Old Jan 18, 2013, 07:49 AM
lucaferr73 is offline
Find More Posts by lucaferr73
lucaferr73's Avatar
Italy, Tuscany, San Marcello Pistoiese
Joined Jul 2012
Ciao a tutti iniziato il taglio depron e fatto l'ordine su HK per l'elettronica
CiÓ
Luca
lucaferr73 is offline Find More Posts by lucaferr73
Old Feb 24, 2013, 09:22 AM
Lasercopter is offline
Find More Posts by Lasercopter
S900-T810-QAV400-XJ470-BO MINI
Lasercopter's Avatar
United States, NY, Saratoga
Joined Nov 2012
Thank you, I started the build with a buddy of mine, this is my first foam plane ever, so wish me luck ill post pictures of the end result.
Lasercopter is offline Find More Posts by Lasercopter
Old Mar 03, 2013, 08:38 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Just starting one with an 18" wingspan from a single sheet of dollar tree foam.
mclarkson is offline Find More Posts by mclarkson
Old Mar 05, 2013, 02:45 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
All the pieces cut out and test fitted together.
Any suggestions on how best to attach landing gear?
Old Mar 05, 2013, 06:14 PM
ggrimley is offline
Find More Posts by ggrimley
ggrimley's Avatar
United States, SD, Rapid City
Joined Dec 2011
Could sandwich it between 2 pcs plywood behind motor making a double firewall, or cut a slot just ahead of ail servo and mount gear to plywood in the slot...then reinforce the area.
ggrimley is offline Find More Posts by ggrimley
Old Mar 05, 2013, 06:16 PM
ggrimley is offline
ggrimley's Avatar
Joined Dec 2011
Or... Make foam gear legs and glue to wing... Like magnum reloaded
Old Mar 05, 2013, 10:08 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I used GWS stuff mounted to ply
JDMJim is offline Find More Posts by JDMJim
Old Mar 06, 2013, 03:25 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
It's currently sitting right at 95 grams, with very nearly everything in place. I still need to add elevator and rudder pushrods and possibly landing gear.
Old Mar 07, 2013, 09:51 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Here she is, ready for a quick test flight. 18" wingspan, 98 grams without landing gear.
Old Mar 07, 2013, 10:05 PM
Jimmy JFlyer is offline
Find More Posts by Jimmy JFlyer
For us He died, in me He lives
Jimmy JFlyer's Avatar
United States, MI, Saint Clair Shores
Joined Dec 2008
Very nice build Mclarkson. What motor/power setup are you using?
Look forward to maiden results.
Jimmy
Jimmy JFlyer is offline Find More Posts by Jimmy JFlyer
Old Mar 07, 2013, 10:33 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I am using the brick / motor / servos salvaged from an E-flite UMX Gee Bee. AUW on the Gee Bee is 100 grams, so I'm hoping I'll be good to go. With the added bonus of 3-axis gyros!
My big concern at the moment is the quad ailerons. I'm not sure the little Gee Bee servos will be happy pushing so much surface around. For the first flights, at least, I'm just going with ailerons on the lower wing.
Old Mar 08, 2013, 12:51 AM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I put landing gear on it. I wanted to keep it as light as possible.
I took a tongue depressor/ craft stick and cut it in thirds, keeping the outer two thirds. I punched one set of holes and two sets of slits through both bits, then colored them with a marker and epoxied them onto both sides of the bottom fuse.
Bent landing gear out of very thin piano wire. (0.022 maybe?) The wire goes thru the hole in the front of the wood brace, then folds back across the brace. Then I run a zip tie thru the two slits and around the wire to hold the wire to the wood brace at the back. The wheels are some very light (.12 gram?) little wheels I had around. They're just held on by bends in the wire (which I'll clip off a bit.)
The gear turned out to be too thin and floppy so I added another zip tie just below the wood brace, to add tension to the landing gear legs. It's bouncy, but seems to work.
The rear is just a skid, made from a leftover GWS control horn.
AUW with gear: 105 grams.
Old Mar 09, 2013, 04:11 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Well, it more-or-less flies. I had to wait for the rain to stop. At that point, the wind was blowing 12MPH or so and, man, this plane would NOT penetrate at ALL.
I may have to go with a 1S and bigger prop.
//edit: Here's the video of the maiden.
18" Dollar Tree Foamboard biplane - maiden flight in the wind (4 min 25 sec)
Old Mar 10, 2013, 10:04 AM
JDMJim is offline
JDMJim's Avatar
Joined Jul 2011
Thats pretty much it. Ailerons are useless on curved wings. but without diehedral, they are necessary...you know? I havent used my hotrod Bipie for a long time
Old Apr 10, 2013, 09:56 PM
ggrimley is offline
ggrimley's Avatar
Joined Dec 2011
Finished.... The Black Burger of the Sky... Finished it tonight.. all made from meat trays.. Had club members collecting them for me... Wanted to add lights, etc, so was not trying to keep it light... AUW is about 390 grams.. Here are some shots
Depron Biplane kestrel2003 Foamies (Kits) 8 Oct 27, 2004 06:32 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? JoshFlies3d Foamies (Kits) 8 Nov 01, 2003 06:57 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
