Joined Dec 2008
hi there..
ok so say i were to be making a wing off this design out of coroplast (i live in australia and cannot find anything equivalent to blucor), scaled down to 22'' wingspan...and i ran this motor http://cgi.ebay.com/ws/eBayISAPI.dll...m=160302682156 with a 2s 850mah lipo... wat are the chances of it actually flying up and away as opposed to directly into the ground infront of me? any help would b great and im sorry if this kind of question has become extremely repetative...im just a little new to the whole plane,brushless and propellor scene... cheers, matt |
ben |
Joined Dec 2008
hi guys...
so i decided to go with the paper covered stuff and make a 31''....man was the paper annoying to get off..soaked it and then rubbed it all off.. bought one of these puppies: http://cgi.ebay.com.au/ws/eBayISAPI....m=120340805662 which i shall run with a 4.75x4.75 APC prob on both a 2s 800 mah and a 3s 1000mah...i also have a smaller 5x3 and a 4.2x2... how do u think i will do for speed, thrust and amp draw? cheers, matt |
DUNDAS CANADA
Joined Feb 2006
I am using 99.9 % pure Methyl Hydrate liquid to remove the paper from the foam boards. It is available in the Canadian Tire stores. I am sure that the hardware store in your area will have it. As well The Home Depot or Lowe’s might have it. Splash some liquid onto the board and with the rug spread on whole sheet. After 20 seconds the paper should peel off easilly. Laddie. |
Raleigh, NC
Joined Sep 2004
The 4.75x4.75 prop on a 3s is your best bet: It will draw 13.1 amps and have a speed of approx 90 mph with a thrust of 13 oz. Personally I think the speed estimate is a bit high - probably will be more like 70 mph when you take air frame drag into account. The 5x3 prop will give similar thrust but only go 60 mph at 8 amps The 4.2x2 would really be dismal at around 42 mph at 5.5 amp draw and only 10 oz of thrust. Don't bother with the 2s battery unless you plan to run a much larger prop. An APC 7x5 would work with a 2s battery (17 amp draw, 17 oz thrust but only 53 mph) Chris |
| Thread Tools | |
| QueenBee: 100" EPP wing build & fly thread | Pjotrrr | Foamies (Kits) | 186 | Jul 29, 2012 03:21 AM |
| Bluecor "Arado Projekt" Build Thread | jimsky | Foamies (Kits) | 82 | Sep 12, 2009 08:43 PM |
| ST Model Wing build thread | scotta | Flying Wings | 20 | Nov 14, 2005 05:01 PM |
| "Thunder" experimental wing build thread | Ryan Archer | Flying Wings | 8 | Jan 22, 2005 04:06 PM |
| Overlord Build Thread - My first wing. | Bernoulli~Bros | Flying Wings | 79 | Aug 15, 2004 05:50 PM |
