Old Mar 31, 2006, 01:28 PM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Help!
Quick Question, Any Input Would Be Appreciated!
Hi all,
Slowly puttin my Zoom/Shogun back together, this time with Daves beltdrive conversion, and need to start thinking about electronics placment.
Currently got two ideas.
#1: Have gyro (GY401) mounted over tail boom, using MJP mount (http://www.grandrc.com/inc/sdetail/3113, only have the gyro bit), RX (Schulze 8.35) on the front sloing bit, and ESC on the bottom of the frame.
Bad thing with this, is that the gyro is in a bad place, not helped by the fact that its even higher up becuase of Daves belt tensioners e.t.c. Picture shows paddles at far back position, although I can easily get them to touch by pushing the paddle down.
But it does have all the bits pretty far from each other, and I like the additional CF of the gyro mount
#2 Gyro in the middle of the frame, just behind the battery. RX still on the slanted bit, and ESC below frame again.
Good thing is that the gyro is pretty well protected (not hard to get to screws on it though). However, ESC and gyro are pretty close (although Im using a pretty good RX...?), and the gyro, which is heavy, is near the bottom of the heli, so its not good for the vertical C of G (more pendulum effect).
So I guess its mainly 'where to put the gyro', seeing as the other parts stay in the same place.
Apart from the ways above, any other simple ways to mount the gyro, or any of the other electronics?
Cant mount it under the boom becuase the motore and tail servos in the way
Oh yeah, if I go with #1, I suppose I could mount the RX behind the batt, keep it protected, but it would mean I wouldnt be able to mount the lipo as far back (about 1/2 inch).
Cheers, Duane
Minimole is offline Find More Posts by Minimole
Old Mar 31, 2006, 02:30 PM
will p3 is offline
Find More Posts by will p3
Joined Aug 2003
#2 is my pic if it doesnt effect the performance of the gyro from feed back from the reciever or esc.
will p3 is offline Find More Posts by will p3
Old Mar 31, 2006, 03:38 PM
Minimole is offline
Minimole's Avatar
Joined May 2004
Thanks.
Yeah, the closeness to the other electronics is my main worry...
Can anyone else shed any light on that setup?
Cheers, Duane
Old Mar 31, 2006, 03:48 PM
jeepson33s@yahoo is offline
Find More Posts by jeepson33s@yahoo
Kids. Please Back Up!
jeepson33s@yahoo's Avatar
Joined Dec 2005
mabee a plate on the bottom of the frame toward the rear. is there enough room?
jeepson33s@yahoo is offline Find More Posts by jeepson33s@yahoo
Old Mar 31, 2006, 04:23 PM
Minimole is offline
Minimole's Avatar
Joined May 2004
Ill probably end up going with #2, dont want to risk my gyro...
Ill push the ESC as far back as possible, should be at least 1inch between it and the gyro, not much I know, but better than nothing
Hope the C of G will be OK, if its too far forward, Ill shift the tail servo back.
Cheers, Duane
Old Mar 31, 2006, 04:27 PM
McDanger is offline
Find More Posts by McDanger
Aberdeen,Scotland, UK
Joined Jun 2005
How about pic #1 but with your gyro mount swung over 180deg. so the gyro is underneath,and the servo on top?.
Edit: ok ok, ive thought it through..... ,,i mean who wants an extra link to get the tail control rod hooked up....
McDanger is offline Find More Posts by McDanger
Old Mar 31, 2006, 04:31 PM
McDanger is offline
Joined Jun 2005
I'll now go with the jeeps suggestion,considering i have the same thing made for my gyro,i shouldve suggested it first.
Old Mar 31, 2006, 05:12 PM
Steve_C is offline
Find More Posts by Steve_C
/bin/ksh
Steve_C's Avatar
USA, GA, Savannah
Joined Nov 2005
When I read the thread title i thought hey a chance to give a quick heliman style one liner
I was thinking were I was to place it on my shogun as well. Underside of frame to the front of the tail servo (make a plate) and move the servo back some if you need to make room. Easy access to adjust if needed.
I like #2 alot too though.
Steve_C is offline Find More Posts by Steve_C
Old Mar 31, 2006, 06:34 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
#2 looks good providing you do not see any glitching... do some test flights (close in hovers etc. in 'your' field) and check the glitch counter on the RX.
The only alternative I can think of is to use #1 but move the gyro in closer to the main shaft to get better clearance from the flybar. You'll need to add an extended mounting plate to the existing mount for the gyro to sit happily - ideally a piece of CF plate.
EDIT: took another look at your photo and there seems to be plenty of room to move the gyro forward in #1. Try #2, if you get glitching then build and extended mounting plate and move it forward from the #1 position is my best shot.
ukgroucho is offline Find More Posts by ukgroucho
Discussion Camera selection! Any help would be appreciated! GOK Aerial Photography 9 Sep 19, 2006 05:49 PM
Question Maxir vs. Hornet X3D. Any Input Would Be Great! Minimole Micro Helis 60 Mar 01, 2006 12:31 PM
Tigermoth 3-D 350...any comments would be helpfuk thenamshow Parkflyers 0 Jun 19, 2005 06:40 PM
any advise would be welcome jeffhines13 Electric Ducted Fan Jet Talk 8 Feb 26, 2004 03:46 PM
Nice frist jet any advice would be great jeffhines Electric Ducted Fan Jet Talk 2 Oct 23, 2002 10:55 AM
