Old Mar 29, 2006, 04:47 PM
JRuggiero is online now
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Yet Another Aero Ace/X-Twin Conversion
Gents,
In the spirit of creating your own thing with Aero Ace/X-Twin hardware, here's my take on the Bell FM-1. Span is 17 inches, length is 12 inches. The wing is wider than scale, because I wanted more wing area. So the tail areas are greater, too.
Weight is 23.3 Grams with two 6-32 machine nuts in the nose to balance. Construction is all 2 MM Depron, except for 1/64" ply for landing gear struts and tail "wheel"/skid, and tail surfaces are 1.3 MM Depron, and non-rotating wheels made of 3 MM Depron.
Insignia was printed on inkjet paper, then cut and pasted, but the tail stripes were done directly on the rudder with Sharpy pens.
I maidened it this afternoon in a light breeze. It needed a little pitch trim adjustment, but it flew fine. Turns could be tighter, so I'm adding wing dihedral. I'll remove one or both 6-32 nuts and see if that corrects a tendency to dive with power off. My goal is to prep the Bell for indoor flying in a couple of weeks. The site is a single basketball court with six baskets hanging down.
Jim R
JRuggiero is online now Find More Posts by JRuggiero
Old Mar 29, 2006, 05:11 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
That's marvelous!
BEC is offline Find More Posts by BEC
Old Mar 29, 2006, 11:32 PM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Beautiful plane + clever construction !
relaxr is offline Find More Posts by relaxr
Old Mar 30, 2006, 12:16 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Very nicely done! When mentally thumbing through aircraft with twin pusher props, this very plane came to mind. I'm glad to see someone's done it.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Mar 30, 2006, 06:31 AM
tann200 is offline
Find More Posts by tann200
Estonia
Joined Sep 2005
any plans avilable for this birdie?
tann200 is offline Find More Posts by tann200
Old Mar 30, 2006, 08:46 AM
Joined Feb 2000
Gents,
Thanks for your kind responses. My pictures don't reveal the construction boo-boos, so your praise is not totally warranted. I did a lot of simplification of the contours, so it's more a "reminder scale" rendering than an authentic rendering. Even so, this sort of thing can be done well with Depron.
And it helps to use a cooperative glue. After a lot of experimentation with GWS glue, Gorilla glue, etc., I settled on Formula 560 Canopy Glue by Pacer Technologies, makers of Zap super glues. Formula 560 grips well, sets up to handling condition in a half-hour when applied thinly, dries clear, and cleans up with water. A little goes a long way in a simple project like this.
To keep weight down, I didn't cover the bottom of the nacelles or forward fuselage, nor did I apply paint. The wing airfoil curve for the center section is determined by the curved slots in the fuselage and nacelle sides. I scored the undersides of the outer wing panels to get them to curve without needing ribs to hold the contour. You'll notice that the top of the fuselage is a simple ridge line formed by gluing the two sides together at their top edges. With the wide bottom, the cross section is, in effect, triangular. It's not scale, but it's simple, and it keeps the weight down.
I didn't make up a formal plan. Instead I worked from 3-views presented over in the Scale Electric Planes forum by Kiwi. Check out http://www.rcgroups.com/forums/showt...48#post5260003 For a more formal construction plan, check out John Hunton's plan for an FM-1 powered by Aero Ace innards in R/C Micro World.
Jim R
Discussion NEW AERO ACE X-TWIN JET at Target kydawg1 Micro Ready-to-Fly 327 Oct 22, 2007 09:11 AM
Build Log God Shave The Queen!!! - Micro Mosquito as an X Twin Conversion! Harpye Scratchbuilt Indoor and Micro Models 87 May 12, 2007 02:07 AM
Discussion another aero ace bites the dust, maybe? karpiloco Micro Ready-to-Fly 17 Aug 27, 2006 12:09 PM
Discussion Next X Twin Conversion ->A Junkers Ju52 Harpye Scratchbuilt Indoor and Micro Models 24 Apr 20, 2006 02:36 PM
Consolidated "Cathy" - X-Twin Conversion Harpye Scratchbuilt Indoor and Micro Models 28 Nov 29, 2005 01:38 PM
