Old Apr 13, 2009, 07:40 PM
jpinn is offline
Find More Posts by jpinn
jpinn's Avatar
United States, CA, Poway
Joined Jan 2006
deleted
jpinn is offline Find More Posts by jpinn
Old Apr 13, 2009, 09:16 PM
Wrench66 is offline
Find More Posts by Wrench66
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
Originally Posted by cjbucher
According to waveoscope, approximately 53 mph assuming 15 degrees celsius temperature. Accurate to plus or minus 2.5 mph.
Not bad for a 9 amp motor...
Oh cool, hey I appreciate that Yeah, that's not too shabby for a little motor like that.
.....hehe 9amps makes for a good long flight even when using a 1000mah 3s and playing near WOT for most of the run.
Ah but the speed bug is in my ear now......won't be long before a much faster motor combo finds it's way over here
many thanks!
--Ray
EDIT.......I just learned that the Emax 2805 red motors can have 2 different KV values.......a 1600kv and 2840kv winds. Well it's obvious I have the 1600KV model so the mystery is solved (mystery was how the hades could a 2800+KV motor only pull 9amps on a 6x3 prop! ).
Wrench66 is offline Find More Posts by Wrench66
Last edited by Wrench66; Apr 14, 2009 at 01:24 AM. Reason: Just discovered real KV of this motor
Old Apr 14, 2009, 05:51 PM
Wrench66 is offline
Wrench66's Avatar
Joined Feb 2008
My boy and I took the wing out again this morning and tried a couple of different setups. The breeze was up just a bit and I wondered how the wing would take to it. Maybe 8-10mph sustained.
For the first run, I substituted the 5x5apc prop we ended with yesterday (this is the one that we ran the speed test with) with a 6x4 Apc prop. The Wattmeter shows 12amps and 137 watts and during the first flight it was noticeably stronger AND had a higher top speed. The wing will climb vertically now where with 5x5 it would pull up and stop after a short time, I wouldn't say it's unlimited vertical but it does slowly keep climbing. Runtime was a bit shorter but I imagined it would be with a higher amp draw...no biggie, still near 6min of practically all WOT.
The second run I replaced the 1000mah 3s with a 1600mah 3s, pushed back on the velcro to keep the CG about the same. The first thing we both noticed was that the wing seemed to be less affected by the breeze, tracking even smoother through all maneuvers and aerobatics we put it through. What impressed us even more was that the wing was handling the extra weight (added 2.1oz for an auw of just over 15oz) of the battery and only needed a couple of beeps of up trim. Vertical climb was not effected and she would just pull up until I told it to come down
As expected, the glide slope was just as nice on the way back in to another great landing. Xlnt, I can ALWAYS use another good windy day flyer
A new wing owner and flier, I have to say I'm hooked!
--Ray
Old Apr 17, 2009, 12:13 PM
daydreamer is offline
Find More Posts by daydreamer
daydreamer's Avatar
colorado
Joined Nov 2003
I can't believe, when i first posted this wing in 2005 it would be so popular. This was just one of those things i figured i could give back to rcgroups where i learned so much. then behold scottflight took over and made a great build thread. We live in the same area just never met. maybe one day when it gets nice we can hook up and see who can build the fastest one. that would be cool. I curently wound a motor thet is a double gobrushless that puts out 20oz thrust 6x5.5 prop 225watts 23amps i would like to put on a new wing and really test the structure i dont know how fast but when this things turning it sounds like a ducted fan. So Sott we should fly some time
daydreamer is offline Find More Posts by daydreamer
Old Apr 18, 2009, 07:51 AM
scottflight is offline
Find More Posts by scottflight
scottflight's Avatar
Arvada, CO
Joined Aug 2004
Daydreamer! Yep, looks like a lot of people have had good success with your design. We should definitely fly, though it looks like we will both be snowed in this weekend. Snow and work are really getting in the way of my flying! I'm in Arvada.
scottflight is offline Find More Posts by scottflight
Old Apr 19, 2009, 12:10 AM
daydreamer's Avatar
colorado
Joined Nov 2003
Yeah. Scott I Agree, The weather is beautiful, but for flying it's another. How is it where you fly? Is there alot of obsticles? or is it pretty open? I still fly at the northglenn open space, on a 112th. Been there now for i think 13yrs or so. i did get the plane finished to day. She's going to be hot. 2200 3s1p running the above mentioned motor i may change to a 6x4 though for speed
Old Apr 20, 2009, 07:28 PM
topher is offline
Find More Posts by topher
denver colorado
Joined Jan 2004
Hey daydreamer, Ijust noticed you are close to me also. We have been flying at the Thornton rec center soccer fields for about 13 years also.Maybe we have met before? We just got kicked out of the park by the city so I am on the hunt for a new spot to fly.Where is the Northglenn spot? Maybe we can fly together sometime?
topher is offline Find More Posts by topher
Old Apr 21, 2009, 06:10 PM
daydreamer's Avatar
colorado
Joined Nov 2003
it's basically 112th and pecos you can't miss it i'll probably be there saturday if it's nice. I've only flown twice at the rec center. to many complainers there. I see it worked. that's to bad. heres the new plane 13oz AUW bad pics though
Old Apr 23, 2009, 04:23 PM
Wrench66 is offline
Wrench66's Avatar
Joined Feb 2008
#2!
I've been having such a great time this past week with my orig wing, I flew 5 batteries through it last sunday at our field, that I decided to build a few more for some friends who wanted one soon after tossing mine around a bit
Daydreamer, Scottflight........xlnt plane, that airframe is so right, thank you!!
here's the video of me FINALLY figuring out how to launch it successfully EVERYTIME LOL LOL
Over the shoulder wing launch (0 min 43 sec)
Pictures below are of #2 being finished up, just before the winglets and radio go on.
--Ray
Old May 06, 2009, 05:33 PM
Kurpal is offline
Find More Posts by Kurpal
Joined Nov 2006
Just finished the build. Here is my set up:
1700 kv blue wonder
Tower pro 12 amp ESC
1300 mAH 3s zippy battery pack
5x3 --> 6x3.5 master air screw prop.
AUW: 9.45 oz
Planning on painting this plane after I know I can successfully fly it. I started by gluing the leading edge of this plane together contrary to plans, but I used gorilla glue and the glue loosened the tape while it was drying. The sides don't match each other quite right but I will see if it impacts performance. I just couldn't come to terms with not gluing a plane together.
Kurpal is offline Find More Posts by Kurpal
Old May 06, 2009, 06:52 PM
daydreamer's Avatar
colorado
Joined Nov 2003
Don't worry there is no need for glue, on this plane. At all. It is very durable, with out it I've crashed mine going full speed, and just ended up with a crinkled up nose, If you glue it you'll end up with a brittle front nose, that will explode on impact. With it just taped up, you could just stuff it with tissue, to pop it back out, put a little more tape on it and your good to go.All in about five minutes.
Old May 08, 2009, 07:54 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
Blu-Wing Float
I've been using my 5-foot model for just about everything: combat, soaring, formation, night flying, and now... float flying.
It's such a versatile and rugged design, I can't stop adapting it. Weather was bad today, but I'm hoping nature will cooperate so that I can maiden it tomorrow.
KFC is offline Find More Posts by KFC
Old May 17, 2009, 06:54 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
How do you stear that in water?
cjbucher is online now Find More Posts by cjbucher
Old May 18, 2009, 12:08 PM
j4ck4 is offline
Find More Posts by j4ck4
A real WingNut
j4ck4's Avatar
United States, AZ, Chino Valley
Joined Dec 2008
I built another last week maidened Saturday about 7:00pm cst, flies great with a bp21 and 9x6 sf prop on a 1250mah rhino 2s 20c pack and a 25amp esc. Going to try and get some video of her this week.
j4ck4 is offline Find More Posts by j4ck4
Old May 18, 2009, 04:20 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
The elevons act like air brakes when I have them on high rates. I just push the stick in the direction I want the plane to turn. It flies pretty well in calm weather, but tends to be unstable on the water when its windy.
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 10:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
