Old Jul 02, 2002, 11:00 AM
NetForce2K is offline
Find More Posts by NetForce2K
Montreal, Canada
Joined Apr 2002
Is Fan-Fold the same material as the pink 2" insulation foam ?
I'm asking because it doesn't seem like fan-fold is available in Canada, probably because of the weather... anyways, I was wondering if it was the same material as the 2" pink insulation foam.
If it is, I could just make myself 3/8" panels out of a 2" sheet... I've done 1/2" already and they were perfectly straight...
Thanks for the info.
NetForce2K is offline Find More Posts by NetForce2K
Old Jul 02, 2002, 11:43 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
No it's not NetForce2K, but it is close and will do in a pinch! The pink stuff is little more brittle than the blue, so much have a different composition.
CenTexFlyer
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Jul 02, 2002, 03:14 PM
Hippo is offline
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
Actually Yes AND No.
The pink insulation foam, and the pink fan-fold are effectively identical. The fan-fold is pre sliced neatly into 1/4" thick sheets. The Blue fan-fold is really quite different. The foam is similar, but the fan-fold has a plastic skin on it that really adds to the stiffness and durability. That's the stuff to get if you can. Otherwise, spray the pink foam lightly with the old 3M-77 spray, and cover it with cheap packing tape to get the durability.
Enjoy,
-Dan
Hippo is offline Find More Posts by Hippo
Old Jul 02, 2002, 09:42 PM
CLARKE is offline
Find More Posts by CLARKE
CLARKE's Avatar
nova scotia
Joined Mar 2002
i live in canada
hey i live in canada and i get some fanfold foam but mine is green not blue its a little better than the blue stuff
i live in nova scotia and got it at a place called cormacs building supplys for 45 bucks
go to a local siding store and ask them if they have it 10 out of 1 says they do
good luck
CLARKE is offline Find More Posts by CLARKE
Old Jul 02, 2002, 11:13 PM
Montreal, Canada
Joined Apr 2002
thanks Clarke, will try that for sure !
Old Jul 02, 2002, 11:15 PM
Radioguy is offline
Find More Posts by Radioguy
Winnipeg Intl, Canada
Joined Mar 2002
Hi Clarke:
Can you post the actual brand name of the stuff for us fellow Canucks?
Lee Smith
Winnipeg
Radioguy is offline Find More Posts by Radioguy
Home depot pink fan fold foam SKU? fuelsguy Foamies (Kits) 13 Feb 18, 2010 05:51 PM
pink or blue fan fold foam EKI16 Foamies (Kits) 1 Dec 05, 2003 11:23 PM
Locating 2" Pink foam or fan fold in AZ. stealthy Foamies (Kits) 4 Nov 20, 2002 11:00 PM
1/2" Owens Corning pink foam Xoltri Foamies (Kits) 3 Aug 09, 2002 09:51 AM
What is "Fan fold Foam and where to buy it? ttnissan Foamies (Kits) 1 Apr 18, 2002 10:48 PM
