Old Mar 30, 2006, 11:49 PM
Crash549 is offline
Find More Posts by Crash549
RALEIGH, NC
Joined Feb 2006
Question
What is the difference between these tail gears??
What is the difference between these Align part numbers HS1152 and HS1153 ? They are the tail gear sets(blue} w/ aluminum belt pulleys. Thanks!
Crash549 is offline Find More Posts by Crash549
Old Mar 31, 2006, 12:42 AM
flyonwire is offline
Find More Posts by flyonwire
Joined Mar 2006
could be tail reduc gear and none reduc gear in blue material
flyonwire is offline Find More Posts by flyonwire
Old Mar 31, 2006, 01:34 AM
rbiasi is offline
Find More Posts by rbiasi
La Costa, CA
Joined May 2005
Look on Align's web site. 53 is for SE, 52 is for XL or CF frame. It comes with the pulley installed. The SE version comes without the pulley installed so you can get it into the bearing block.
rbiasi is offline Find More Posts by rbiasi
Old Mar 31, 2006, 02:45 AM
BigS is offline
Find More Posts by BigS
Mad Heli Scientist
BigS's Avatar
Rangiora, Canterbury, New Zealand (Aotearoa)
Joined Jun 2004
The preassembled pulley set has a spline that the alloy belt pulley is pressed on to.
The SE set that doesnt have the pulley assembled, also needs the pulley to be held on with R48 but it doesn't have a spline.
Edit: see next post
Apart from that, they are exactly the same.
Shannon.
BigS is offline Find More Posts by BigS
Old Mar 31, 2006, 03:42 AM
rotarypower3 is offline
Find More Posts by rotarypower3
Trex450/500/600E(vBar)
rotarypower3's Avatar
Melbourne (east burbs), AUSTRALIA
Joined Mar 2005
Originally Posted by BigS
Edit: the tail shaft on the SE version is 41mm long where the preassembled version is only 40mm.
ALL the new tail shafts are 41mm.
rotarypower3 is offline Find More Posts by rotarypower3
Old Mar 31, 2006, 04:10 AM
BigS is offline
Mad Heli Scientist
BigS's Avatar
Joined Jun 2004
Must have got an earlier slowdown gear set then eh .
Shannon.
Old Mar 31, 2006, 04:42 AM
Joined Mar 2005
Must have been a REAL early one, because Align brought out the 41mm tail shafts before the slow down gears.
Old Mar 31, 2006, 07:05 AM
jeepson33s@yahoo is offline
Find More Posts by jeepson33s@yahoo
Kids. Please Back Up!
jeepson33s@yahoo's Avatar
Joined Dec 2005
i have a complaint about these gears. the pully is wobbley and it is so bad that it will tighten and un-tighten my belt every revolution. anyone else have this or am i the only one?
jeepson33s@yahoo is offline Find More Posts by jeepson33s@yahoo
Old Mar 31, 2006, 03:19 PM
BigS is offline
Mad Heli Scientist
BigS's Avatar
Joined Jun 2004
My pulleys seem to be fine, they run very true, unlike the plastic pulleys.
Shannon.
Old Mar 31, 2006, 10:38 PM
Crash549 is offline
RALEIGH, NC
Joined Feb 2006
I went to align's web page and looked at the pretty pictures and saw the difference and ordered the set with the front pulley already installed.
Old Mar 31, 2006, 11:36 PM
mrX is offline
mrX
Find More Posts by mrX
mrX
mrX's Avatar
Columbus, Ohio
Joined Jan 2005
Guy at the LHS here said the only difference was whether the pulley was pre-installed or not. I bought the last pre-installed one. He said the others were for the SE b/c of how it installs in the frame. He said it only saves one step, and that they'd not be stocking the 1152s any longer (I bought the last one).
mrX is offline Find More Posts by mrX
Old Apr 08, 2006, 01:02 AM
Crash549 is offline
RALEIGH, NC
Joined Feb 2006
Thanks for all the info
got the HS1152 gearset today and I love the aluminum rear pulley.Its like a buck more than JUST an aftermarket rear pulley. Go Figure.
Discussion what is the difference between these 2 frames? DsWright Mini Helis 7 Mar 23, 2007 02:35 PM
What is the difference between these motors? louisd Power Systems 1 Sep 27, 2005 02:24 PM
What is the difference between these two GWS receivers ? robert harik GWS (Grand Wing Servo) 2 Mar 30, 2004 02:55 AM
what is the difference between these two GWS receivers? robert harik Radios 0 Mar 30, 2004 12:31 AM
What is the difference between these? Bill K. Batteries and Chargers 2 Nov 15, 2003 10:55 PM
