As promised here is a video of the BluCor wing I built a couple weeks ago.
Also, got some video to see how fast she is Yesterday, will post the results as soon as I get it Dopplered. |
If the problem is actually the shape of your airfoil, your heat gun might be the easiest fix on your wing though. By the way I cut out the f117 from dollar tree foam board, don't have small enough motor for it right now. So it has been shelved for the time being. Cut out and started glueing up a kf foiled B2 from GPW's build thread. They are great flyers also. But, I still have amotor looking for a Nutz to live on. |
United States, IL, Normal
Joined Mar 2008
my 42 in ws fff wing
heres my second fff wing. Didn't get pics of my first. On my maiden flight my wing basically disinagrated in mid air. i guess i was going to fast.lol Had to be going atleast 100 mph. My setup is hxt 2845 2700kv inrunner,60 amp supersimple esc, hxt ubec, hextronix mg servos, 2-2 cell turnigy 2200 mah lipos in series,hitec o5s receiver,master airscrew 5.5x4.5 prop. It was fast. so i decided to build another and beef up the structure alot more. hope to get video by monday. Well heres a couple of pics.I didn't do a good tape job but hey, it will work.
Joined Nov 2005
I think it looks great, should look really good in the air. I also like the half finished beer next to it, ha.
How did you attach the motor mount? Can you get a picture of that? Is it one of the Hobbycity motor mounts? I'll be watching for the video. Ron |
Joined Mar 2008
It is a hobbycity motor mount.I used thin ply sandwiched between top and bottom layers of foam on both sides and and bolted the motor mount to it. I didn't have a good maiden today. Both of my servos came loose and nosed it in. second flight, one of my 7/16 dowel rod broke about 10 inches from the end. But guess what, it still flew. Then my motor shut down in flight. The motor was extremely hot. I never had problems w/ this motor, but I'll figure it out on my next build. I should have another one built in a couple of days.
Thanks for the compliments. Hope to get a video next weekend. I didn't get any footage this time because as soon as i hand launched I gave it half throttle and she went down and i couldn't control it. Here is a pic of the damage and pics of the motor mount. |
Des Moines IA
Joined Dec 2005
Robert |
Alright, here's my version of the FFF Bluecor wing. I'm going to try and maiden it this weekend. Yes, that is a working ram air induction cooling sytem for the internal flight gear and motor. I hope it will work without affecting the flight too much. I won't know till I flyer. I always wanted to build a plane with a hood scoop. What a cool design for a wing. Thanks daydreamer and scottflight for this great thread.
Al. |
I am currently in the proccess of painting mine. I am doing the bottome and top with a center area of metallic silver, the bottom black, the top sides green and blue, and with a red wingtip on both the top and bottom of one wing. I am using enamel spray paints. It has actually eaten the foam some if you get too thick of a coat on it. This has happened in only one spotso I added masking tape to that area and repainted it. The problem I am coming up with is that the paint peels off of the areas where packing tape was used when painters tape is applied. I have found a way to cover the area without using tape, but is there any way to make it so the paint doesn't peel off? like some sort of sealer? or should I sand with steel wool on the packing tape?
| Thread Tools | |
| QueenBee: 100" EPP wing build & fly thread | Pjotrrr | Foamies (Kits) | 186 | Jul 29, 2012 03:21 AM |
| Bluecor "Arado Projekt" Build Thread | jimsky | Foamies (Kits) | 82 | Sep 12, 2009 08:43 PM |
| ST Model Wing build thread | scotta | Flying Wings | 20 | Nov 14, 2005 05:01 PM |
| "Thunder" experimental wing build thread | Ryan Archer | Flying Wings | 8 | Jan 22, 2005 04:06 PM |
| Overlord Build Thread - My first wing. | Bernoulli~Bros | Flying Wings | 79 | Aug 15, 2004 05:50 PM |
