the mini-version sounds interesting! the biplane configuration with large wing surface makes it sound very feasible. however, you will need some very light equipment. 12" of span is spretty small. if you are going to do it, let us all know what came out please! greetings chara |
Great looking drawings! Glad it flies well.
Did you couple all 4 ailerons yet? Just curious what it will do to the character of the aileron turns... IIRC, the video is with bottom wing ailerons only? The top ailerons may screw things up with adverse yaw (yech!), thus why I'm curious... |
hi guys!
nope I did not couple the ailerons yet. What I am tryin out first is to use larger servo arms to get more aileron deflection. I was not so happy the way it was before. Now I get maybe >10° more of max. deflection. that could already be sufficient for quick rolls. Weather was terrible past few days here (it was SNOWING! ) so I could not fly... Tommorow will be better. I'll tell you what comes out!Gene, the video is with 2 ailerons only and old (short) servo arm. Rolled a bit lazy and at very low speed motor torque was an issue. Adverse yaw? yes, maybe because of the wing camber already in. on the other hand you could reduce total deflection and hence yaw moments... hmmm... someone 's got to try it out Jer, sounds great! Let us know how it works out for you! greetings chara |
| Thread Tools | |
| Depron Biplane | kestrel2003 | Foamies (Kits) | 8 | Oct 27, 2004 06:32 PM |
| Looking for small fast profile depron plane | Mac8 | Foamies (Kits) | 3 | Oct 12, 2004 07:53 AM |
| Depron Biplane - My first scratch build | pjsmith | The Builders Workshop | 0 | Jun 28, 2004 05:30 AM |
| Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? | JoshFlies3d | Foamies (Kits) | 8 | Nov 01, 2003 06:57 AM |
| Video of Matt Fritz Depron Biplane... | kepople | Foamies (Kits) | 11 | Oct 17, 2003 09:41 AM |
