Old Dec 15, 2009, 02:36 PM
lee292a is offline
Find More Posts by lee292a
Build, crash, repeat...
lee292a's Avatar
USA, VA, Cedar bluff
Joined Dec 2002
Then by all means move the motor! This is what makes this design so neat. Drag out the old X-acto and chop away till it balances!
lee292a is offline Find More Posts by lee292a
Old Jan 24, 2010, 03:52 PM
Svenne is offline
Find More Posts by Svenne
Joined Aug 2009
I've build this as my first wing it fly's great, but not fast.
I'm using a GWS8x6 prop on an e maxx 2822 1200KV and a 3s1000mah
The prop is not of the pusher type I just reversed the motor.
does that matter?
THX
Svenne is offline Find More Posts by Svenne
Old Jan 24, 2010, 04:58 PM
victapilot is online now
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Not if the convex side faces forward. I had a pusher prop installed as a puller, and you just reverse the rotation with electric - so easy
victapilot is online now Find More Posts by victapilot
Old Jan 25, 2010, 01:20 PM
Svenne is offline
Joined Aug 2009
yeah i thought so wasn't sure doh. After reading a few more pages in this thread and I found my fault : the prop was on backwards the 8x6 letters were facing the sky not the wing as it should be? When it's puller the letters face the sky in front of the plane so when I mounted the motor backwards I also flipped the prop the letters facing the sky again. Should leave the prop on like it was en just reverse the motor Right?
Or else Is it the motor that's not spinning fast enough.
Time to go look @ hobbycity for a lighter faster spinning one,
any sugestions wich will make a good one with ??? Prop.
The wing also folded, I'm thinking to use a spar instead of a piece of depron will add strenght.
GRTZ
Old Jan 25, 2010, 04:37 PM
victapilot's Avatar
Joined Feb 2009
I have a CF2822, not sure if it's same as yours, it's from Hobby City. It is for a 9 or 10 inch prop. I use a 9x4.5 or 10x3.8 from memory (plane is downstairs I'll look again if it's important)
The letters/numbers on the GWS orange props should face the direction of flight.
Hobby City also sells a CF2812 which is much faster, but uses a 7 inch prop.
Old Jan 26, 2010, 12:46 PM
Svenne is offline
Joined Aug 2009
they didn't face the direction of flight, going to build another one and try again.
I have good reason to believe your e maxx is the same as mine 1200KV
going to give it another go. with a larger prop.
Did you use that motor for your wing? How was it mounted?
Grtz
Old Jan 26, 2010, 02:57 PM
victapilot's Avatar
Joined Feb 2009
Grtz
I mean that the letters face direction of flight, no matter if pusher or puller
No, not in a wing, in a flat foam Yak. I'm building a wing like the Assassin with a CF2812. The motor arrived in the mail yesterday, but I want to complete 2 other projects first
Old Jan 26, 2010, 05:48 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Before this turns into confusion.... props can be different. GWS props have lettering in the front (this i am sure of). But some props have lettering in the back.
One can never tell just by the way the lettering is facing. Think of a prop as an airfoil (because it is one after-all). If you look at the prop closely, the Convex side of the prop heads to the direction of travel (which is usually front, but hey, ya never know) .... i hope that helped someone. I always got my props mixed up until it was said to me this way.
Golden Rule: convex side goes front.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Jan 26, 2010, 05:54 PM
victapilot's Avatar
Joined Feb 2009
Right - see my post #918. We were talking about GWS props, but it never hurts to clarify - thanks
Old Jan 26, 2010, 06:06 PM
pdiddyg40's Avatar
Joined Jul 2008
whoops. sorry about that, didnt mean to step on an toes here!
Old Jan 26, 2010, 06:19 PM
victapilot's Avatar
Joined Feb 2009
No sweat - your explanation was better anyway!
cheers!
Old Jan 26, 2010, 06:35 PM
scottflight is offline
Find More Posts by scottflight
scottflight's Avatar
Arvada, CO
Joined Aug 2004
I really like the higher kv motors with a 5x5 prop on these guys, they like a little speed.
Scott
scottflight is offline Find More Posts by scottflight
Old Jan 27, 2010, 12:46 PM
Wrench66 is offline
Find More Posts by Wrench66
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
I've built more than a few of these blue foam wings, and a couple have used the Emax 2812 with APC 6x5.5 prop to go over 70mph.
Heads Up RC http://www.headsuprc.com/servlet/the...ushless/Detail
OR, an even faster setup that is $18 W/18a ESC incl!!
RC Hot Deals http://www.rchotdeals.com/Products/r...18A_combo.html
I am using the faster one on my wing now, with the same APC 6x5.5 prop and Blue Lipo 1300 25c 3s battery I have been over 80mph.
good luck
--Ray
Wrench66 is offline Find More Posts by Wrench66
Old Feb 01, 2010, 02:17 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
having read through the posts, i decided to build the origional 31" in 6mm grey depron and at the moment it has a blue wonder 1500Kv with a 8x4 apc prop, and a 900 mAh lipo, i have not yet maidened it, i am hoping this will fly well, and have a spare emax CF2812 motor and was thinking of putting this on as well, with a mystery 1500 mAh lipo and a 7x4 apc clone prop, but not sure if the 31" is enough for a heavyier better motor, or should i look at a bigger version of this wing
carl
doggit is offline Find More Posts by doggit
Old Feb 04, 2010, 06:15 AM
saltbush is offline
Find More Posts by saltbush
Bendigo, Victoria, Australia
Joined Apr 2009
doggit - how is motor mounted?
Hi Doggit - I wonder if you could explain how you have mounted your motor, and possible post a close-up photo? This would be greatly appreciated.
with thanks,
saltbush is offline Find More Posts by saltbush
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 10:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
