Old Mar 25, 2006, 11:25 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Neu 11xx bolt pattern
Is the standard bolt pattern of non-PGD Neu 11xx motors = 16mm x 19mm, M3 thread, or something different? (Im just guessing because those magic numbers have something to do with fitting Maxon PGD's like Hacker's etc?).
ptxman is offline Find More Posts by ptxman
Old Mar 26, 2006, 04:44 PM
Airbike is offline
Find More Posts by Airbike
United States, CA, Walnut
What's a PGD? Gearbox or something?
Anyways, the Neu 11xx motor has a 16mm center to center pattern and 2.5mm mounting screws.
Airbike is offline Find More Posts by Airbike
Old Mar 26, 2006, 06:52 PM
rcelectfly is offline
Find More Posts by rcelectfly
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
I think he means planetary gear drive.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Old Mar 26, 2006, 06:53 PM
ptxman is offline
Calgary, AB, Canada
Joined Oct 2002
sorry, Ive heard it as PGD = Planetary Gear Drive, or PGB = Planetary Gear Box
anyway, do you mean all 4 bolt holes are spaced apart 16mm, or is it 16mm in one axis & 19mm in the other (ie like Hacker & other euro motors)?
like this...
Old Mar 26, 2006, 07:04 PM
ptxman is offline
Calgary, AB, Canada
Joined Oct 2002
...and 2.5mm mounting screws.
For sure not M3 (3.0 mm)?
Old Mar 26, 2006, 09:38 PM
Airbike is offline
16 mm for both axis and 2.5 mm mounting bolts according to the spec sheets that came with my 1105 and 1110 motors, verified by measurement.
Old Mar 26, 2006, 10:34 PM
ptxman is offline
Calgary, AB, Canada
Joined Oct 2002
Thanks for teh info. Im getting a motor in the mail here shortly, I was just wondering in advance.
Typhoon Micro-15--mounting bolt pattern needed P-51 fan Power Systems 1 Jan 12, 2004 01:24 PM
Bolt pattern diameter of B50, and Axi Paul Susbauer Sport Planes 2 Sep 26, 2003 05:31 PM
razor motor bolt pattern YZ 212 Power Systems 3 Aug 27, 2003 10:54 AM
bolt pattern Astro 010 and MiniAC 16 KenP Power Systems 6 Feb 26, 2003 07:26 AM
Bolt pattern on the 450 Turbo motor vs. Speed600 motors Scott C Power Systems 1 May 22, 2002 09:57 AM
