Old Apr 02, 2006, 06:29 AM
direstraits is offline
Find More Posts by direstraits
ireland
Joined Feb 2006
Help!
Thrust Bearing In Blade Holder Assembly
I AM BUILDING AN EVO 30.THEIR IS A CAUTION IN THE BLADE HOLDER ASSEMBLY IRO THE THRUST BEARING.IT SAIS THE LARGER INNER DIAMETER MUST FACE THE HOLDER .TO ME BOTH DIAMETERS LOOK THE SAME.MORE IMPORTANTLY WHAT HAPPENS IF THEY GO IN THE WRONG WAY AROUND!!!
ANY HELP WOULD BE APPRECIATED
direstraits is offline Find More Posts by direstraits
Old Apr 02, 2006, 06:40 AM
imodel is offline
Find More Posts by imodel
USA, CT, Farmington
Joined Nov 2003
Take the bearing races and place them on an Allen wrench. The race with the larger hole will hang just slightly lower.
imodel is offline Find More Posts by imodel
Old Apr 02, 2006, 06:56 AM
ireland
Joined Feb 2006
IM AFRAID TO ASK WHAT HAPPENS IF THEY IN THE WRONG WAY AROUND.I HAVE PAST THIS ASSEMBLY STAGE AND AM WONDERING HOW HARD ITS GOING TO BE TO REMOVE THE BEARING TO CHECK.ANY IDEAS
Old Apr 02, 2006, 08:20 AM
imodel is offline
USA, CT, Farmington
Joined Nov 2003
I'd make sure they are correct and take the grips apart, it only takes a few minutes. Cheap insurance for peace of mind.
Old Apr 02, 2006, 10:17 AM
barracudahockey is online now
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Slip both races on the spindles, rock them back and forth. One will move much more than the other, thats the larger ID.
Caps is SHOUTING, please refrain.
barracudahockey is online now Find More Posts by barracudahockey
Old Apr 02, 2006, 10:34 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
If they are installed the wrong way around the smaller inner diameter could rub against the feathering spindle causing a bit of friction.
Is there any chance you have mixed up the two sets, so that on one set you have both small ID ones, and the other both large?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Apr 02, 2006, 12:12 PM
ireland
Joined Feb 2006
got it sorted
Pat MacKenzie
that is exactly what happend!!! thanks a million for the advice.
got it sorted now.
Old Apr 02, 2006, 12:14 PM
ireland
Joined Feb 2006
no more shouting
Discussion Swift 16 thrust bearing & blade grip issue Paint Man Electric Heli Talk 4 Aug 16, 2007 08:25 PM
Question Thrust bearing in Raptor 50 V2 blade grips tufnik Electric Heli Talk 3 Jul 14, 2006 10:12 PM
Question Order of assembly for thrust bearings in ECO 8 head? preston_brown Electric Heli Talk 2 Jun 02, 2006 08:25 PM
Thrust Bearings in Blade Grips on Zoom 400? sailmike Mini Helis 0 May 04, 2005 06:50 PM
can you put thrust bearings in an Eco? nullman Electric Heli Talk 5 Mar 05, 2002 11:36 AM
