Old Mar 26, 2006, 05:45 PM
scottflight's Avatar
Arvada, CO
Joined Aug 2004
Bluecor Wing Build Thread
Alllrighty then.
Well, I decided that I really needed to post this build. I have tried a lot of stuff in the past couple of years and I’ve settled on a very few designs that are all around great, I’m kind of performance-picky. The one that gets the most flight time for me is one that is not only fun and aerobatic, but it can fly a long time on a charge, in the wind, and take a beating too. Did I mention cheap?
So here it is. This flying wing is one of the best I’ve ever had for all around conditions. And I’ve had a lot. Ezipper, Eraider, Slofly’s, PCW, Unicorn, Zagnuts, Superfly, my own designs, etc….
Disclaimer! this was a general design that someone else had posted some time ago. It was originally made for a speed 400, but I stumbled across the perfect build/set up for this one. Since this has been my hanger staple for so long I just had to post the build. But first, I’m going to show a video of how it actually flies so you can decide for yourself. I guarantee that if you build this one, you will have an absolute ball and there will be no disappointment. Stick with the gear I recommend, even though it is pretty forgiving.
So for those interested, here’s the stats and setup…
What: bluecor flying wing
Wingspan: 31”
Weight: 10-11 oz.
Motor: 15 turn Cd motor, I use a Lensrc 20mm, but really any CDrom 15 turn motor will work with this setup
Prop: 5x5 zagi (6x4 works too)
ESC: CC10
Battery: TP 1320 3 cell
Servo: 2x HS55
Power: Pulls about 5.5 – 6.5 amps
Speed: Zippy
CG: Start at 7” or less from the nose, and play around, it’s not super sensitive, but it does make a difference if you don’t pay attention. It will fly well even if very nose heavy. Don’t be too afraid to add a half oz of nose weight, I did to get to 7.25" and found it to be fantastic. (or move the motor farther towards the nose by cutting further.)
Cost: Come on it’s bluecor with a CD motor, make three, you’ll want three anway
Wind: will fly in 20+mph wind easy, and it’s a BIG kick too, the thing will rocket straight up with a strong gust. Wind is very fun. No wind, is very fun.
Flight times: I’m getting well over 20 minutes and I get tired and go home, the last two times I didn’t even run down the battery all the way
Durability: Completely bashable, This thing has taken many beatings. I’ve destroyed more than one pack by doing inverted pile drivers and still kept the airframe. I hit a pole today which stopped it nicely, no problem vertical landing. My buddy and I want to do some combat with them. They may not stay looking nice with abuse, but they still perform great. Besides, it’s easy to tape.
Time to Build: 2 or so hours total for a first timer, about an hour+ for #2.
Difficulty: Easy as can be, you’ll see how crooked I build mine, all the gaps, etc.
Field area: Med Sized park, I fly in a small park and stay on top of it.
Glide: good enough that I want to build a sloper out of it, that’s next though.
scottflight is online now Find More Posts by scottflight
Old Mar 26, 2006, 05:46 PM
Arvada, CO
Joined Aug 2004
Video
Ok, here's the video, let's see if I can get it to load...it's quicktime sorry, that's all I got on the camera.
Try the videos here...
http://www.putfile.com/scottflight
Also, they are kind of big files... 23mb and 13mb....for those who are interested.
Old Mar 26, 2006, 07:13 PM
bass3587's Avatar
Arlington,Texas
Joined Jan 2005
Post it on www.putfile.com
bass3587 is offline Find More Posts by bass3587
Old Mar 26, 2006, 09:35 PM
Arvada, CO
Joined Aug 2004
Next Step
Next make an elevon template and cut out two elevons. I make my elevons form blucor and taper from about 2.5” wide at the wingtip to 1.5” wide near where you cut off for prop clearance. Trim the bottom side edge that mates with the trailing edge of the wing to 45 degrees.
Now cut out the spar spacers. Just make a strip of blucor that goes from a height of 3/8” to ¼” and is as long as the panel.
Old Mar 26, 2006, 09:44 PM
Arvada, CO
Joined Aug 2004
Great now you’ve got all the major frame components set up. Make the wing cores next. First trim the leading edge of all 4 panels at a 45 degree angle. Then trim off the trailing edge at a shallow angle. I use a long utility knife as shown.
I use packing tape for just about everything in the build. Now take a strip of packing tape and place it along the leading edge of the one panel. Put the other panel next to it, leading edge to leading edge and press down.
Old Mar 26, 2006, 09:51 PM
Arvada, CO
Joined Aug 2004
Fold the wing over so that you pre-crush the leading edge.
Next hot glue in the spar strip. Glue it about 25-33% from the leading edge all the way down. Close is good enough, really. I think I did 25% in my last one.
Old Mar 26, 2006, 09:56 PM
Arvada, CO
Joined Aug 2004
Now put a strip of tape along the trailing edge and get ready to hot glue. Put some glue along the spar strip and fold over immediately and tape the trailing edge up. You’ll find that the glue will not attach to the upper wing panel for the whole length. That’s ok. Not so close is good enough. It will bulge some near where the center will be. Cool, now do the other panel.
Old Mar 26, 2006, 10:00 PM
Arvada, CO
Joined Aug 2004
Then you need to tape the panels together. One strip down the middle on both the top and bottom. You can add some tape to the nose if you want. It is best to wait on adding nose tape until after you have painted as the paint will pull off the tape pretty easy.
Trim off the cores where they meet if needed to get them to come together straight.
Check the wing for warp or any crookedness. Try to fix it if you need to.
Old Mar 26, 2006, 10:08 PM
Arvada, CO
Joined Aug 2004
Tape on the elevons. I like to use one long strip and two short ones underneath
Old Mar 26, 2006, 10:11 PM
Arvada, CO
Joined Aug 2004
Next I glue and tape a small scrap piece of blucor on the bottom of the wing to prevent the motor from scooping up dirt on the landings...when I choose to land on the bottom side that is.
Old Mar 26, 2006, 10:16 PM
Arvada, CO
Joined Aug 2004
Next make the cutout for the motor and prop clearance, I like to tape up again after I cut out a big section. I just cut one layer of the blucor for motor mounting. I use a slofly tube mount and tape and hot glue it to the blucor. Works great and I’m sure it saves the motor at times.
Old Mar 26, 2006, 10:19 PM
Arvada, CO
Joined Aug 2004
Next I cut out the servos. I measure about 6” down from the nose and 4 inches from the center. Or put them wherever you want. Doesn’t really matter that much.
Old Mar 26, 2006, 10:21 PM
Arvada, CO
Joined Aug 2004
For the control horns, my friend Jared has the best solution. Make a couple of ply horns, make a slit in the elevon and epoxy them in. Works great and really strong. Use an exacto knife to form t he holes for the music wire.
Next I like to paint the top side. The bottom I stripe with black polytape
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 186 Jul 29, 2012 03:21 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 08:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 05:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 04:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
