This thread is privately moderated by Ron Williams, who may elect to delete unwanted replies.
Old Mar 27, 2006, 12:04 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
The Gary Wright Mini E3D
Scroll down for the pictures.
A recent building project was Gary Wright’s Mini E3D. The kit was started a few monthss ago and has flown. How was the kit? Just fine except for a few little things involving the fuselage side balsa, the strip wood and a few places that had to be watched to ensure an accurately built framework.
The two fuselage sides were made from very different pieces of balsa. One side was stiff, heavy “C” grain and the other was very light and soft “A” grain. After testing them alongside each other for stiffness, some thin CA was run along the length of the “A” grain piece and hit with accelerator. That stiffened it up considerably. Assembling the fuselage required close attention to keeping it straight and aligned. In spite of that attention it came together a bit off but some soaking in acetone loosened things up and allowed it to be trued. Lesson learned: The stabilizer should be aligned with the wing before the fuselage is finally glued together.
The strip wood was quite curvey but there was enough with the kit and in the backup bins (Thank you, Aerocraft) to overcome what could have been a frustrating experience. Even wood that looked straight when picked soon warped in the summer humidity.
The paper/phenolic tubes that support the aluminum wing connecting tube allowed the wing to be twisted and for the twist to be held long enough to glue in an undesireable warp. Again, acetone loosened things up so the warp could be removed; the situation was carefully watched and controlled on the second wing.
The “cabin” framing was reinforced to keep covering wrinkles out of the corners. The only other modifications were to adjust the servo supports and openings to adapt to Hitec Hs55 servos. This involved some pieces of scrap balsa and a bit of fuss; no big deal.
As the plane neared finishing, a few things came up that required rethinking. It was difficult to balance with the battery (TP2000 Prolite, 3S1P) at the front of the provided ply strip. A ply insert was cut to fill the area up to the underside of the nose with slots for a hook & loop strip to wrap the battery as well as an extension of the hook material. The receiver was difficult to reach when it was mounted all the way to the rear so it was moved up. An RCDirect stick on antenna was installed along the side of the fuselage under the left wing.
The Hacker A20-20L is plenty powerful and with the added battery mounting area, the plane balances easily. The radio is a 5 channel Berg and the ESC is a Hacker X20. Prop is an APC 10x4.7E. The plane flies great.
Ron Williams is offline Find More Posts by Ron Williams
Old Apr 17, 2006, 03:42 PM
cadmanpilot is offline
Find More Posts by cadmanpilot
cadmanpilot's Avatar
Chesapeake, VA
Joined Oct 2002
Ron,
I'm preparing to cover mine now. I didn't have too many build issues but fitting the HS-55 was a surprise. I'll heed your battery placement recommendation and adjust mine if required. I have already added the requisite velcro straps. Thanks for the great write-up on your build.
Paul
cadmanpilot is offline Find More Posts by cadmanpilot
New Mini E3D from Gary Wright Harley 3D Flying 61 Aug 28, 2015 05:40 PM
New MINI E3D from Gary Wright - Build and Fly Harley Sport Planes 797 Sep 06, 2014 02:09 PM
Video Gary Wright Large E3D 2001 Neat Fair Ron Williams Electric Plane Talk 1 Aug 21, 2007 09:11 AM
Wanted Gary Wright Mini E3D kit FredN Aircraft - Electric - Airplanes (FS/W) 1 Jul 20, 2007 01:09 PM
For Sale NIB Gary Wright Mini-E3D and Estar 3D Yak 54 Kits ClipperBill Aircraft - Electric - Airplanes (FS/W) 1 Jul 20, 2006 01:09 PM
