Old Jan 17, 2009, 01:50 PM
MYHELIGUY is offline
Find More Posts by MYHELIGUY
BUILDIN-FLYIN-CRASHIN-FUN
Michigan
Joined Feb 2008
yes lowes, its the new stuff, PBIII 3/16" thick,yes its kinda just quick circle wrapped,i had to hunt threw the bundles.
MYHELIGUY is offline Find More Posts by MYHELIGUY
Old Jan 17, 2009, 01:51 PM
Michigan
Joined Feb 2008
Originally Posted by j4ck4
The KFM from what I read is a real slow flyer, I have one on the workbench now about got it ready for electrics. Gene Bond also has a bluslo wing, http://www.rcgroups.com/forums/showthread.php?t=207171
Check it out, I built one havehad alittle trouble getting the cg set but I built a cg checker yesterday.
can you post pic of CG checker ,thanks--have you built this gene wing ? details ?
Old Jan 28, 2009, 02:30 PM
j4ck4 is offline
Find More Posts by j4ck4
A real WingNut
j4ck4's Avatar
United States, AZ, Chino Valley
Joined Dec 2008
Yes I got it at Lowes. Sorry I took so long getting back to you. If you catcvh it when they first pu ti out it is in good shape if it's been sticking out in the aisle it gets messed up quick. I'm finishing up a 60" version of this wing now. Will probably wait until the snow & ice is gone to maiden it. I did fly my kfm wing again this morning and fixing to go run another bettery pack through it. temp is 27 deg here in Tulsa today, but winds are calm. Try to post the video of the kfm L8R today.
j4ck4 is offline Find More Posts by j4ck4
Old Jan 28, 2009, 05:24 PM
j4ck4 is offline
A real WingNut
j4ck4's Avatar
Joined Dec 2008
MHELI
Here are a couple pics of the cg tester I built one by itself the other with the 60" Zagnutz I am finishing up now.
Old Jan 28, 2009, 05:39 PM
j4ck4 is offline
A real WingNut
j4ck4's Avatar
Joined Dec 2008
MYHELI
Yes I built Gene's slo wing but as I said in an earlier post I never got it to cog out correctly. I don't think it was anything to do with Gene's design thourh because I have built two of his and GPW's b2 not quite scale stealths and they flew fine.
I did get a chance to shoot some video today of my kfm zag so wilol post it when I get it edited a little more, Have to excuse the cameraman had to have my 12 year old grandson shoot it for me.
Old Jan 28, 2009, 10:37 PM
Michigan
Joined Feb 2008
j4ck4 ,
yeah ,video good idea.thanks for replies. i'm into considering which wing to build first out of about 5 diff ones,i thought the zagnut,then this kfm,need one to float and fly slow for now,48" ws is ok for this PBIII .got a himax gearbox with himax 2015/4100kv 110watts 62grams on 2 cell lipo 12x8 prop.
Old Jan 28, 2009, 11:36 PM
j4ck4 is offline
A real WingNut
j4ck4's Avatar
Joined Dec 2008
Check post 753 ther's a link to a video I have on youtube of my 48" Zagnutz last couple days of life there. and the video I shot today of my kfm wing should be available shortly.
Old Jan 30, 2009, 06:53 PM
j4ck4 is offline
A real WingNut
j4ck4's Avatar
Joined Dec 2008
Wow
As I just posted over on the kfm wing thread I maidened the 60" wing inthe pics above in about 10mph winds today and it is quick and agile. First plane I haven't crashed at least once on a maiden. Hit the throttle tossed it up into the wind and away it went, loops great turns on a dime. Thanks again for your build threads and all your help guys. I am deffinitely a WingNut
Old Feb 15, 2009, 12:52 PM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
I'm still getting lots of fun out of building smaller versions of this basic design using EPP and carbon fibre.
I've built a new one. It's 9oz all up weight and 26" wing span with a 2 cell 1200mah battery accounting for a fair proportion of that and a EMAX CF2805 2840KV. Seems to climb vertically on a 5inch prop and it's supposed to take a 6 so i'm happy with the performance so far.
teslahed is offline Find More Posts by teslahed
Old Feb 15, 2009, 04:52 PM
topher is offline
Find More Posts by topher
denver colorado
Joined Jan 2004
Just started building my next 16" micro wing.This ones got a dons rc "wicked junior" 3200 kv outrunner. Should hit about 100 mph! My other one with a medusa motor does about 70
topher is offline Find More Posts by topher
Old Feb 15, 2009, 05:39 PM
topher is offline
denver colorado
Joined Jan 2004
A close up of the homemade mount, and sitting next to its "brother"
Old Feb 15, 2009, 07:37 PM
Murman is online now
Find More Posts by Murman
Go Panthers!!
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
What size lipo will you be using? I built one of these 16" wings with a 12mm inrunner and 500mAh lipo and it flew ok, but adding the Wicked Jr with a 30a esc and 1000 to 1200mAh 3s lipo should turn it into a brick. I used the Wicked Jr on a 22" wing and I had to fly it pretty fast at all times just to keep it airborne. I hope you have success, but I don't see your wing having enough wing area to stay in the air very long with the weight of that motor and a lipo and esc big enough to support it.
Murman is online now Find More Posts by Murman
Old Feb 15, 2009, 08:10 PM
topher is offline
denver colorado
Joined Jan 2004
Actually I am copying this setup from a buddy and have seen his wing fly. It pulls 10 amps running a TP 730 3s. Flight times are a little short.About 2 1/2 to 3 minutes, but that thing absolutely rips! Useing CC 25 amp esc. cam 4+3 prop. Weight without batt hopefully will be about 5 oz,s
Old Feb 19, 2009, 08:02 PM
theslacker44 is offline
Find More Posts by theslacker44
Joined Dec 2006
This is my 16 inch wing with a Dons Wicked 3200KV motor, that has the same power system that Topher is using. My wing weighs 4.2 without battery 6oz with a 720 3s. The wing actually fly's pretty good even with the high wing loading. Also here is a pic of my newest project...a fully molded 32 inch wing (almost done).
theslacker44 is offline Find More Posts by theslacker44
Old Feb 19, 2009, 08:16 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
Man that is sweet. I like it. And this is out of blue core? I need to make one of those. But someone needs to help me with the way to make it so nice.
More Trim is offline Find More Posts by More Trim
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 11:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 09:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 06:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 05:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 06:50 PM
