New paint job...I know its not great but I have to have bright colors but I can't see very well.
BTW Thanks for this thread this is my first wing that actually flew worth a crap. I tried a hobbypeople "Wild wing" and it was junk. Only flew 2 twice super twitchy and was only flyable super nose heavy. Mo. |
Joined Feb 2006
i have a couple 250 but no brushed controller. i tried the 4x4 with no luck on the cdrom 2s. does the 250 spin that much better than a 15t brushless? maybe i just have the wrong 4x4 (its black) im sure this 7x5 apc will do it but thought it might be a bit over kill.. im really looking for a floater atm nothing fast yet
if I'm reading you right...
the 15 turn should be great, the 2 cell would turn a 7x5 just fine and if you keep it light, it may just work. You could always cut it down a bit too. A 3 cell is ideal with a 5x5. a 4x4 on a j250 might be a little hot unless you keep it to 2 cells. a 4x2.5 would probably be better. |
Joined Feb 2006
well i have 2s800 and a 2s 2100.. guess i was thinking a brushless would out do a brushed anytime but with the 4x4 and 2s800 it couldnt stay up. unless im missing a setting on the tp 10amp esc to spin faster.. my next step is to get a 3s1000 or 1200 but hope to try the 7x5 on 2s 800 if the rain holds off in the am. thanks again
Try the 7X5 on the 2 cell. On the 3 cell you want the 4X4. Prop UP for less cells, down for more cells. I flew mine on 2 cell with a 6X4 Mo. |
Joined Feb 2006
yup it flies
well im new to flying and did well.. cant say same for my buddy..lol used the 7x5 sure glad it flew.. was wandering if i should give up... guess it was prop size all along. its still pretty fast with a 2cell flying in a ball field lined with trees.. still fun as hell! My next one i can paint and fly myself and not loan out withou fear of a crushing nose. this one still flies but its about 2" shorter in the nose.. hehe i also need to figure out my rates.. that was hard to control when set to high with max travellol thanks guys |
As far as your rates go if you have a computer raido then just limit you end points or use dual rates set from 50 to 70%. If you just have a standard raido then you just move the control rods to the inside hole on the servo arm and/or then outside hole on the control horn. Mo. |
Ok here is a quick vid of mine, and a crash of an alley cat in the back ground :P AnyhowI noticed that mine is not the best at gliding like others have said. It might be the cg is still a bit forward but its not a biggie. Mine is 10oz. RTF and on a 3 cell 1300mah pack my motor only pulls 5A.
Enjoy! Ok fixed the link! Well screw putfile it uploads then gives me an error of not found when I click it. SO here is the link for the video section here. http://www.rcgroups.com/forums/showa...hmentid=825710 |
| Thread Tools | |
| QueenBee: 100" EPP wing build & fly thread | Pjotrrr | Foamies (Kits) | 186 | Jul 29, 2012 03:21 AM |
| Bluecor "Arado Projekt" Build Thread | jimsky | Foamies (Kits) | 82 | Sep 12, 2009 08:43 PM |
| ST Model Wing build thread | scotta | Flying Wings | 20 | Nov 14, 2005 05:01 PM |
| "Thunder" experimental wing build thread | Ryan Archer | Flying Wings | 8 | Jan 22, 2005 04:06 PM |
| Overlord Build Thread - My first wing. | Bernoulli~Bros | Flying Wings | 79 | Aug 15, 2004 05:50 PM |
