Old Oct 08, 2012, 02:37 PM
Kev71H is offline
Find More Posts by Kev71H
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
Nice eye candy... ""Got......To....Resist.........got.....to.....get .....me.....one...." (my best BATMAN to ROBIN voice
Kev71H is offline Find More Posts by Kev71H
Old Oct 19, 2012, 03:35 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Bruce, do front brake pins that hold the front brake disk come with the wheel spokes that you sell?
http://2wheelhobbies.com/product_inf...oducts_id=1562
If not, why?
Eager to know.
Kevin
Old Oct 19, 2012, 10:49 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
If not, why?
Eager to know.
Kevin
No they don't. They come in the front brake kit.
Bruce
slawsonb is offline Find More Posts by slawsonb
Old Oct 23, 2012, 02:55 AM
alanonly is offline
Find More Posts by alanonly
Joined Oct 2012
Hi Bruce,
What is the option wheels and tires for DXR500 to replace the stock front and rear gyro?
Regards,
Alan
alanonly is offline Find More Posts by alanonly
Old Oct 23, 2012, 11:01 PM
slawsonb is offline
Bruce
Palmdale, CA
Joined Sep 2005
Originally Posted by alanonly View Post
Hi Bruce,
Regards,
Alan
Duratrax makes the Alloy front and rear wheels that will fit. ZH Racing also makes an alloy wheel set. PMT tires work great. Get te SB5 tire inserts to go with the tires.
Bruce
Old Nov 12, 2012, 12:13 AM
alanonly is offline
Joined Oct 2012
Hi Bruce,
Zh racing alloy wheel set is out of stock?? Waiting.......
alanonly.
Old Nov 13, 2012, 10:55 AM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Where to buy brake disk PINS???
***** Where can I guy the "brake disk pins" at?
When I want to change my front tire, I don't want to remove the front pins that keep my brake disk in place because I have them set perfectly on the current one I have now.
*See pic.
Old Nov 13, 2012, 11:09 AM
steliosh is offline
Find More Posts by steliosh
www.steliosh.net/rcmoto/
steliosh's Avatar
Athens, Greece
Joined Oct 2003
You can always make your own from an old 3mm diameter shock shaft! I did two when I LOST two in my first bad crash and never found them at the parking lot!!!!
Then you just press them slowly into the wheel sockets.
Unfortunately I dont have the wheel near me (it's with the bike at an RC Shop for showing on the window!) so I can't measure the length. Anyone?
steliosh is offline Find More Posts by steliosh
Old Nov 13, 2012, 11:11 AM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Originally Posted by steliosh View Post
You can always make your own from an old 3mm shock shaft! I did two when I LOST two in my first bad crash and never found them at the parking lot!!!!
MAN! I can't hardly believe that TT does not offer to have these parts available WITHOUT Having to buy the whole front brake assembly.
** I don't have a 3mm shock shaft to sacrifice or I may consider making a set.
(Note: Stelios, wow bro - What kind of crash did you have to loose those pins??? Must have been a bad one.)
Old Nov 13, 2012, 12:11 PM
steliosh is offline
steliosh's Avatar
Athens, Greece
Joined Oct 2003
the crash was head on to the sidewalk! At what it seemed like full speed... Actually the front tire was not glued well (MY FAULT!) ballooned and took with it the ESC switch which I had double side taped under the steering servo. IT WAS an accident waiting to happen...
Broke disc, hub, ruined a brand new PMT200 tire, ruined the black kit TT insert, lost two pins... oh... I just had forgotten how painful it was!!!
Anyway...
However, TT does not even sell the disc brake alone. Only in a set...
Edit: You can go to your local HS and ask for the longest/cheapest shock shafts. Then cut accordingly... Each shaft may make 3-4 pins...
Old Nov 13, 2012, 01:34 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Ouch!
Old Nov 13, 2012, 02:42 PM
TopDave is offline
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
*See pic.
Kev71 you can buy 3mm dowle pins from McMaster-Carr.com on line. Just measure your pins and order what you need. Ya may have to buy them a bit longer and grind a mil or 2 off to get the length you need.
TopDave is offline Find More Posts by TopDave
Old Nov 13, 2012, 03:09 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
Hey Bruce.. any word on the Repsol MotoRacer?
Akura2 is offline Find More Posts by Akura2
Old Nov 13, 2012, 03:39 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Thanks!
New Product Kyosho HOR now at 2WheelHobbies.com slawsonb Motorcycles 9 Jan 06, 2007 05:55 PM
Discussion Thunder Tiger now at 2wheelhobbies.com slawsonb Motorcycles 41 Jun 21, 2006 06:46 AM
