Old Dec 10, 2008, 03:17 PM
cjbucher is online now
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Hmmm. I haven't had that problem. I did the normal 1/4" blue cor with a top and bottom piece. Somehow that hollow shape along with the spar and some bamboo skewers made mine very rigid. My power system gets my plane to around 65 mph in level flight and up to 80 in a dive. Never had a flutter.
It's weird how the 1/4" foam is so flexible but when you put 2 pieces together with a spar in the middle, it becomes quite rigid. Must be an engineering principle in there somewhere...
Maybe solid foam allows for a lot more flex?
I also built an "Ultron" 3D plane that's a full fuse design. Amazingly strong and rigid design. Love the way it flies. http://www.rcgroups.com/forums/showt...ghlight=Ultron
cjbucher is online now Find More Posts by cjbucher
Old Dec 10, 2008, 06:59 PM
more_eggs is offline
Find More Posts by more_eggs
Joined Dec 2008
thanks heaps guys..
hmm im a little worried about too high an amp draw as the battery is a standard pack out of a honey bee king 2..so its only rated for 10c at 1000mah...could it cope with the 4.75x4.75?
ill probably have to pick up another pack anyway so wat sort of mah and discharge rate are we talking?any suggestions on a cheap source?
sorry for all the q's..bit of a nub wen it comes to lipo tech etc..
cheers,
matt
more_eggs is offline Find More Posts by more_eggs
Old Dec 10, 2008, 07:16 PM
Joined Dec 2008
Originally Posted by smkn951
what to do to get rid of flutter.
i have cf across already, taped leading edge. but at 10 seconds into a level ft flight it'll vibrate and flutter.
power is donsrc wicked jr, 3s 1300, 30 amp esc.
any suggestions on making it stronger? fg i have melted the test foam i have
BTW its made of 1/2 blue cor sanded to an airfoil.
TIA
one thing that i hav found in the past with planes and wings wen i have tried to shape them myself is that unless the wings are very very similar in shape, which is hard to do wen jus sanding and checking it by eye, that the wings will "flutter" in flight.. im not second guessing ur build quality, jus explaining wat has happened to me before..
one other thing...take a sheet of paper for example...hold it out flat and it will bend and flop down...do the same thing again but this time put a curve or "arc" in it wen u hold it...much more rigid and it doesnt flop..i think this applies to the wings that use 2 sheets with a spur as they have the same curve built in the design hence making it much more rigid...
matt
Old Dec 11, 2008, 09:49 AM
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Originally Posted by more_eggs
thanks heaps guys..
cheers,
matt
10c 1000mah really can only handle 10 amps. You might get away with the 4.75x4.75 but try not going full throttle too often. In any case, that battery will age fast.
matt
Um, that's what I said.
Old Dec 12, 2008, 09:53 PM
in2skimn is offline
Find More Posts by in2skimn
in2skimn
axworth Ga
Joined Apr 2005
blue core wings
guys hears a great site that help me with my 32" wings.http://home1.gte.net/texhills/page3.html
easy instuctions. any guestions feel free to ask.
chuck
in2skimn is offline Find More Posts by in2skimn
Old Dec 24, 2008, 01:45 PM
j4ck4 is online now
Find More Posts by j4ck4
A real WingNut
j4ck4's Avatar
United States, AZ, Chino Valley
Joined Dec 2008
My Wing
Hey jI just maidened my first attempt at building a wing. With a few tweaks on my cg I got about an 8 minute flight out of it in 38 degree weather with variable winds of 6-15 mph all over the compass.
This is the first scratch build I have flown, just got started building a couple weeks ago and I love it. You guys keep the good build threads comming.
j4ck4 is online now Find More Posts by j4ck4
Old Dec 24, 2008, 10:45 PM
sketchanderase is offline
Find More Posts by sketchanderase
new pic, same plane....
sketchanderase's Avatar
Dayton MN
looks cool, ill try one when i have time...
sketchanderase is offline Find More Posts by sketchanderase
Old Dec 29, 2008, 09:00 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
well my 32"first flight went well yesterday,great flayer i had used a BP 21 out runner on this one with a cut down 10x4 prop to 7x4 @ 3 1/4 throttle the wing would take off from a vtol position from ground but @ full stick in the air it will do about 30miles max very smooth but speed is not what i was looking for i had a 3s 2250 25c it only pulls about 17amp the plane is 1lb even and i did not thing my JGF 350 would do the job.so back on the drawing board to see if i can figer dif motor.
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Dec 29, 2008, 11:42 AM
Murman is offline
Find More Posts by Murman
--Fly By Night--
Murman's Avatar
USA, NC, Huntersville
Joined Jul 2008
Originally Posted by FASTBEN
...used a BP 21 out runner on this one with a cut down 10x4 prop to 7x4
Most of the thrust from a prop comes from near the tips. When you cut 3" off of your 10x4 you eliminated most of the "sweet spot" on the prop. If I were you I would find a true 7" prop to try before you give up on that motor.
Murman is offline Find More Posts by Murman
Old Dec 29, 2008, 01:21 PM
FASTBEN is offline
Cumulus Altimus
FASTBEN's Avatar
Joined Feb 2002
you are abselutly correct i will do it and try,
ben
Old Dec 29, 2008, 03:36 PM
More Trim is offline
Find More Posts by More Trim
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
I agree don't cut the prop. IT will for sure not preform right at all. I have tried it. Not good.
More Trim is offline Find More Posts by More Trim
Old Jan 02, 2009, 12:33 PM
pburt1975 is offline
Find More Posts by pburt1975
pburt1975's Avatar
Chester Va
Joined Sep 2007
I'll be running a 2408-21 on mine in puller config using a 1500mah 3s (20c) battery.
What size prop would you suggest?
here' some pics of where we are now... 32" ws just like the original plans.
pburt1975 is offline Find More Posts by pburt1975
Old Jan 02, 2009, 02:18 PM
Wrench66 is offline
Find More Posts by Wrench66
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
Hi PBurt,
That BP21 has a pretty good following in our club.....lots of them running in the 7x5 area with great thrust and decent run times (using about the same mah battery you have there) of 7-8min. Use at least a 25a speed control or can drop to a 20 IF you have good thr management skills (I do not).
Most the planes and wings we fly are in the same weight class as your wing so this should help
--Ray
Wrench66 is offline Find More Posts by Wrench66
Old Jan 02, 2009, 03:00 PM
More Trim
More Trim's Avatar
Raleigh NC
Joined Jan 2007
Hey that thing is pretty sweet. Did you go by some sort of plan. And is it something can get?
Old Jan 02, 2009, 05:10 PM
Murman is offline
--Fly By Night--
Murman's Avatar
Joined Jul 2008
The ep8040 is my favorite prop for that motor on 3s.
Here is some great prop data for the bp21.
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 10:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
