Old Mar 24, 2006, 12:11 PM
Geekay
Geekay
Guest
n/a Posts
Big purchase this weekend - Mini Funtana 3D EP ARF from E-flite
Hello,
My local LHS in bay area is giving a no tax sale this weekend. I'm
planning to make some big purchases. Since I have little time to do my
research, pls throw in your choices if you have experience with Mini
Funtana 3D EP ARF from E-flite and a lipo charger.
1. Need fliight pack to go brushless (6.6:1 gearbox with 10T pinion
gear and 12x6 prop included in the kit). So need a brushless
recommendation that will suit this gear box.
2. Need a recommendation on good, reliable smart lipo charger (3- 5
cell).
3. Can funtana be used as a trainer? I'm a newbie to RC flying.
This is my purchase list
1. Specktrum DSS radio system
2. Funtana
3. Brushless kit for Funtana
4. A good smart lipo charger (3-5 cell)
May be I'm writing like a pro but I'm a newbie, so pls kick in if you
have any suggestions. I'm also planning to buy a trainer (RTF most
likely).
Old Mar 24, 2006, 04:11 PM
Ken Day
Ken Day
Guest
n/a Posts
Re: Big purchase this weekend - Mini Funtana 3D EP ARF from E-flite
On 24 Mar 2006 09:16:43 -0800, "Geekay" <jayanthigk2004@yahoo.com>
wrote:
>Hello,
Very familiar with this airplane. Have test flown 2 or 3 for
some flying buddies. Also owned one.
>cell).
No !!!! . If you have never flown before I would suggest hanging this
pretty little airplane from the ceiling to look at while you're
learning on something else , otherwise it's life will most likely
most likely be very short .
There are many good electric trainers out
there but my favorite is the GWS Slo Stick. Many of the club
members have these as they are a lot of fun to fly even for
experienced pilots.
I've seen a number of people learn to fly on these over the last 3
years or so . I have one and fly it often . I do have a brushless on
it so this makes it a lot more fun.
Get one with micro servos
>2. Funtana
Nice aircraft , after you get some flying time under your belt.
There is not really a brushless kit as such for this , but here is a
combo I have seen quite often and they fly good on this.
This is also what Horizon Hobby recommends.
Motor : Park 400 Brushless, by E-flite. 3700 or 4200 kv
25 amp Brushless ESC
4 micro servos in the 8-10 gram weight range , such a Hitec HS 55
Check to see what comes with your radio. You should be able to get
micro servos with it.
You will need a 3 cell pack ( 11.1 volt). I would recommend a 2100 ma
pack. I would highly recommend that it be a Thunder Power. They also
make a pack configuration that fits this very well.
Many out there. If you want to go sorta high end I would recommend
a Triton , or for a dedicated LiPoly charger that will suit all your
futures needs , an Astro Flight 109D. Great charger. I've had a number
over the last 3 years including the Triton and this is my favorite.
BE SURE that you study the proper charging procedures for
LiPoly batteries.
Buy a fire proof container of some sort to charge the batteries in and
NEVER leave them in the aircraft except when flying. Not even for
charging. Lowe's and home depot have a nice little safe for about 30
bucks that I like real well. Just make sure the case will contain the
a fire if that should happen. LiPoly's demand your attention , safety
and respect.
>likely).
No. We know you're a newbie , and glad to help in any way
we can.
>Thanks
Welcome
Ken Day
Old Mar 24, 2006, 06:11 PM
Mike R
Mike R
Guest
n/a Posts
Geekay wrote:
> Hello,
E-flite Park 4200 brushless inrunner and E-flite 20A ESC ( make
sure the ESC is version 2......B at the end of the part #, if there is
no B there then its version 1 and you will experince problems with that
E-flite 450 outrunner would also be good
> cell).
Triton
Can be with an instructor.....NO if its your first!! and
going solo. Try out a GWS Slow Stick and put the Park 400 in the stock
gear box and use the lipo pack for the Funtana.........you can always
switch over the gear to the Funtana at a later time when you have some
flite time under your belt
> 2. Funtana
> likely).
> Thanks
Sold NIB Mini Funtana 3D ARF Hoppla! Aircraft - Electric - Airplanes (FS/W) 1 Aug 24, 2006 06:14 AM
For Sale E-Flite Mini Funtana 3D EP ARF jmbneaf Aircraft - Electric - Airplanes (FS/W) 0 May 28, 2006 08:53 PM
Fs-nib Mini Funtana 3d Arf JONBOYLEMON Aircraft - Electric - Airplanes (FS/W) 1 Jan 31, 2005 10:27 AM
Fs Nib Mini Funtana 3d Arf JONBOYLEMON Aircraft - Electric - Airplanes (FS/W) 2 Jan 30, 2005 12:11 AM
Mini Funtana 3D ARF ptglass 3D Flying 12 Dec 19, 2004 05:42 PM
