Old Dec 06, 2006, 03:29 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Well Chara,
right now I have few DIY CD rom motors (single & double) on the bench to test.
Target for the Watt-power you suggest should not be a problem...the problem is me, the pilot.
I was thinking reducing the speed to tame the bird..
frankyfly is offline Find More Posts by frankyfly
Old Dec 06, 2006, 04:36 PM
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Throttle control! That will help. What prop are you putting on tho, is it going to have enough pitch speed?
TeamTEOR is offline Find More Posts by TeamTEOR
Old Dec 07, 2006, 03:34 AM
frankyfly's Avatar
Italy
Joined Sep 2004
TeamT,
I don't know about what pitch speed is going to be but I would to use this bipe for a relaxed park-flyer kind of plane so....I'll try to aim more for a thrust power plant using a large diameter/low pitch prop.
We'll se if it's going to work.
Old Dec 09, 2006, 03:38 AM
frankyfly's Avatar
Italy
Joined Sep 2004
removable BIPIE wings...
Chara, see what I did.
I made some changes to your "bipie". Elastic bands no glue to secure the wings to the fuse, and to be able to unmount the ailerons servo without ruine the fuse.
Old Dec 09, 2006, 03:40 AM
frankyfly's Avatar
Italy
Joined Sep 2004
.....removable wings..
Wings and fuse apart, here we go .....
Old Dec 09, 2006, 06:26 AM
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Frank, excellent work!!! Great idea with the removable wings!
I would need that too because I run into space limitations in my apartment with all these airplanes lying around.
The blue and white finish BTW realy looks best on this plane...
Hope you'll have lots of fun with Bipie!
-chara
chara is offline Find More Posts by chara
Old Dec 09, 2006, 12:01 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank you Chara.
Looking forward for new plans from you...
Frank
Old Dec 11, 2006, 06:12 PM
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Scaled down Version
Here's mine scaled down 25%, AUW with batts 5.1oz, Trying to fing the right motor prop combo. Looking for less than 5 amp 2cell application.
mrfliboy is offline Find More Posts by mrfliboy
Old Dec 11, 2006, 06:16 PM
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Forgot pics
Old Dec 12, 2006, 12:17 AM
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
That looks perfect for a CDRom motor. M.A.E. might be a good place.
Old Dec 13, 2006, 03:15 PM
chara's Avatar
Munich, Bavaria
Joined Dec 2004
very cute! and yes, this thing screams for a CDRom motor.
Old Jan 09, 2007, 11:44 PM
AMA# 851123
brucea's Avatar
Bailey, CO
Joined Apr 2006
Nice Job
Great looking plane and nice evolution.
brucea is offline Find More Posts by brucea
Old Apr 17, 2007, 01:47 PM
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
I'm kinda new to flying/foamies (have built two STC's) so hope this isn't a dumb question.
How do you mount the motor? Glue on a plywood piece as a firewall? Install a 3/8" square stick?
Have a "Nasty" started on the bench but may switch to this one for some much needed training.
Thanks in advance.
Rjay
rdjay is offline Find More Posts by rdjay
Old Apr 17, 2007, 02:16 PM
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Rjay,
there are so many ways to mount a motor that it would be a good idea to start a sticky "tripps and trick" thread for motor different mounts. but still it is the most challenging task in many builds.
it mainly depents on the style of motor you use.
If you go through my build-log pictures at the beginning you will see the way I solved this problem on the Bipie. I have glued two round pieces of hardwood into the nose and drilled a hole into each of them (looks like a pig nose when motor is not mounted). the holes match the distance of the flange holes of the motor-mount, so I can screw the motor to the nose.
hope that helped....
Old Apr 17, 2007, 02:53 PM
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
Chara,
Thanks. I saw the wood but wasn't sure how it worked. What's the approx size of those pieces? Is location important, meaning does the prop shaft need to allign with the hz stab or other?
Thanks again.
Rjay
Depron Biplane kestrel2003 Foamies (Kits) 8 Oct 27, 2004 06:32 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? JoshFlies3d Foamies (Kits) 8 Nov 01, 2003 06:57 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
