Old Jul 20, 2009, 04:49 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
thank you
carl
doggit is offline Find More Posts by doggit
Old Jul 20, 2009, 04:50 PM
sketchanderase is offline
Find More Posts by sketchanderase
new pic, same plane....
sketchanderase's Avatar
Dayton MN
a 75% wing would make a 23.25inch wingspan just so you know. that would be sclose enough I would think, and its much easier than the 77.45% to get it even closer to the specific dimension....
sketchanderase is offline Find More Posts by sketchanderase
Old Jul 20, 2009, 11:32 PM
himeros is offline
Find More Posts by himeros
O. C. CA
Joined Jan 2005
[QUOTE=you can scale it by just taking the dimensions of each part and scaling them down by a certain percentage. you would take the 31inch wingspan and find the percentage that makes 24inch and then use the same percentage to scale down the other dimensions of the templates.[/QUOTE]
It seem that if I do scale it down that way, the wing tip cord will become very small, or am I just thinking crazy?
Himeros
himeros is offline Find More Posts by himeros
Old Jul 20, 2009, 11:34 PM
Dayton MN
it shouldn't, take all the dimesnions and multiply each by 0.75 and write them down on a small drawing, then measure each out in the template as you would with the normal one. the tip will be smaller, but thats because the whole plane is!:P
Old Jul 21, 2009, 02:28 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Originally Posted by sketchanderase
Dows protection board, but NOT Protection board III
Protection Board 3 is all I can find any more. I haven't had any problems with it.
KFC is offline Find More Posts by KFC
Old Jul 21, 2009, 03:28 PM
doggit is offline
doggit's Avatar
Joined May 2009
just found out that bluecor is also known as styrofoam over here in the uk, and what thickness are these wings, or is it up to each builder what thickness they use
carl
Old Jul 21, 2009, 05:40 PM
Dayton MN
pbIII doesn't have skin on both sides. it is more brittle. I find my blucor at fleet farm.
Old Jul 25, 2009, 09:07 AM
daydreamer is offline
Find More Posts by daydreamer
daydreamer's Avatar
colorado
Joined Nov 2003
Man this plane is super fast. I got a chance to fly yesterday. Dead calm. . I will have to trade out the foam elevons for balsa, Because at top speed I have no input at all, straight ahead thats it.it's a good thing it tracks true. Like i said it's fast. I can keep up with my brothers Stryker. And he uses a four cell battery. with that stock brushless that comes with the plane.
daydreamer is offline Find More Posts by daydreamer
Old Jul 28, 2009, 08:10 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
any tips on building with cdr motors?
captaingeek is offline Find More Posts by captaingeek
Old Jul 28, 2009, 08:58 PM
daydreamer's Avatar
colorado
Joined Nov 2003
Not CDR, but gobrushless. Just keep the windings tight. Do your home work on what speed and amps and prop you want to play with. And thats about it. What this is, is a gobrushless double, wound 5T of 22AWG terminated in wye. it pulls 21amps static with a 6x4 APC prop and a 2200mah 20c 3s1p.
Old Jul 31, 2009, 12:05 AM
USA, CA, Novato
Joined Jul 2008
hey gents. i have the following parts, what size wing do you recommend?
Super Tigre 400 - Maximum constant watts=145 - Suggested Prop sizes:9x3.5SF to 11x7SF
950mah 3s batt
other goodies to go with
Old Jul 31, 2009, 08:26 AM
j4ck4 is offline
Find More Posts by j4ck4
A real WingNut
j4ck4's Avatar
United States, AZ, Chino Valley
Joined Dec 2008
I have built up to a 60" wing with 950Kv motor, wing will go vertical if you can keep it on a line. I used 1250mah 3cell pack with mine, but as long as your using a 3cell you should be okay just shorter flight time, and slightly less power than I had with mine.
These wings are great fun to fly.
j4ck4 is offline Find More Posts by j4ck4
Old Jul 31, 2009, 10:36 AM
USA, CA, Novato
Joined Jul 2008
cool myn's about 60" too. This motor doesn't seem to have much RPM. Perhaps my batteries dead though.
Old Aug 05, 2009, 04:10 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
BluWing Formation Flying
Here's a little clip I put together of my dad and I doing some formation flying with our wings.
Old Aug 05, 2009, 04:39 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
PbIII is what i use because i cant find the "real" blu-cor. I havent had any problems with it, but i guess it is more brittle because it will snap if you bend it one way, yet bend if you push it away from the covered side. Either way, it's still good stuff.
Just my $.02
pdiddyg40 is offline Find More Posts by pdiddyg40
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 10:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
