Old Apr 29, 2011, 10:34 AM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
KFC,I love the NASCAR spin-out at the end
_OZ_ is online now Find More Posts by _OZ_
Old Apr 29, 2011, 11:28 PM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
+ 1,000 I wish I would have seen that in person.
ckreef is offline Find More Posts by ckreef
Old Apr 30, 2011, 02:20 PM
daydreamer is offline
Find More Posts by daydreamer
daydreamer's Avatar
colorado
Joined Nov 2003
Man! hobbycity saves you alot of cash. 6 gws props at LHS = $9 one BL motor comparible $40 and 750mah lipo $35 Total $84. Hobbycity $24. Now thats worth the wait in the mail : ) Sorry guys just had to share my Joy...
daydreamer is offline Find More Posts by daydreamer
Old May 03, 2011, 05:10 PM
fishon2 is offline
Find More Posts by fishon2
Joined Mar 2010
Have any of you guys tried making an EDF wing yet?
fishon2 is offline Find More Posts by fishon2
Old May 05, 2011, 10:54 PM
sleverage is offline
Find More Posts by sleverage
Unregistered User
Calgary, AB
Joined Jan 2009
Technially not a bluecor wing, as I made this out of Cellfoam 88. All I could find local here. This is my first wing, my first wing build, my first foam build at all really. Been flying an easystar for a few years now and keep seeing these wings and they peak my interest.
One thing I know I made a mistake on was the motor is too far back, making it hard for me to balance with the battery pack having to be so far forward on the nose. I will probably fix that if (more like when) it breaks off. I do also plan on sinking the battery pack and RX into the fuse on the next build, but i was too unsure of CoG for this time...
I set my radio up for elevon mixing and verified proper movement of control surfaces. I set some up elevator trim as I have seen mentioned in a few threads and comments. Only thing left now is to try it I guess...
Any other tips for a first time wing builder/flier? I am not expecting this first build to last long, but I could get lucky and not destroy it on the first launch.
Pics attached
thanks!
steve
sleverage is offline Find More Posts by sleverage
Old May 05, 2011, 11:57 PM
StevoRC is offline
Find More Posts by StevoRC
SoCal SlowFlyer
StevoRC's Avatar
United States, CA, Glendale
Joined Nov 2009
Nice job! Good luck with the maiden!
StevoRC is offline Find More Posts by StevoRC
Old May 06, 2011, 10:02 AM
fishon2 is offline
Joined Mar 2010
What motor are you using? It looks like a really big batter. You shouldn't have any CG problems, just put the batter as far forward as possible and give the elevons 15% up as the center for your trim.
Old May 06, 2011, 11:11 AM
daydreamer's Avatar
colorado
Joined Nov 2003
Would any one be interested in buying wing cores of this wing. Probably $15+ shipping I've cut a few before but for my enjoyment only. And it was using bead foam , I will cut these with blue foam. Just checking before I try and cut them. I took the original airfoil from my original plan and used it. Daydreamer.
Old May 06, 2011, 12:35 PM
Unregistered User
Calgary, AB
Joined Jan 2009
Its a tower pro motor I think. says 2410-9 on it and thats about it. I have a turnigy plush 10A esc for that. the prop in the pics is a busted prop that was just on there temporarily, but normally its a 6x4. the lipo is a 3s 1800
This is stuff I just had around... not really in the budget to buy new things so its a matter of tuning the airframe to match my gear instead of the usual other way around. I have 4 of these motor and esc so it would be nice to be able to use them.
My AUW with that battery is 433 grams...
Last edited by sleverage; May 06, 2011 at 12:43 PM. Reason: add weight measurements to post
Old May 06, 2011, 12:38 PM
Unregistered User
Calgary, AB
Joined Jan 2009
if you would ship them to canada and could provide pics of an example of your stuff, id definitely consider it. Problem I am running into is a lot of the materials are simply unavailable to me in Canada. Even finding Depron is like trying to find a pot of gold at the end of a rainbow... so elusive. This Cellfoam 88 build I did is not impressive in terms of structural strength so alternatives would be welcomed.
steve
Old May 06, 2011, 03:52 PM
daydreamer's Avatar
colorado
Joined Nov 2003
I could do that. It would probably be more exspensive than to ship in the states/ Lower 48. I want to cut some practice ones 1st though. So I know they'll be good. I will post them when all is ok.
Old May 06, 2011, 06:06 PM
Wrench66 is offline
Find More Posts by Wrench66
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
That motor isn't going to spin fast enough to use that prop on.......the KV is only 900 or so and on 3s those will normally spin a 10-11in prop. You will want a motor in the 1800-2000kv range, and as a bonus the motors will prolly be a little lighter........the 2410-9 is a little over 60grams and the faster, smaller 1800kv I use on my wings are approx 35 to 40grams.
You will love that wing
Wrench66 is offline Find More Posts by Wrench66
Old May 06, 2011, 08:56 PM
Unregistered User
Calgary, AB
Joined Jan 2009
oh ok... that sucks. it does seem to have some decent thrust on the 3s, probably burn it out if I keep using it the way it is... however being that i have four of them I may just try it with this motor while i wait on an order from hobbyking... since I can't get anything like that local.
I do have the 10x4.7 props that I was using with these motors for a multicopter but I thought it would be ridiculous to cut 10" out of the wing to fit that giant prop :P
this whole motor/prop/battery/esc sizing thing is still new to me so hope I can get a proper motor so I can fully enjoy this thing
THanks Wrench66
Old May 06, 2011, 10:37 PM
fishon2 is offline
Joined Mar 2010
THanks Wrench66
Here is a thought. Go to hobbypartz and put 64mm edf unit on it. It enhances the planes performance 10 times.
Old May 07, 2011, 07:44 AM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
Sleverage, good luck on the maiden. I find the initial flight is always the trickiest until you get it dialed in. Be prepared for a wacky 1st flight. Until it's dialed in it can be a handful. If you can get a helper to move your trim buttons why you control that 1st flight is always helpful especially if it is way off.
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 188 Feb 27, 2015 10:15 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
