Old Mar 29, 2006, 09:33 PM
TopFoam is offline
Find More Posts by TopFoam
aka RAMTech-RC
Chandler, AZ
Joined Aug 2005
Great work, can't wait for a video.
TopFoam is offline Find More Posts by TopFoam
Old Mar 30, 2006, 01:48 PM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Originally Posted by Speedo125
Oh...... I LIKE it! I think I'm gonna have to have one of these! It's going to need some expo' to tame it enough for me, but that's easy enough. Good Job Chara.
Thanks Speedo,
I'll post some plans after the maiden (in case I have to change something in the design). It is pretty easy and straight forward to build. Hope you will like it.
greetings
chara
chara is offline Find More Posts by chara
Old Mar 30, 2006, 01:53 PM
hawk4932 is offline
Find More Posts by hawk4932
UH-60 Blackhawk TI
hawk4932's Avatar
Michigan, United States
Joined Feb 2006
Chara,
Whats your weather looking like? Any chance for your maiden flight SOON. Can't wait. Good luck.
Hawk
hawk4932 is offline Find More Posts by hawk4932
Old Mar 30, 2006, 02:03 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Originally Posted by mr badwrench
Hey, How big is that thing? Its cute so I assumed it was small...
thanks and sorry badwrench that I forgot to give some specs.
In deed I would consider it as small to medium sized.
Wing span is 62cm (= 24.4 in), Length is 55cm (= 21.6 in).
Flying weight will be 230-260g (around 8-9 oz ?) depending on your setup.
260g is with 3 servos, 3s1p 850mAh battery and a small outrunner motor.
Thrust will be around 350g with this setup.
Everything is built in 6mm Depron (blucor works as well of course) and some styrofoam. With the given dimensions and weight the whole construction is stiff enough to do well without any CF-rod reinforcements. That reduces costs and complexity
hope your question is answered
greetings
chara
Old Mar 30, 2006, 02:11 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Originally Posted by hawk4932
Chara,
Hawk
Hawk, weather is rainy at the moment. Forecast for tomorrow Is just as bad, but Saturday looks promising!
Believe me, I'm just as anxious to go and fly that baby as you are!
I still have to do the linkage of the control surfaces, so I'm not too disapointed with the weather as long as Saturday is stable!
@TopFoam:
I'll try to persuade my girlfriend to do the camera-woman once again, so I can
send some footage of the maiden flight.
wish me luck!
chara
Old Mar 30, 2006, 02:37 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
...I thought I'd do some cosmetics and add a simple paint scheme (the "classical", pitts one) to the wings to enhance visibility when it is in the air.
Motor is installed - I wished I had a big nice spinner that I could flange to the prop. It would look so much cuter...
-chara
Old Mar 30, 2006, 06:36 PM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
I hope it will turn !!! You may have to turn it with the rudder and keep the wings level with the ailerons... Maiden will tell !!!
gpw is online now Find More Posts by gpw
Old Mar 30, 2006, 07:47 PM
Crash & Burn is offline
Find More Posts by Crash & Burn
Crash & Burn's Avatar
Palmdale, Ca
Joined Jul 2004
Chara, that is realy cute!!! love its shape and lots of wing area.
good luck on your madin. looking forward to reading and see about it
Rowe
Crash & Burn is offline Find More Posts by Crash & Burn
Old Mar 31, 2006, 03:28 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
hey Glen,
I wonder a bit why it shouldn't.
thrust to weight, wing loading etc. looks all reasonable to me,
so when CG is on the right spot it should fly just fine.
I'm only a bit unhappy with the ailerons actuation. servo is a bit worn out, servo arm a bit too short. but I'll go for it as it is. As you said, "Maiden will tell!"
@Rowe:
Thanks! Tomorrow is the day!
greetings
chara
Old Mar 31, 2006, 08:39 PM
Speedo125 is offline
Find More Posts by Speedo125
Glider guider
Speedo125's Avatar
United States, FL, Sun City Center
Joined Oct 2005
Good luck with the maiden tomorrow Chara! Actually, I guess it's nearly "tomorrow" already in Munich.
What a great looking design! We're headed into town (60 miles) tomorrow. I'm going to stop at Kinko's and print a 12" and a 24" version.
Speedo125 is offline Find More Posts by Speedo125
Old Apr 01, 2006, 12:51 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Maiden Successful!!! :)
Yeeeeeppppeeeee!!!!!! SHE FLYES!!!!!
We had great weather today! A bit windy though but dry and warm, so I gave it a try.
I was realy happy with the outcome of the maiden flight. Very first flight was a bit touchy cause the CG was too far aft. The "rule" that the correct CG position is 1 inch more worward than you have calculated showed once again to be ALWAYS true!
After some batteries-moving and fiddling around with trim positions, expo and dual rates she finally rewarded me with GREAT FUN .
She goes vertical with 2/3 throttle and likes so much to loop, hover and hammerhead that it is a real pleasure to see her fly. The paint sheme by the way (as simple as it is) looks realy beautyful when she flies.
Things that I would change after my first impressions are:
- the "tame" version would do better with a higher wing loading (build it smaller or use heavyer gear) to make it less susceptible to gusts.
Rudder is optional.
Use only small elevator deflections or go with a slightly smaller elevator.
- if you go for the aerobatics version:
link the upper ailerons to the lower ones to make her roll faster. roll rate was rather low. I would say just right for "promenading".
use less to none wing camber to have more symmetrical pitch behavior (a CF rod in the lower wing would be recommended in this case for more stiffness).
We took some videos of the maiden flight. I'll cut them together and post them tomorrow. I think you're gonna like it!
Later I will update the plans and post them too.
Greetings and thanks to all!
chara
Old Apr 01, 2006, 01:17 PM
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Great news....congrats
JAM
JAM is offline Find More Posts by JAM
Old Apr 01, 2006, 01:31 PM
hawk4932 is offline
UH-60 Blackhawk TI
hawk4932's Avatar
Joined Feb 2006
Glad to hear the good news. You should be very proud. Congratulations. I will be looking for the plans when you post them.
Hawk
Old Apr 01, 2006, 03:16 PM
Palmdale, Ca
Joined Jul 2004
Hey chara, CONGRATULATIONS on the maden. I bet it looked good while flying. It is a realy nice looking plane. I'm also looking forward to building one of these using your updated plans.
Rowe
Old Apr 01, 2006, 05:36 PM
windy city is offline
Find More Posts by windy city
Lake In The Hills, Il
Joined Jun 2005
chara... GREAT NEWS!
Congratulations Take a bow! proud Papa. It is so cute!!!
Maybe too soon to ask but. Does it fly as slow and relaxed as you hoped?
can't wait for the video.....
windy city
windy city is offline Find More Posts by windy city
Depron Biplane kestrel2003 Foamies (Kits) 8 Oct 27, 2004 06:32 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? JoshFlies3d Foamies (Kits) 8 Nov 01, 2003 06:57 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
