lighter. (probably not as strong as fiberglassing, but more than adequate for the airplane)
There's also "Towerkote" and Econokote... relatively light and low temp versions of Monokote. But I've never tried to apply them to GWS's foam. I tend to think the GWS foam wouldn't take as much heat as the white styro I've used them on. The temp for good shrinkage of these is getting close to the temp that causes white (beer cooler) styro to deform.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Apr 02, 2006, 09:11 PM
Dr_DOM is offline
Find More Posts by Dr_DOM
Dr_DOM's Avatar
Whitby, Ontario, Canada
Joined Aug 2004
If you want to reinforce and strengthen GWS foam, I would highly recommend going the fibreglass route. This thread:
http://www.rcgroups.com/forums/showt...hreadid=189838 or http://www.rcgroups.com/forums/showt...x&pagenumber=1
is a good place to start.
I would suggest 0.75oz glass cloth, sealed with water based polyurethane, (not epoxy) for the A-10. A number of coats of the polyurethane would give a very strong surface.
Given the amount of work you will be doing on the A-10, using “real” fiberglass would not be out of line.
Good luck.
Dr_DOM is offline Find More Posts by Dr_DOM
Old Apr 02, 2006, 09:32 PM
starcad is online now
Find More Posts by starcad
AMA 667982 KG7NKY
starcad's Avatar
United States, AZ, Tucson
Joined Sep 2000
I'm just finishing up my F-106 projuect and glassed it with 0.75 oz cloth and WBPU. Added 1oz to the total weight of the model. Now if I can only figure out how to airbrush again after 20 years I should come out with an airplane weighing in at around 23 oz.
Look up the finishing techniques by J Morgan, John goes into great detail on how to finish a foam model, an execlent thread.
starcad is online now Find More Posts by starcad
Old Apr 03, 2006, 07:30 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Do an AltaVista translation of this site. Look under Tips and Tricks
http://home.arcor.de/sirdidi/
hoppy is offline Find More Posts by hoppy
Old Dec 21, 2006, 04:37 PM
sammy is offline
Find More Posts by sammy
senior member
sammy's Avatar
United States, SC, Okatie
Joined Jan 2002
silk and glue plus gesso for foam covering
I have just covered a Formosa II with light silk- one yard from fabric store does 2 F-II's; used aliphatic glue (furniture, Elmers, etc.) thinned with water.
Silk is much lighter than firerglass, some say stronger. Enough silk for plane weighed less than 1/2 oz. Silk can conform around 3-D shapes.After sanding and spackling, Hold silk against foam, brush on thinned glue. Takes a little fussing to keep the silk down until dry. Heat gun helps a lot. Overlap pieces of silk. After covering, spackle any rough places. Then brush on artists acrylic gesso- from art/craft store- dries fast, sands well. First coat fills, second coat covers. Gesso is pure white. After getting a good surface on gesso, add trim paint, camo, etc. Then spray model with clear acrylic spray can, matte or gloss.
Silk and glue makes foam parts amazingly stiff and strong- no carbon fibre is needed to stiffen wing, etc.! Weight added is minimal- few ounces. Plane can look as good as moulded fiberglass, depending on how much work you are willing to do.
sammy is offline Find More Posts by sammy
Old Dec 22, 2006, 09:16 AM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
I have used slikspan and minwax polycrylic with very good results on foamies. You can get a glass smooth finish if you want. I found it helpful to seal PS type foam with polycrylic and lightweight spackle before you add the first coat with the silkspan. It keeps the foam from sucking up the polycrylic and keeps the weight down.
ImaBiggles is offline Find More Posts by ImaBiggles
Discussion Glass+Wbu or oracover on depron/foam plane? Niggo Foamies (Kits) 2 Apr 23, 2006 03:42 AM
Iron on covering weights JimF Electric Ducted Fan Jet Talk 2 Mar 25, 2002 08:35 AM
GOT a Wedgie now whats THE BEST & lightest iron on covering for EPS FOAM rcracerx Foamies (Kits) 5 Feb 10, 2002 10:07 PM
Light Iron-on Covering pgleesonuk Sport Planes 19 Dec 24, 2001 04:40 AM
Iron on covering for slow flight RCFlybry Parkflyers 3 Dec 07, 2001 01:25 PM
