Old Mar 26, 2006, 11:42 AM
_Pattern_Man is offline
Find More Posts by _Pattern_Man
Fly it like you own it.
_Pattern_Man's Avatar
Canada
Joined Feb 2006
Hello, I'm a little stumped with my A-10 brushless numbers.
Hi everyone,
In my GWS A-10, I'm running EDF-55 300H fans with Fiegao 2035-4700kv motors and thunderbird 18's.
Now I seem to be pulling 16.5 amps at full throttle and 10 amps at 3/4 throttle.
These little motors are rated for 10amps max. And this was on a TP 3S1P 1320mAh 11.1V pack.
If I switch to a 14.8 Volt 4 cell pack, will my amps go down or go up from the increased rpm?
I thought I had heard somewhere that more volts equals less amps?? But it would also equal more RPM and I can't exactly change the prop.
Also at 4700 Kv at 11.1V I'm looking at 52,170 rpm. And at 14.8 Volts, I'd be at 69,560 rpm. Will the 4 cell pack push the fan beyond it's limit? It seems a little fast for an EDF-55.
Thanks alot.
_Pattern_Man is offline Find More Posts by _Pattern_Man
Old Mar 26, 2006, 12:50 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
WOT w/4S will increase your ampdraw since the rpms increase.
(I believe) if you throttled down to the SAME rpm level as the WOT w/3S setup,
Your ampdraw would be lower at the same rpm.
But basically the 4700kv is too high for the load and may burn out with extended WOT running. So throttle back!
At the stated rpms the blades may rub but they'll clearance themselves after a few flights. I would add throttle on mine until they rubbed lightly, and after about 4 flights they don't rub at all anymore.
bmiller is offline Find More Posts by bmiller
Old Mar 26, 2006, 04:07 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
I'm a bit lost as to your numbers, are you pulling 16.5 amps WOT for both motors or one? Are they rated to 10amps each, or combined? I would have thought 4700Kv would be rated to at least 10 amps each, but at 20 by 35mm size would have expected more like 14-18amps rating.
And your battery at 1350mah is pretty small for this kind of current. I now have 4400Kv motors in my A10 rated at 12 amps each, they are 20 by 30mm and fit into the 55-150 housing. When I first spooled them up with my 1500mah 15c battery I hit 27 amps which quickly dropped to 24, the battery was over its limits, the voltage dropped towards 9v within 7-8 seconds. At 2/3rd throttle I was pulling around 17 amps and it fly fine like this with quick bursts to pull vertical for a loop etc. Today i am going to get a new pack, and will report on what happens, as its the same physical size and weight as my 1500mah JP, but offers 36amps max continuous and larger capacity with fancy korean cells. I am expecting to pull more amps and have this thing produce 700g plus of thrust, but time will tell!!
Hay Bill, you see my pics? I think they uploaded the second time. I have since weathered the paint a bit and done some decorating, its looking quite nice now
Extreme_RC is offline Find More Posts by Extreme_RC
Old Mar 26, 2006, 04:12 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Oh and dont forget, those rpm numbers are unloaded ones, take away 25-30% from what I have been able to calculate to get loaded rpm with the EDF55 6 blade rotor.
This particular issue has been nagging me for ages, so I compiled as much data as I could from sites showing motors fitted to EDF55 and the resultant rpm with x voltage, I ended up with around 25% or so drop in rpm with the 55 fan unit on the shaft. If I am wrong, or someone has some actual measured data with a tacho please post it!
PS: this might actually be worth askin Mr GWS about, he should be able to tell us % drop in RPM with the 6 blader.
Old Mar 26, 2006, 04:38 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Could you share your findings??
I think the issue regarding the selection of powersource for the EDF55 is very little covert by testers and producers...
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 26, 2006, 04:56 PM
68Strat is offline
Find More Posts by 68Strat
68Strat's Avatar
United States, MA, Andover
Joined Jun 2004
if you didnt already cut down the rotor to 3 blades this will increase rpm and pull less amperage.
68Strat is offline Find More Posts by 68Strat
Old Mar 26, 2006, 07:03 PM
Canada
Joined Feb 2006
Thanks for the input.
To clear it up The motors say 10amp max on them. So per motor. I was drawing 17 amps at WOT on 1 motor. And the lipo is 16c so it was fine. I didn't know what to expect for amps.
I would think I'd be alright if I manage my throttle properly but I wanted to drop the amps a bit.
I'm stuck with these motors and I don't want to trim blades if it means I'll loose thrust.
Plus the TB18 ESC's are only rated for up to 3S Lipo.
Old Mar 28, 2006, 04:24 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
http://www.rcgroups.com/forums/showp...6&postcount=28
Not by much less amps at all. The increase in rpm just compensates for the decrease in thrust for the same rpm. Not really worth the effort, just get the correct motors and be happy (your ESC's will thank you too).
Seems this urban legend has popped up (again) since HL mentioned it for one of their models they didn't have the correct components to do it right from the get-go.
Justin
roccobro is offline Find More Posts by roccobro
Old Mar 29, 2006, 07:07 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
4700Kv is too fast for the EDF55, you are pulling too many amps. Also your battery is way too undersized for the A10 with brushless, you will find after 5 seconds your battery is dropping very quickly towards 9v, and will go under it if you hold WOT for 15-20secs. You need a battery like the Hyperion I chose, cont' discharge rate is 36 amps, weight is 140 grams, its only 12 grams heavier than my JP 15c 1500mah but provides heaps more power on the bench. My setup is only pulling 16c WOT which is perfect.
Your motors are a little bigger than what I use, mine are 20-30 and weigh 43 grams, (same as original) are 4400Kv and rated at 12 amps but I am pretty sure they can stand more.
My 3400Kv motors from the same factory pulled only 8 amps WOT each yet were rated at 14A, the A10 flew nicely but could not pull vertical.
My current tests are:
4400Kv motors in the EDF55-150 housings, 6 blade fan, twin 18A ESC's and one of the new Hyperion CLX1800 20c batteries. On freshly charged battery it pulled 31 amps and 320 watts, dropping slowly to around 27 amps, 10.8 volts for 290 watts.
RPM on the fans at full throttle was around 19,000 on a hyperion meter, so that completely f#$%s my calculations of a 25% drop under load from the unloaded Kv figure!! (or the hyperion was getting bad readings)
I have yet to fly with the new battery, hopefully tommorrow will be a little more friendly wind wise, from the very basic measurements I can do right now I am looking at around 600-700 grams thrust.
Old Mar 29, 2006, 07:28 AM
Canada
Joined Feb 2006
Thanks for the info guys. The TP 1320 is not the battery I plan to use with the A-10. I should have emntioned it was just what I had close by for testing at the moment.
I have some 20C Apogee 2100 packs that I'll be using.
I'm pretty disappointed about the motor. I was told that the 5400kV motors were to much and that the 4400 was perfect. The motor seems to handle it fine but the 10 AMP MAX printed on it kind of scares me. It seems as though it should be able to handle over 10 amps.
Formosa with my new brushless alwhorley Foamies (Kits) 2 Dec 29, 2003 03:21 AM
Alert what am I suppose to do when i'm finish riding with my kyoho megaforce MEGAFORCE Off-road Cars 3 Sep 06, 2003 11:47 PM
Sky scooter ,Little problem with my esc or radio ?? Baveux Parkflyers 6 Jun 25, 2003 01:10 PM
I'm fed up with my Eco8, which gasser should I try? Ju87BStuka Fuel Heli Talk 5 Sep 03, 2002 02:03 PM
Need a little help with my Direct 280 SonnyG007 Foamies (Kits) 10 Jul 26, 2002 01:52 PM
