Advice on upgrading the power system on my EasyGlider Electric? (long)
First thing: I wanted to try to do this for as little money as possible.
I have my stock EasyGlider Electric. As a refresher, it has a speed 400, geared 3:1, with a 9.5x6 folding prop/spinner. Since Multiplex pulled this drive unit out of the Space Scooter, the spinner's too small for the EGE, and the prop doesn't fold properly. Now, I'm using an 8 cell, 750 mAh AAA size pack and getting by with it for about 5 minutes' worth of climb. I haven't bought my final battery pack for it yet. So that is one motivation for upgrading. The other motivation is that it doesn't offer very fast climbs. I'm not after hotliner or vertical type climbs. I don't need it, as this is a thermal sailplane. I would like to be able to climb out at about 30-40° though. Option 1:
Thanks for sticking with it until the end of the post!
manila
Joined Jun 2004
You can consider using a hyperion Y22L brushless (got this from Aircraft World), an MPI speed 400 gearbox (from Hobby Lobby) using 3:1 gear ratio, 8-cell 1050 NiMh and a 10x8 Graupner Cam folder.
I posted this set up and a pic of my easyG over here (post #9) http://www.rcgroups.com/forums/showthread.php?t=457921 If you want to use your stock gearbox, the Hyperion Y22L is a great drop in replacement for the stock speed 400 With my present set-up, she flies great, plenty of power but won't go vertical and hang on her prop if that's the kind of performance you're looking for. I find that having my throttle stick halfway is more than enough to allow me to fly to soaring altitude. |
I use a 3 cell 1200 Mah and it is more than enough on the stock motor to get it up, in fact I use a little over half throttle to take off and climb, I would try to find a 3 cell from 1200 to 1800 mah to borrow for a test before I went thru all what you are talking about, do you have the brake set on the Jeti, I don't have a brake and I use the GWS rubber bands 2 of them over the prop to fold it, it does a fair job untill I get another speed controller with a brake
Heres a video where I flew it the first time, I wasn't trying to get it up fast http://www.rcgroups.com/forums/showt...63#post5254782 |
manila
Joined Jun 2004
Jeremy - here's the web address:
http://aircraft-world.com/ It's a great site and their service is top notch. This forum is full of threads that talk about the quality of their service and their products. The MPI gearbox I'm using offers three gear ratios - 2:1, 2.5:1 and 3:1. The gears are mounted on the shaft via a built-in set screw. For added security, I placed treadlock on the shaft and set screw hole before mounting it. |
If you are going to use brushed motors, they are going to wear out. They will wear out before the GB. And you will need the pinion puller then. Ryan |
Latest blog entry: 2012 Masters Videos
Not on some of the larger folders. For example, I have the Graupner 11x8. It does not use set screws, but a regular nut. Here is how it works. There is a nut on the front of the spiner and as you tigten it, it collapses the plate that the motor shaft goes into. Hard to explain. But it is not like some of the smaller graupners (like the Graupner 6x3 folder), where there are 2 set screws driven by a "hex driver" that go into the sides of the spinner and press against the shaft. BTW, I don't like the setscrews. I always tend to over tighten them and then that ruins the little plastic that they screw into. But, whatever you go with, good luck. Sounds like you have done your homework. Ryan |
| Thread Tools | |
| Discussion Problem Setting Up Dual Rates on My First Electric 3D Plane | rickson34 | Electric Plane Talk | 2 | Dec 11, 2006 09:13 PM |
| Advice on N11 power system | The_End | Power Systems | 5 | Nov 08, 2004 05:19 AM |
| Please help, I need the right power system for my plane | 3D Champ | Parkflyers | 7 | Feb 26, 2004 10:54 PM |
| Power System for my Surprise 11 F5B | bwaltz | High Performance | 18 | Jan 04, 2003 03:40 PM |
| Ailerons on my HH Electric Scout! | Matthew Allen | Sport Planes | 4 | Jul 15, 2002 02:13 AM |
