Old Mar 27, 2006, 03:40 PM
chara is offline
Find More Posts by chara
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Build Log
"Bipie" - Profile depron biplane cartoon style
PLANS AVAILABLE ON PAGE 4 OF THIS THREAD !
Hi guys, have been a bit lazy the past few months cause I restricted myself on just reading those interesting threads in this forum and letting them inspire me for new projects.
Time to give something back I think. So here is what I was designing a few time ago and finally managed to start the build....
The "Bipie" is designed for low wing loading and some nice and relaxed low speed flying, hence the bipe configuration. It will have rudder, elevaror and aileron control so I may be able to use it also as a moderate 3d trainer.
here come some pics of how I put everything together....
greetings
chara
chara is offline Find More Posts by chara
Old Mar 27, 2006, 03:47 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
...here is the first drawing I made on the pc. might give you a better idea of how it is supposed to look like...
cu
Old Mar 27, 2006, 04:01 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
It's a cutie! Hope to hear a great maiden report!
Short-coupled, lots of control surface and a short nose.... should be interesting
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 27, 2006, 05:58 PM
stafphoto is offline
Find More Posts by stafphoto
stafphoto's Avatar
United States, MI, Chelsea
Joined Aug 2005
Cool little plane hope she flies well for ya.
stafphoto is offline Find More Posts by stafphoto
Old Mar 27, 2006, 06:09 PM
TopFoam is offline
Find More Posts by TopFoam
aka RAMTech-RC
Chandler, AZ
Joined Aug 2005
Looks good to me. I love the Cartoon Fatties.
TopFoam is offline Find More Posts by TopFoam
Old Mar 27, 2006, 09:58 PM
im-sad is offline
Find More Posts by im-sad
Or am I...
Bournemouth, Dorset, UK
Joined Jan 2005
zoom zoom ^^
im-sad is offline Find More Posts by im-sad
Old Mar 28, 2006, 06:20 AM
gpw is online now
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
Very COOL and FUN !!!!! One suggestion , the intersection of two lines at a sharp angle (bottom of fuselage aft of the canopy )gives worries to stress, and breakage ...a slight rounding of the intersection relieves such stresses, providing the plane doesn't break somewhere else ...hahahaa
gpw is online now Find More Posts by gpw
Old Mar 28, 2006, 11:24 AM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Thanks everyone for your positive feedback and the tips.
I use two styrofoam pieces ("styrodur" to be more precize, that is the light blue stuff) of about 2cm of thickness and glue them along the fuselage. That increases stability of the overall construction and allows the use of two more struts to support the upper wing. These struts are reinforced with bamboo skewers on the leading edges and attach pretty nicely to the styrofoam. I wanted it to be rather solid in anticipation of some harder landings I produce on a regular basis.
Here we go with some more photos as the build progresses...
cu
chara
Old Mar 29, 2006, 12:04 AM
windy city is offline
Find More Posts by windy city
Lake In The Hills, Il
Joined Jun 2005
chara,
Looking Good!
I know you are looking for "some nice and relaxed low speed flying"
Hope I am wrong again,But I bet you will have your hands full with this one.
Cool looking plane!
Please keep us posted!
windy city
windy city is offline Find More Posts by windy city
Old Mar 29, 2006, 04:30 AM
hawk4932 is offline
Find More Posts by hawk4932
UH-60 Blackhawk TI
hawk4932's Avatar
Michigan, United States
Joined Feb 2006
I love it. Looks cool. I can't wait to hear how she flies. Good luck with your maiden. Do you plan on posting some plans for it in the future?
Hawk
hawk4932 is offline Find More Posts by hawk4932
Old Mar 29, 2006, 01:17 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Originally Posted by windy city
chara,
Looking Good!
Cool looking plane!
windy city
Thanks windy city!
I can't wait to maiden it. I'll start with small surface deflections, forward CG and quite some expo to see how it behaves in the air. Later I'll go fo the "envelope expansion test flights"
The upper wing ailerons by the way are still fixed. If I find out that more roll power is needed for the crazier stuff, I'll connect them to the lower wing ailerons.
greetings
chara
Old Mar 29, 2006, 02:01 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Hawk
Hawk, thanks for the kind words.
If the weather gods allow, I might be able to maiden her on Saturday. Right now it is rather rainy/windy here in Munich.
If the maiden flight is successful and if someone out there shows interest in building his own Bipie, I will be pleased to post the plans in this thread (free for everyone of course ).
greetings
chara
Old Mar 29, 2006, 02:30 PM
chara is offline
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Here is another build-detail that might be of interest for some of you.
It is a technique that I use to connect surfaces (depron sheets) that are perpendicular to eachother (it also works with other than 90° angles).
Glueing together two surfaces in a 90° angle often gives not enough stability
because of the small contact surface.
I stabilize these kind of connections with integrated balsa or plywood reinforcements. I found out that CA works extremely good on wood. So I CA-glue together two balsa/plywood strips of about 40x6x1 mm to form a T-shape (the ca bond is ultra strong).
Then I cut a slit right through the depron surfaces that have to be connected and squeeze in the wooden T-reinforcement. Of course you should apply some "uhupor" on the T-piece before you squeeze it in and also on all the rest of the contact surfaces. "seal" the slits with clear tape.
This method increases the strenght of perpendicular bonds signifficantly. It works great and is easy to do!
I hope the following pics explain it better than I can do with my poor english...
good night
Old Mar 29, 2006, 04:15 PM
Speedo125 is offline
Find More Posts by Speedo125
Glider guider
Speedo125's Avatar
United States, FL, Sun City Center
Joined Oct 2005
Oh...... I LIKE it! I think I'm gonna have to have one of these! It's going to need some expo' to tame it enough for me, but that's easy enough. Good Job Chara.
Speedo125 is offline Find More Posts by Speedo125
Old Mar 29, 2006, 06:45 PM
mr badwrench is offline
Find More Posts by mr badwrench
mr badwrench's Avatar
Joined Mar 2006
Hey, How big is that thing? Its cute so I assumed it was small...
mr badwrench is offline Find More Posts by mr badwrench
Depron Biplane kestrel2003 Foamies (Kits) 8 Oct 27, 2004 06:32 PM
Looking for small fast profile depron plane Mac8 Foamies (Kits) 3 Oct 12, 2004 07:53 AM
Depron Biplane - My first scratch build pjsmith The Builders Workshop 0 Jun 28, 2004 05:30 AM
Question Whats the cleanest way to mount a B20 to a Profile depron fuselage? JoshFlies3d Foamies (Kits) 8 Nov 01, 2003 06:57 AM
Video of Matt Fritz Depron Biplane... kepople Foamies (Kits) 11 Oct 17, 2003 09:41 AM
