Old Apr 01, 2006, 03:43 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Build Log
Valenta 1/3 L-213a
OK, you guys asked for it. I just finished the model today, will aerotow next weekend at the Visalia aerotow meet. I used 9 HS-5945 servos on the ailerons, flaps, elevators, and rudder. HS-225mg for spoilers, HS-645 retract, tow release and brake. Used 4 JR Matchboxes. 2 3300 ma. batteries. Unless my scale is wrong it weighs 29 pounds. It only took 15 ounces of lead in the nose to correct the C.G.
s2000 is online now Find More Posts by s2000
Old Apr 01, 2006, 09:40 PM
MT4 Display Only is offline
Find More Posts by MT4 Display Only
Pedal Faster
MT4 Display Only's Avatar
USA, CA, Visalia
Joined Apr 2004
Visalia Aero Tow Flooded
These pictures were taken Friday March 30, Word is that
the water will remain at this level for one week.
Im not sure the water level at the field will be down enough,
or be dry enough by the April 8 to do any flying.
MT4 Display Only is offline Find More Posts by MT4 Display Only
Old Apr 01, 2006, 10:03 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
I hope you are bringing it to Los Banos. I'de sure love to see it fly since I have one of those on order.
TFLG
TFLG is offline Find More Posts by TFLG
Old Apr 02, 2006, 09:32 AM
jfrickie is offline
Find More Posts by jfrickie
jfrickie's Avatar
United States, KS, De Soto
Joined Aug 2004
Load her up and bring it to the KCSE aerotow at the end of April, we will tow you up. HKM -USA may have the new ASW28 there for its first flights also.
jfrickie is offline Find More Posts by jfrickie
Old Apr 03, 2006, 07:12 AM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Wow Dennis...sure loook super and ready to rip up the sky. Pilot really sets it off nicely. 29 pounds...sure that's right? I weighed up my bare airframe before I started and it came in at 18-3/4 pounds. However, I don't have a retract and mine does not have as much carbon as yours.
How did you set up the 4 matchboxes...one for each aileron servo? Also, would love to see how you set up the pull-pull rudder bellcrank and servo.
TIA,
Steve
SteveR is offline Find More Posts by SteveR
Old Apr 03, 2006, 07:14 AM
SteveR is offline
New York
Joined Feb 2002
Also...how did you attach the rudder horns for that big hollow control surface?
Old Apr 03, 2006, 08:42 AM
s2000 is online now
so. cal.
Joined Jan 2006
Steve, on the rudder, I used the glass rudder horn supplied, but the connectors they give you in the kit are too big, so I just used pull-pull cable directly on the horn to the servo, I skipped a bellcrank. I was trying to use the supplied pushrods with 2 rudder servos but once again no clearance for the larger ballinks they supply, so I went to 1 rudder servo, and skipped using the pushrods. My model weighed 21 1/2 pounds dry. I will try posting some more pictures tonight when I get home of the rudder mounting etc.
Old Apr 03, 2006, 09:19 AM
skyboyken is offline
Find More Posts by skyboyken
I do this for fun!
Sunshine Coast, Australia
Joined Sep 2004
Where are you guys buying your Valenta planes?
skyboyken is offline Find More Posts by skyboyken
Old Apr 03, 2006, 09:45 AM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
Soaring USA
Old Apr 03, 2006, 10:06 AM
rbehrends is offline
Find More Posts by rbehrends
Thiells,N.Y
Joined Jan 2002
Well Steve, that will be a hell of a project, now if we only know someone with a towplane powerfull enough toget to altitude. Would imagine even the Pegasus would be laboring and the trick being not to overfly the towplane.
I can't wait to hear the flight reports on these! When will you start building it?
Richard
rbehrends is offline Find More Posts by rbehrends
Old Apr 03, 2006, 10:33 AM
SteveR is offline
New York
Joined Feb 2002
Richard, I'm almost done with both wings, fuse is next. I'm sure a Pegasus with a 100cc engine will tow it up nicely. I would think your G62 tug will do well. I'm guessing mine will come in around 21 pounds.
Dennis, thanks for the info, also interested to know how you wired your Matchboxes. I'm thinking that with my Profi 4000 TX I can program one aileron servo in each wing in the normal manner and then use a separate channel with a 13 point curve for the 2nd servo in each wing to precisely match the travel of the first. Anything amiss with that logic?
Regards,
Steve
Old Apr 03, 2006, 11:28 PM
s2000 is online now
so. cal.
Joined Jan 2006
Steve, that sounds fine with the Profi. I just routed each aileron servo through the Matchbox and dial them in, Matchboxes are a great little accessory.
A Pegasus with a DA-100 will tow just about anything behind it, we have towed models over 55 pounds, it helps if the towpilot and glider pilot are experienced.
I am going to see if I can get my scale calibrated, the model doesn't feel like it weighs that much.
Old Apr 04, 2006, 08:28 AM
SteveR is offline
New York
Joined Feb 2002
Thanks Dennis, greatly appreciate all your helpful info. Making good progress with my big Blanik, feel confident it will be finished in time for the JR event, see you there for its maiden flight!
Regards,
Steve
Old Apr 04, 2006, 10:19 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
L-213
Dennis:
Sweeeeet!
Bob
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Old Apr 04, 2006, 11:19 PM
s2000 is online now
so. cal.
Joined Jan 2006
And many thanks to Bob from SoaringUSA for importing the L-213a, there are many little detail items in the manufacture of this model that made it a real pleasure to put together, things like the servos hatches on the wing and stabs that have a nut bonded into the wing skin to attach the servo covers, that kind of detail saves a lot of time, the fit of all the rudder hardware was incredible, I haven't seen this type of work in most of the German kits. I wil post some pictures of what I am talking about this weekend. Thanks Bob!
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
For Sale Valenta all molded L-213 2.7m Scale 5:1 NIB Dbox Aircraft - Sailplanes (FS/W) 7 Sep 22, 2006 06:35 PM
1/3 scale L-4 project continues (slowly) the-plumber Scale Fuel Planes 0 Feb 16, 2005 11:40 PM
New Version of WebWeather (1.3) eladyland Parkflyers 12 Jul 27, 2003 06:12 PM
ModelTech 1/3 Scale Cub mkirsch1 Sport Planes 2 Dec 16, 2001 04:24 PM
