Old Jul 09, 2001, 10:32 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Reversing a brushless motor
Well I'm taking my 1406/2Y out of my fan as it's just sitting with no airplane to fit into, and I'm going to fit it into a Modeltech EX300S ARF with a gearbox. Besided the retiming, I have to reverse the motor. I think I've read that you just have to switch two of the three wires, and that it doesn't matter which two. Is this correct? I'm using the Aveox L260 controller so it's sensored. I can't find the instructions for the controller at the moment...DOH!
Thanks guys.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jul 09, 2001, 11:59 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Usta be, maybe still can; download the ESC and motor instructions (pdf) off the Aveox site. Could e-mail them if you need.
I use Kontronik sensorless, so I just swap leads.
Got a GB in mind? the 5mm shaft makes this a bit of a challange. If you have special ordered it with 1/8" the MEC box would work well.
jrb is offline Find More Posts by jrb
Old Jul 09, 2001, 03:01 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Ed, I had good luck with the new Jeti sensorless 40A controller (with BEC) & the 1406/2y. You might want to consider it - as a replacement if you ever get tired of your L160 sensored controller, timing, sensor wires etc.
Herb is offline Find More Posts by Herb
Old Jul 09, 2001, 03:29 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Oops.. as pointed out in the other forum, you still have to retime it!
ARGH - guess I'm getting too used to these sensorless controllers myself!
..a
Old Jul 09, 2001, 03:37 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Well shoot I forgot about the dip switch. I found the instructions on the site, it says just flip one switch to off and I'm set! Gotta change the timing of course. Cool, sounds fairly easy. Don't know if I'll measure currents when retiming or just offset it as much as it is now.
I ordered a 13 turn 5mm Astro pinion from New Creations. I have a Superbox from MEC with a 60 tooth spur, that'll give me a 4.6/1 ration, and I also have a 3 to 1 Master Airscrew box...not sure how many teeth the spur has on that one, gotta take it apart. I'd like to get a 10 tooth pinion but with the 5mm shaft that's out of the question. I'm looking for a fairly high ratio since the 1406/2Y is a hot motor. I want lots of prop for good vertical performance. Now to get hacking on the fuselage of the Extra to get rid of some dead weight....
Old Jul 09, 2001, 04:18 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Wait Ed, wait. Not all Superboxes are the same!
The MEC Superbox uses stander 48 pitch RC car pinions. The AF stuff (Their Superbox as well) use helical gears.
I'm pretty sure the AF pinion won't work with the MEC box.
Old Jul 09, 2001, 04:54 PM
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Not sure on that one JRB! New Creation's site didn't say helical or not, but there may not have been enough room in the description box. He said the part number had changed from AF5120 to AF755, which makes me suspect it might be helical. I just emailed Kirk to ask. I looked on the Astro site for the part number but couldn't find it. If it is helical, oh well, probably means fate is pointing me toward an Astro gearbox anyway.
Old Jul 09, 2001, 05:35 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
4.6:1 GB sounds more like a glider gear ratio..? I am converting the .25 Me-109 (similar to the extra) but I will be using a lower gear ratio, will be in the 2-3:1 ratio. Keep in mind that above 11 by x, the prop will hit the ground - my Me-109 has a really short LG. I have a three bladed prop to try as well. And I might try the Jeti 30/3 on direct drive as well. Sorry Chris, I know - no ducting anywhere here...
Old Jul 10, 2001, 12:38 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Covered in Science.. flip the DIP switch!
..a
Question reversing brushless motor controllers sheltod Blimps 12 Sep 25, 2006 12:49 PM
Question reversing direction of a brushless motor Andy2No Hacker Brushless 2 Apr 21, 2006 09:01 PM
Reversing brushless motor? megawatt Power Systems 4 Sep 08, 2001 11:33 AM
Reversing a brushless motor Ed Waldrep Power Systems 3 Jul 10, 2001 12:19 AM
tiny brushless motor and i mean tiny tiny Spin_Doctor Electric Plane Talk 1 Apr 30, 2001 04:07 PM
