Mar 26, 2006, 08:50 AM
Singapore
Joined Nov 2001
Little Duo Discus
We were flying EPPs at this particular slope, since there isn't any nice place to land a plane other than into the bushes. Glass ships are too expensive to take such a beatings but I always wanted to fly a scale sailplane there.
So, I started to design my own 2 meter version of the Duo Discus from the 3 views. This project will serve as an experiment and it'll test the survivability of the design on this kind of landings. If successful, it'll open the door for me to design more scale gliders for such slope or if not, it'll serve as a sacrificial model for me to have some quick time fun there.
I broadened the chord a little and use the Selig 3010 to compensate for the low Reynolds number. The stab is enlarged by 10% and all these deviations are hardly noticeable anyway. Construction is fo blue foam for the fuselage and balsa sheeted sandwich wing structure with blue foam core. Stab and rudder are balsa.
The entire fuselage is laminated with 2 layers of medium grade glasscloth with Z-poxy resin. After priming, sandings, fillings, the fuselage is given a few coats of automotive white paint. The wings,stab and rudder are covered with Oracover light-scale white. The canopy is moulded from PVC sheet and given a coat of 'smoke' paint. All up weight tips at 21 oz.
